View Full Version : 4.6L V8 Specific General Discussion
  1. Standard GT fuel pump
  2. MAC prochamber
  3. Engine Components (help)
  4. Just Finished Brenspeed Saleen stage 3 install
  5. 05 GT Exhaust question
  6. Saleen S/C for 07 models
  7. R&D For Winter Engine Build Cylinder heads
  8. need help finding parts
  9. parking brake question..please help
  10. 75mm tb and plentum question
  11. front sway bar delete opinions
  12. side exhaust question
  13. Pro 5.0 3.90 vs FRPP 4.10
  14. Anybody else getting a hiccup?
  15. direct replacement wheel studs but longer
  16. Bad Valve Stems and Hood Struts
  17. will these wheels fit on the car
  18. need installation help!
  19. Gear change ratio reflash
  20. "Free"/Cheap mods?
  21. 01-04 faster than 05-08?=(
  22. Anyone ever seen this from a datalog?
  23. insight on 'bolt on' set up
  24. Difference between comp stage II NSR cams?
  25. turbo v. supercharger v. nitrous
  26. CAI + Tune = Pinging
  27. Slp long tube header install help
  28. How much rwhp do s197gts make?
  29. New roush charger on horsepower tv.......
  30. cams
  31. 36,700 miles & engine light comes on
  32. Exhaust question
  33. Dipstick problem
  34. Well add another to the Whipple hot rod cam crew
  35. need to increase horsepower on 97 mustang
  36. I'm so stoked
  37. Running 97 octane and still getting detonation
  38. Jlt cai
  39. When is 3" FULL exhuast needed ?
  40. Dyno sheet gains for hot rod cams
  41. anyone upgraded from non-aftercooled vortech to aftercooled?
  42. Yellow Freight Sucks, Lost my Whipple
  43. KOOKS LT header install
  44. How hot is tooooo hot?
  45. Nitrous help
  46. PICS? PHOTOSHOP??? Blackout panel on a torch red with white stripes!
  47. Need help...
  48. Anyone running an auto trans with an O/R pipe?
  49. Tillman Speed....any good?
  50. Rpm's Dropping Below Idle (while a/c on)
  51. Almost done! Steering Rod Question!
  52. How do you check timing on a 3v?
  53. Tune
  54. Just not happy with exhaust sound. Any ideas?
  55. Question for those with American Racing Headers...
  56. fitting longtubes with a particular midpipe
  57. Whipple Programming for a 2008 Mustang GT
  58. Another Spec 2+ clutch hell
  59. Will this Bogart rim fir
  60. anyone have CC STG 2 XFI dyno graphs
  61. How to Jack Motor up?
  62. predator revisions necessary?
  63. Magnapack Catback exhaust.
  64. Spin tires from 1st gear roll with 3.31s?
  65. proper way to clean c&l air filter
  66. wtf feels like im down to 1/2 power
  67. Need Opinions, What sounds better?
  68. NEW: 05-09 GT Fore Precision Fuel Rails!
  69. FI and fuel pumps
  70. MAJOR hesitation....why?
  71. The Cursed Pinging!!!!!!!
  72. Size difference between C&L Street and Racer
  73. Aluminum Coolant Resevoir
  74. Race tune doesn't feel the same.
  75. serpintine belt
  76. Fluid Options for 4.10 gear install?
  77. DIY Paxton 2200 install? and some '???'
  78. Dynotech S197 Driveshafts in Stock!
  79. I want lots of power...but still kept 87 octane?!
  80. Mcloed RST Installed
  81. A question ive always had about Cams..
  82. Psi for stock engine?
  83. Built Motor is in and running
  84. Coil Packet ?
  85. Best place to get an engine block
  86. Best Cams for street driven NA GT?
  87. Anyone want to work on Barricade with me?
  88. CAD Exterior Lights
  89. Error codes after cam change, anyone else
  90. CDC shaker with GT500 TB?
  91. Need help with LT header install!
  92. upset with benspeed
  93. trying to figure out if i have a problem..just got back from the track
  94. h-pipe
  95. Problem
  96. best mid pipe for Borla Stinger?
  97. Annoying exhaust rattle
  98. my dilemma
  99. K&N CAI (63-2565) Issues?
  100. Engine/Exhaust Trouble?
  101. Exhaust cut-outs
  102. Whipple w/FRPP cams - First start up
  103. Ford Racing CAI Dyno Sheet
  104. Surprisingly good sounding exhaust setup.
  105. brenspeed sct x3
  106. Hot Rom Cams w/ B&A Video
  107. MSD Cop's
  108. H pipe & flowmaster question.
  109. Massive Vibrations … help!?
  110. took time off work for my cam install!!
  111. Steeda CAI problem/concern
  112. VMP Tuning Dyno Day at Hooters
  113. bamachips VS brenspeed
  114. Hot Rod Cam Installation Guide
  115. I'm tired of you all with superchargers!!
  116. Whipple SC'd Stang + FRPP Hot Rod Cams- install writeup sticky at top!
  117. 89 tune with 93 octane?
