View Full Version : 6 Cyl (V6) Applications
  1. motor swap
  2. Need A Quick Answer! Camshaft Synchronizer
  3. worst stang scavenger hunt
  4. Racing Stripes
  5. tranny shifting question
  6. Tuner or Exhaust
  7. Quick question about turbo pricing
  8. what should i do to increase header performance
  9. Lowering Opinions needed!
  10. Tuner on stock?
  11. here guys pics of the 4.2 build and the car
  12. 2000 3.8 litre thermostat issues
  13. Fianlly put my new wheels on last night.
  14. Stock 96--> Windstar (pix)
  15. Tires
  16. street cam
  17. Anyone need port and polished intakes?
  18. Cleaning out the shop
  19. what kind of gear oil to use?
  20. does the brand of bearings affect performance?
  21. V6 to dual exhaust X, H, or 2Ys
  22. PLZ HELP! 2005 v6 with rough idle and running
  23. Suggetions stock v6 '97 Coupe.
  24. transmission?
  25. Ram Air Shaker
  26. Gears
  27. Anyone have an extra 94-98 light grey ac vent?
  28. Mach 1 Chin Spoiler Owners, Painting advice...
  29. Just bought a 98... a few questions
  30. do I have to use a windage tray?
  31. Car Alarm
  32. HOt rodn my 09 mustang V6
  33. Quick Answer Please-OEM Cobra Wheels
  34. Can you black out
  35. A few question Regarding Tune Up
  36. Tread life?
  37. Need Help 2000 Stereo Removal
  38. Towing
  39. Hood Scoop
  40. ride hieght
  41. Electronic throttle body adjustments?
  42. Found a 4.3 stroker on Ebay
  43. SCT 2 or 3
  44. rear o2 sensors
  45. Struts/Shocks
  46. Door Repair
  47. wheel spacers..worth it??
  48. I have a all-stock 3.8 V6
  49. What are some good high flow cats?
  50. car wont start, might be tuner, HELP
  51. v6-gt guage conversion
  52. 00-01 engine diff
  53. how do you use the transgo shift kit?
  54. clutch problem
  55. Yes another CAI question lol
  56. Why let an exhaust shop make it?
  57. 1998 Exhaust O2 sensor question
  58. Another problem came up... ugh.
  59. 02 Stang buckin....not in a good way
  60. N2O with a m112
  61. Coilovers
  62. Rev Limiter
  63. 18" GT/CS Wheels OEM Bullitts on V6
  64. Exhaust system
  65. ford t-lok rebuild?
  66. only fits models without egr?
  67. Lesson Learned
  68. Mach 1 brake install
  69. How to remove rear seat on 98?
  70. Exhaust Question..
  71. Cam
  72. V6 problem please help.
  73. New hood
  74. 05 JBA Headers Install questions
  75. does my car need the MIL delete?
  76. Installed LTs/ H pipe, now have ticking?
  77. "new" maf
  78. Tail Light tint
  79. Beeping noise coming from dashboard...
  80. O/D problem !!!
  81. Latest Work
  82. 3.8 supercharged????
  83. Seat replacement options?
  84. too much
  85. where to get my tune from
  86. Overheating issues
  87. 0-60mph time estimate
  88. Neg effect of using 91 oct???
  89. whats causing my DTC P0171
  90. Pretty Rough Idle
  91. Trunk problems
  92. Gas Saving Mod?
  93. LT / O2 questions
  94. heads
  95. engine acting up
  96. SOCAL V6 STANGS NEEDED FOR A MOVIE
  97. Need to know if this rear end will fit?!
  98. Gears or a Throttle Body?
  99. wont shift :o(
  100. do i need new bearings for a gear change?
  101. VS.
  102. 1999 3.8 turns over, will not start
  103. Off road w/ long tubes?
  104. Wrecked Mustang Pics*
  105. Turbocharger Parts and Stuff?
  106. LOWERING SPRINGS!!!!!
  107. help please
  108. '98 3.8L spark plugs and wires.....which ones?
  109. couple questions
  110. trans issues
  111. Bleeding the cooling system
  112. Motoblue udp set vs. lightweight driveshaft??
  113. Turbo routings
  114. Are all manual 94-04 V6, GT, Cobra driveshafts the same length?-03' cobra on a 96'?
  115. Putting Cobra brakes on the 96' and suspesnion Need help with interchange parts
  116. T-5 oil drain
  117. Need ideas!
  118. flow rate on 4.2 heads and 3.8s plz POSTED PICS
  119. Power stering pump
  120. having a bad day? here's something to make you feel better about your car!
  121. What sounds better?
  122. Flame thrower kit?
  123. need help choosing spark plugs/wires/coilpack
  124. Rear end
  125. New headlights
  126. adjusting the stock clutch
  127. speedo problem
  128. 2000 mustang tranny?
