- strut tower brace
- Pic request
- need help 347 carb
- Good deal on GT 40P heads?
- Carb Advice?
- 91 Mustang ( Efi swap)
- Which carb?
- new to carbs help if you would
- Stock 5.0 motor specs????
- 347 daily driver
- ? on Speed Density!!!
- Non HO cam in a HO motor
- pvc valve after carb swap
- E85 Carb set ups?
- 1988 GT Vacuum/Hoses question
- In need of torque wrench settings
- Car wont start!
- 82 t-top carb into an 87 gt vert?
- Edelbrock Performer 289 v. 302 EGR
- fuel pressure
- High Idle engine!
- Rearend Question
- Dissy question
- fuel pump
- carb gas leak
- What Can I Remove?
- what happened to the cams for sd sticky?
- oil pressure
- Hesitating & Need Advice/Info
- rough idle_cant change replace much more-no codes
- H.C.I help please?
- SD/MAF ?
- intake manifold
- FUEL LINE ???
- carb to fuel injection
- SPEED DENSITY TO MAF
- Distributor question
- maf conversion question
- speed density fuel injection behavior
- Fuel Regulator
- what are these? smog/egr/??
- what carb and manifold to use???
- harness ??????
- Whats the difference between injectors
- Which auto Trans to go with?
- What throttle cable should i use?
- Anyone runnin a comp thumper cam?
- SWAPPING FI FOR CARB
- How Bad Are Carbs?
- Severe SD problems
- efi to carb swap
- opinions on a carb
- Dead Spot?
- Electric Fuel Pump
- Vacuum Advance
- Ok guys which distributor would be best
- VACUUM DIAGRAM NEEDED
- rear end swap
- How far can I go..
- I wanna go carb'd
- Am I missing something here? Thoughts?
- EEC-IV Identification - help, getting mixed information
- SD VS MAF conversion
- Dual Carb?
- Help...
- New to carb need help setting time and info on 6AL
- Fuel pressure - what should it be?
- Carb'd 302 help..
- 1989 mass flow or DA1 ?????
- fuel level carb conversion
- 87 Notchback, want to modify engine 400hp range
- why wont it run like it should
- Car runs... kinda
- Opinions plz
- Efi to carb need help on what dizzy
- rear end ????
- 7.5 rear end ?????
- getting stock tach to work with carb
- carb ?
- 83 capri rs 302
- anyone have an S/D 347???
- efi carb swap on 94-95 mustang
- Ok now with all correct info, looking for opinions
- Ordered a couple things.
- ARG help.. fuel delivery question
- 91 carbed 5.0L missing at low RPMs
- coolant temp guage
- 1. Rough Idle At Start, 2. Power Loss At Speed
- will a tubular GT40 intake and super comp headers work on a stock cammed 87 density ?
- DRIVE SHAFT U JOINT FLANGE PROBLEM!!
- Throttle cable?
- Mass air conversion question
- pics?
- carb for my 302
- A couple carb questions
- Knocking sound cam and head swap
- Clearance
- TURBO 86 5.0 Speed density
- 1 Electric pump, 2 Regulators
- do 1984 302 pistons have valve reliefs
- help with carb sizing!
- V-8 Swap Into Notch
- Mass air conversion (need help)
- Carburetor "sizing" for a SBF
- Heads?
- 02 sensors
- 89 LX wont start without starter fluid
- switching to carb
- carb ?
- Best Carb? '95 Mustang GT 302 w/ Edelbrock Performance RPM intake
- Necessary Vac lines for carb setup???
- New To this Whole Carb Set Up. Couple Of ?'s
- fuel question
- HELP(EFI TO CARB)
- Throttle sticking
- Turbo Carb
- What fuel pump/ regulator to use
- carb 5.0 swap into 89 2.3 body
- Question
- 87 gt
- vacume secondary VS mecahnical
- speed density and supercharging
- misfiring
- which intake mani?
- Help carb adjustment
- What size carb?
