- throttle body decision
- V6 engine groaning
- Agreeive look hoods for 1995 Red 3.8L
- boosted!.. but not making any power?
- Bushing Kits
- Ebay CAI
- power increase
- Things I did to the stang this weekend
- New Headers
- 8.8 From a Crown Victoria
- HELP, replacing window in '02 stang??
- Programmer after 4:10s?
- Question about installation for CAI
- rear end question
- cold air intake
- cold air
- Motor running hot?
- low grinding at high speeds
- Will it fit?
- Squealing noise
- 99 v-6
- torque converter
- 99 v6 Radiator Fan not working
- V8 Exhaust System
- new cam?
- need new tires if lowered??
- pulley changes
- seat deletes
- 3.8L v6 Exhaust Question.
- squeaky window
- When to chip?
- Oops to much oil ??
- scoops
- 2.3T rmp and gearing question
- Odometer stopped?
- Mustang V6 2004 Problem
- help with tires!!!!!!!!
- RPM and Gears question
- inspiration for the V6 crowd *vids*
- Fuel pump
- 98 3.8 install problems
- any one have?
- mam
- clutch petal height
- 2.3 does anyone know for sure????
- Interested in getting a 99-04 5spd Mustang 3.8
- Anybody know where I can get a new Ash tray?
- 98 V6 mustang specs
- 3.8L exhaust
- 91 turbo bird ecu in 88 mustang?
- Blown head goosket :(
- Mothers getting an 00 v6
- Help on putting 2005 GT grille to 2005 V6 Mustang
- 2005 V6 Performance Parts
- tranny swap
- I did it!
- What New Transmission?
- whistling noise
- Check engine light
- 05 V6 exhaust question
- where is the best and cheapest place to buy un pulleys for 04 v6?
- K&N maf kit does it work?
- CHANGING EXHOUST
- How difficult is it to change the heads?
- Gauge question
- Questions about some codes
- empty hole in dash
- cold air
- v6 exhaust
- suspension
- T-LOCK OR NEW AXLE
- shakes
- What's the 1st mod that you did?(V6 ppl but V8 welcome)
- vortex
- Next project
- Radar Detectors
- resistor
- 1988 mustang
- Gas...Higher Octane Better??
- ebay stuff
- Ram Air
- Help installing new cd player
- say what!!
- 8 plugs 2.3L
- Faster
- Bad Cig Lighter
- general help with my 82 4cyl
- Governor removal
- Fuel Cutoff Switch?
- anyone have any 2.3L performance mod sites??
- Help on installation of CAI
- alternator problems
- Sweet..kinda
- Still have issues with my 98
- Air induct?
- 05 V6 1/4mile and 60ft
- Do underdrive pulleys actually help?
- quarter mile
- Are lighter flywheel and aluminum driveshaft worth it?
- my first Turbo
- horseppwer
- damnnn!!
- Hood scoop
- I'LL TRY IT
- Ummm.. trany question
- Performance parts, 2.3L 4 cyl.
- How much HP can the 7.5" rear end handle?
- High pitch noise during hvy acceleration 3.8
- V6 Engine Swap for manual transmission
- clutch pedal pad
- Pypes Performance Exhaust Question
- F-350 Turbodiesel
- can you feel....
- cold air?
- Module changed?
- True Dual Exhaust PROBLEM!!!!!!!
- Ya also:
- 95 3.8L Plug wire routing?
- Top end compared to others
- Clutch?
- 98 6 cyl having trouble starting
- high po power pack
- 89 LX , 2.3L
- hood troubles
- ok ... Witch cars should I look for in the junk yard ta pull a 2.3L turbo ?
- Exhaust leak
- Twin Turbo
- exhaust or intake
- need some quick info to get started
- Engine mounts
- trans swap
- car suddenly wont start...
- 2.3L ta SVO turbo swap ..... Help with steps
- Wheels
- Noise when car put in reverse
- can some body explain in short what 3.8, 2.6 , 5.0 means ?
- rear gears and posi
- 05 v6 dual exhaust
- notice fellow 6er's
- what to do?
- Turbo 2.3L
- I want true dual exhaust!!
- Cleaning my engine!!!
- Mustang Mods
- make some threads sticky ...
- converting 3.73 gears to 4.10 & posi
- dynomax on a v6?
- Custom True dual exhast
- SVO info needed!!!
- Crazy High Idle
- Couple of Q's for yall
- Cams
- T Top swaps
- hydraulic or spring loaded???
- Improve hp
- Gauges
- i need help
- Suggestions for some V6 mods please
- How to test oxygen sensors? And plug wires?
- Good deal on GT?
- car idle ?
- hype?
- run open headers
- Electrical Glitch at High RPM Question....
- Fuel Pump Question
- help on deciding new exhaust...
- it's a culture, man!!
- ZEX 75 shot nitrous wet kit
- Throttle body spacers
- rear end gears
- Slugish
- What kind of Fuel Injector Cleaner
- v6 2004 mods
- cold air kit?
- 3.8l V6 MUSTANG[X(]
- CAI, is it working correctly?
- Top Speed in 04 v6 !VIDEO!
- Drive line vibration ?
- Which tranny ?
- 2.3 hp rating???
- 200 amp alternator
- Wheres the VIN number???
- could...
- top speed
- gt rotors
- 97 V6 coupe weight
- need help
- races
- bbk or mac
- how do I get my MPH too rise , I only can do 85
- wish list. let me know
- P0175 code!
- GA exhaust & window tint laws
- blow thru VAM ??
- My poor car!
- Question on tire size
- Which wheels do you guys and Stang sweeties like best for your V6 Stang?
- weight on a 04 mustang
- cams and pistons
- crank and at the wheels?
- gears and posi- trac
- HEADLIGHTS GO ON AND OFF ! ! !
- 98 3.8L horsepower?? h'much?
- Question on headlights
- supercharger?
- Gear Ratio question??
- Short Shifter!!!
- hp gains
- Best headers
- NOS Kits!!!!
- Headers???? Long?? Shorty headers??
- Which CAI and Underdrive Pulley's
- what is your 6-cylinder mpg?
- Any v6 mods?
- flowmaster 40 series?
- Thinking of purchasing a 95 V6
- 89 2.3 to 5.0 conversion..Info needed PLEASE!!!
- Using GT take-offs
- Before I install my CAI:
- Supercharger
- supercoupe sc's
- Starter won't stop cranking
- Whats wrong with my car?!?!
- head job
- Trans problem???
- Engine swap
- Motor Swap Help!!!
- synthetic fluids ... which kind?
- Best mode for better fuel mileage?
- Realistic Dream or just that, a dream?
- 2004 V6 dyno
- Just bought a 99. Advice? Upgrades?Performance?
- engine conversion
- engine conversion
- engine conversion
- can i take a 04 cavalier 5sd
- 2.3 Turbo Motor For Sale Please Look!!!
- my 04 stock v6 beat my friend camaro
- buying a 2000 Mustang
- Rice or nice
- Help me with a price quote??
- CAI IAT Sensor help please!!!
- Headers
- 2002 V6 Mustang Rear end gear
- V6 Exhaust
- suspension $$ question
- Spark Plugs...
- V6 exhaust question
- 2.3 Header Interchange