  118. Rear O2 sensors?
  119. Aftermarket Intake Manifold
  120. BBK Shorty Headers installed and Custom Dyno Tune
  121. Selling my Turbo Kit
  122. SCT X3 tune recomendations?
  123. Flow master intall problem, tips not aligned
  124. RST Installed FINALLY!
  125. Hot Rod Cams installed-- finally
  126. Anyone Else Weird Idle After Header Install?
  127. Got in the 11's with stock T/C!
  128. x pipe O2 sensor
  129. rear seat delete?
  130. Rocker Stripes for a GT
  131. Lethal Performance teams up with Saleen!
  132. First Mustang, Help Appreciated on CAI, Headers, Gears
  133. gas
  134. Weight of the 3v 4.6
  135. boomtubes and stock hangers
  136. New mods
  137. in need of some help
  138. 07 GT Auto-First time at track-Questions
  139. Need some advice on what to buy!!
  140. Axles...
  141. J&M Sale at Lethal Performance! 5% and Free Shipping!!
  142. sudden acceleration at 3k
  143. Cam ?
  144. Roll Cage ? Need info!
  145. Best TB for under $360 while going F/I?
  146. anti lock
  147. Engine Torque Specs
  148. Engine Removal
  149. Engine Miss
  150. Brenspeed stage 2 saleen kit ?
  151. gapping HT0's
  152. Oil capacity
  153. Spark Plug for my N/A
  154. typical oil PSI on the 4.6?
  155. bug got me
  156. Livernois
  157. Reliablity of Mustang GT
  158. Dark smoke under acceleration
  159. CAI + Tune???
  160. suspiciuos ?
  161. which 5th gen mustang is best?
  162. Pulley Mod Question?
  163. Severe rear end problem--- Headed to dealership
  164. Need Help error codes!
  165. 2007 GT Deluxe vs Premium
  166. back from the dyno, what do u think
  167. Question on a CAI
  168. Mustang header bolts
  169. 06 question...
  170. Paxton and Vortech crew meeting!
  171. 480-490whp?
  172. Ford Hot Rod Cams Arrived Today !
  173. elusive part - anyone know where i can get 2?
  174. OBX Headers?
  175. RST Arrived today!
  176. Twin Screw question
  177. Need Test Vehicle - Free Custom Tune
  178. Good Price for a Whipple install @ Dealer?
  179. Condensation...Weird?
  180. Need Help
  181. The results of my cammed and AC Vortech "dyno vid w/ numbers"
  182. HTO or BRISK
  183. Brenspeed Saleen Stage 3 Cold Start Issue
  184. Whipple 05+ HO Kit Price Increase. SAVE BEFORE THEY GO UP!!
  185. engine trouble codes?
  186. Tune issues,need help please!
  187. simple, wheels
  188. Auto Fire Extinguishers
  189. help me decide.. 93 race or 93 torque tune?
  190. Prochamber splice for stock cats
  191. What am I missing?
  192. Need Muffler Suggestions..still too raspy!
  193. tensioner and belt for whipple
  194. air intakes vs K&N
  195. Fuel Lean code, Supercharger
  196. So Many Options!
  197. Check Gas Cap Light keeps coming on!!
  198. Good Price?
  199. Exhaust adjustment?
  200. Pinging??
  201. Race Tune = less gas mileage?
  202. First Mod!!!
  203. Pinging??
  204. BBK Shorty Headers
  205. Knock sensor and adaptive timing
  206. Custom gauges w/out adding gauges?
  207. Custom gauges without adding gauges..?
  208. full bolts Vs FI only?
  209. help with exhaust
  210. Brenspeed FI Installation Question
  211. comp cams thumper cams?
  212. Anyone ever have their engine light come on?
  213. Vortech S/Cers suck to install. 1 mile of hoses. ;)
  214. Vortech after cooler surge tank?
  215. H&R Race Springs - Possible Camber Problems
  216. Throttle Body
  217. New Clutch?
  218. Ready to pull the trigger
  219. help!! Please
  220. Help with locked rear brakes
  221. FRPP hodrod cams power?
  222. Who has the most hp/tq on a stock block?
  223. Dexicool
  224. Dyno and track day.
  225. Stingers.. two models?
  226. where to get supercharger???
  227. Looking to stay N/A, what is out there?
  228. I got Boosted on 8/8/08.
  229. TPMS Programming
  230. Brenspeed Tune
  231. best tune?
  232. help with exhaust Popping.
  233. mgw shifter
  234. Whats the deal with Diablosports MAFia?
  235. What coolant?
  236. I am now Cammed! now w/ install pics.
  237. Wideband Tuning with SCT 2
  238. Is a Do It Yourself Turbo kit a bad idea?
  239. Torque specs?
  240. New Exhaust Video Comments on sound?
  241. Magnaflow 2.5" vs 3" Performance Exhaust
  242. Spend My 2k on Mods!!!
  243. WTF, Vapor Lock on CAI?!?
  244. FRPP Stingers Vs. Borla?
  245. End of Supercharger Saga - Dynotune from VMP
  246. What Oil is best to use? Please help.
  247. Am I understanding this correctly???
  248. Just got MMR Motor installed
  249. TCI Ratchet Shifter?
  250. Hot Air