  129. Temperature Gauge Fluctuation
  130. Speedo gears
  131. Temperature gauge wont rise
  132. trouble with pypes exhaust
  133. 01 Cobra stock exhaust fitting onto a 2000 V6?
  134. should i install a transgo shift kit?
  135. breather filters bad?
  136. bad mileage
  137. LT's on 2000 mustang
  138. do i need a new bearing kit?
  139. Cold air intake= decrease in fuel efficiency?
  140. The best place to buy touch up paint
  141. NOT FIRING PLEASE HELP
  142. 03 throttel cabel
  143. Will 9/10.5 rims with 275/40/17 fit my 98?
  144. How unlocking tuners works....
  145. Broken Window Selenoid Holder Thingy
  146. Looking for some help with a '94 V6
  147. Fuel rail help
  148. ignition wires
  149. Engine roar...i dont hear it..
  150. Location of Engine Block Drain Plugs
  151. ??
  152. would this fit my car?
  153. '98 3.8L Oil Pressure gauge flickering....WTF?
  154. got my new hood!
  155. just shuts off
  156. what looks better
  157. To anyone who is planning on getting the Duplicolor caliper paint...
  158. GT Fog light back plugs
  159. brake upgrade on 96
  160. Who's faster
  161. True Duals and LT's
  162. Cigarette lighter's not working? 1998 mustang
  163. tuner with 04 v6
  164. Not sure whether or not to sell my car...
  165. motor start up troubles
  166. Lookin at some new gears for 03 V6 mustang - what all do I have to get?
  167. Wet or Dry?
  168. Manual Transmission Synchro Problems? Help Please
  169. Flowmaster vs Mac Exhaust on 1998 mustang
  170. Trac Control questions...
  171. help, sumthins wrong!!??!!
  172. new battery
  173. need some help
  174. Bent the rear??
  175. 17's or 18's wheels???
  176. clicking noise
  177. '98 V6 w/Auto dual exhaust suggestions
  178. Anyone know where to get a good/cheap alternator?
  179. Pick one
  180. Replace left rear tail light bulb?
  181. Camshaft Synchronizer
  182. 98 Mustang Heater core tapping noise..HELP!!
  183. DELETE!
  184. Cobra Bumper?
  185. New gauge cluster/car wont start?????????
  186. ABS Sensors.... HELP
  187. How do tuners work?
  188. 170 engine hp give or take...
  189. Spark plug wires? Mistake?
  190. Tuner or Gears
  191. New gauge cluster/car wont start?????????
  192. Buying used/rebuilt posi?
  193. 1998 - 4.0 Lt. Engine - Idler pulley / Belt Tensioner Question
  194. will '02 f150 engine fit? what do I need?
  195. 1981 Capri 5.0 swap?
  196. SCT SF3 TUNER
  197. Does the 7.5" rear end have a gasket?
  198. Wrecked Mustang
  199. Fuel pump?
  200. need some advice on tires
  201. Underdrive Pullies
  202. Sn-95 Idle
  203. Audi S4 Turbo on Mustang
  204. o/r exhaust vs. a 4.10 ratio
  205. Battery Cable Corrosion
  206. rough idle
  207. short ram or Cai
  208. ZMAX
  209. Trans Problem
  210. 1995 mustang info
  211. bullitt grill in a V-6 car
  212. WRECKED!!!! RIP ol' girl
  213. P1000 code, flashing theft light and issue starting mustang
  214. What are the best upgrades for a V6
  215. Fuel Pressure
  216. Replacing tag lights
  217. Need some suggestions...
  218. Hood scoop w/3M?
  219. CLUTCH HELP and drive shaft help
  220. will a 03 oem cobra bumper fit a 00 mustang
  221. stock tranny in a 2000 v6
  222. Motor Mount Issue?
  223. Educate me?
  224. Educate me?
  225. Airbag light flash code 52
  226. he wrecked it!! now what
  227. Front Rotor Measurements
  228. Pypes Dual Exhaust for 4.0
  229. Squeal from crankshaft pulley
  230. what are the gains of a t-lok?
  231. Need To Find A Few Parts
  232. xcal3 for $175 OR livewire for $200
  233. squealling noise from the main pulley area
  234. Rear Window Louvers
  235. Few problems with my sixer
  236. catalytic converter removal
  237. Fuel injectors
  238. has anyone done this before??
  239. Will a engine & tranny from a 03' work in my 99'?
  240. Looking into advice/help for autox
  241. Fog Lights Just Dead
  242. 2001 V6 3.8 - Filler Pipe Question
  243. Rear Seat Delete
  244. how much is my car worth
  245. MAF questions
  246. quick hood question
  247. NEED TO KNOW WHAT/WHERE TO GET THIS PART! Pics inside!!
  248. Need Help Deciding
  249. $70
  250. How long do stangs last