- Carb swap checklist
- MSD 6A + Carb Question
- carb conversion question
- How far can SD really go.
- what gaskets for weiand x-celerator intake carb
- Steeda #19 cam with speed density
- Carb options
- Swapping to carb question?
- Switching to carb
- intake, carb ,dizzy suggestions
- cam swap in 86 5.0
- Cam Choice
- Carb Question
- RHS 180,200s or Dart Iron Eagle's?
- gas mileage on 88 5.0
- Cam Specs
- Which head gaskets to I get for gt-40p heads on 88GT
- gotta beat my friends 4.6
- Help me with this cam
- Speed Density to Carb?
- weather idle issues
- 750 carb
- CFI to Carb
- At the risk of sounding.........
- Speed density gt40p
- Need MORE power!!!!!
- 87 mustang!!! HELP!!!
- Cheapest way to swap to carb.
- need speed density adapter for CAI
- Speed Density Cams
- belt help needed
- speedometer error
- Cam Options.
- 21lb injector capacity?
- Pics of my SSP
- problems after puttin t5 in auto car
- help..first time owning a carb
- Carb Question!!!
- 94- ? roller 351w
- NEED HELP! intercooling an s/d car
- 331 stroker running lean
- Missfire
- Fuel Pressure Question?
- get codes but no data??
- Nitrous and SD
- turbo ? + manifold ??
- megasquirt
- busts up under a load
- SD tuning
- 86 5.0 question
- Car wont run!!!!!!!
- Anyone have experience with the Keith Dorton 2bbl?
- cam problem
- Stock Fuel Pump?
- SuperCharging or turbo charging a CARBD 5.0
- stand alone harness
- 87 Mustang
- vacc. secondaries aren't opening
- Anybody Running Holley BLue or Red Fuel Pumps..
- Speed Density vs. Mass Air????
- carb s/c
- carb problems
- idle question to modded SD guys
- T trim Streetable
- 87 missing at high rpm(WOT)
- Carb Distributor ??
- 87 GT vert - Oil leak, bad MPT...etc
- carb swap...fuel pump wiring
- what to set fuel pressure at?
- Chirping noise under hood?
- Pony carb trouble
- how well will it run ?
- efi to carb
- What makes a cam SD compatible?
- carburator for turbo applications
- STALLING
- basic build up need alot of help, 88 lx 5.0
- PATRIOT HEADS
- efi to carb need help please
- carb/intake question
- 5.0 carb tuning
- Model Number for Carb?
- stalls when given gas
- Major rebuild coming soon, need some advice!
- Carb fuel pump question
- years for speed density cars and differences...
- fuel pump vapor return line
- heads intake for DD
- SD 5.0 not running just right after startup.
- Help ... Engine idles at 1400 RPM when hot.. 4bbl holly 1985
- Surging Idle help please?
- 1/4 mile times?
- SHORTIES VS EQUAL LENGTH SHORTIES??
- Injector order?!
- Water/Methanol Injection
- RADIATOR??????
- MOVED: FRONT BUMPER ?
- 1985 Mustang Gt Failed Smog check
- HIGH RPM PROBLEM!!!
- Looking at buying a 86 5.0. Advice Needed :)
- help ignition problem!!
- Speed Density/Mass air question
- 750 DP with HP main body swap.
- distributor
- NX264HR COMP CAM W/ SPEED DENSITY??
- Tuning my supercharged Jeep
- high idle
- Cutouts
- cough & sputter at 4grand
- blue smoke and smells like gas?
- fuel pump ?
- '88 GT 302 Randomly Spontaneously Dies!
- 85 GT problem
- Lifter Knock or Worse?
- Porting explorer GT-40p heads and intake on SD setup
- Ready for the Spray
- parts question that need answer please
- new to SD
- need some help?
- High RPM engine hesitates????
- 1.7rrs on crower 15511
- EQUAL LENGTH SHORTIES OR LONG TUBE HEADERS???
