- stock press fit "spring lock" fuel line to 3/8 NPT
- NEW MOTOR SMOKING HELP!!!!
- clearance
- 351 swap in progress
- lbs/hr
- 351 build
- My 351C proj....
- rpm on 351
- 351 build
- High Oil Pressure, Oil coming out of everywhere
- gt 40 heads on 351?
- Need some advice please
- 408w most horsepower
- connecting rod question
- will this work?
- Block casting
- extream windsor over hual
- 351 intake leak
- 351 C conv
- will my S/C fit
- 351 horsepower
- Torque sequence for main caps
- 225 or 205 cc heads?
- 351 aftermarket oil pan question
- 351w flywheel
- Determining engine specs
- Ok guys, Time to show off those engines!
- Need some Help 351w running MAF 5.0L A9L Computer
- 5.0 fuelie on a 351 w
- Problems after 351 swap.
- What kind of Fuel Pump?
- 351 lightning motor swap into 87 fox body
- Ford racing 351
- Start Up Problem
- combustion chamber size...351W
- 351W in '98 6cyl????????
- Looking to Tap ya'll's 351 knowledge!!!
- 351 build
- To boost or not to boost?
- 393W intake?
- New to 351w's, swap parts list
- hp?
- 351w fuel system question
- 351w Stroker Opinions
- 351 swap into 4cly
- oil pan question
- 351w streetable ?
- 351 turbo help
- 351 Swap part question
- Got a new 351w block (stoked)
- drive shaft strength question
- 351w build up
- I thought these were apropriate for my car
- im looking for a guy i sold a 351w to in washington state
- 408w fuel system
- mac headers???
- 351w w/2 bolt mains
- best flat tappet cam for 351w
- 351w owners post mpg.
- I need some help...
- Swap question
- Has anyone tried this combo
- valve question, may have been asked before
- more 351m help!!
- 351w question
- 351 Cleveland
- 0il pan question
- 351w fuel delivery?
- 1990 351
- 6.200 rods w/ 3.500 stroke?
- fox 408w main girdle?
- Distributor for 351w swap
- balanced kit or non balanced
- dart heads
- Tremec 3550 problem!
- Intake ?
- 351c Headers?
- GT40p heads
- engine combo help roller 351
- Swap Problems
- radiator help
- Carb too big???
- sheet metal intake.
- RPM redline for 351
- Electric water pump on Roller motor
- motor notching?
- 351 cheap buildup
- Spec stage 3+ w/ NOS
- 4cyl to a 351m???
- 5.0 upper on 351 lower?
- Ghetto fuel leak repair? Carb...
- 351C into Foxbody
- SO SEXXY, got my new pistons at the house tonight
- timing cover interference
- 351w Engine Combo ?
- balancer questions???
- initial fuel pressure and timing
- 351 problem
- 351 header question
- 351W headers???????
- head = pushrod lenght
- 357w Head confusion! Need Input
- 351 roller, supercharger?
- 408 build carb help
- What to do about a K member
- 351w swap in 95 mustang carb or efi ????
- Supercharger Sale from THR...Blowout!
- oil pan swap question??
- New Guy.. I have questions and would like input!
- Looks like I am stroking the 351w! (408 or 427!!!)
- 1979 351w
- interference issues
- "Budget" 408 - Component Questions?
- What stroker crank to use?
- Tires for hooking
- Aluminum head torque specs?
- MY RWHP better be HIGH! I HOPE
- SCAT 9000 crank???????
- 4 cyl to 351 swap
- MOVED: Where's everybody From
- Power Stearing bracket???
- my 351w build thread!
- MUSTANG 351W Nitrous Questions
- TRW Forged .60 Piston
- need advice
- finally got a 351w, time to build it! Looking for some advice!
- got some pics of the new ride
- Oil Pump pickup???????
- 427W in an SN95
- How much Nitrous can my 408 take
- swap brackets
- what auto trani to run with a 408
- getting myself a christmas present
- new motor
- 351 c
- New to the 351 MPG help!!!
- Pushrod length?????
- Some Help?
- re
- LS1 vs this setup
- camshaft help asap
- where to start?
- AFR 205s
- 351 plus Novi2K
- s/c 351
- Piston Cam question for a 408
- WHICH HEADERS WILL WORK?
- 408 rediculiously simple question
- stock 351 or mild 408 with STOCK C4 tranny?
- 351W based motor info please
- motor mounts not fitting.
- too good to be true right?
- wat size cowl hood
- compression ratio
- Stroker Clearance With Windage Tray?
- 351w EFI Intake help
- 351c help?
- roller conversion confusion
- Area 351 project
- how much power
- 351 swap
- what to build?
- Some things to consider with your 351 swap
- How large can the cam go?
- 351 helpp
- My new ride
- H/C/I Combo For cheap???
- will this 351 work in a fox body????
- control arm help
- 351 efi under stock hood in a SN95
- Help! Car will not start!!!
- porting work
- WHERE TO GET A BLOCK???
- 4 Cylinder Driveshaft with 351w.
- 351 EFI MPG?
- 351
- 351w clutch kit / tansmission mind boggler
- converting carb to FI
- what manual tranny for 408w street car?
- 93 e 250 351
- Fuel injection or Carb?
- I BOUGHT A TRUCK :)
- mex prod 351w
- 351/400m heads?
- BOOKS!!!
- 351W Head Part Number Location???
- -408- solid roller??
- compression ?
- heads for now and later
- 1969 351w Identification
- cant decide on a stroker?
- 94-95 Longtubes
- thinking about a 351
- CAD Files
- Can i use a 3.850 stroke crank???
- Suspension???
- Pushrod length??
- 351 wih stock hood
- does anyoune have pics?
- What all is there?
- help with oil pan
- heads for 408 build????
- 351 win
- 351 headers and intake
- 351 vs 429BB
- power estimates
- Transmission Swap
- Ford Torque Specs.
- The big swap
- Which 351 to use
- FastBlack is Back
- Newbie to the 351 scene
- Hows This Sound???
- MAC Performance 351w LT headers...
- changing heads
- performer rpms for 357??????
- 500rwhp na pump gas 408?
- FL414AA
- 357 combo advice.
- A Good 351 to get?
- fuel injcted 408?????
- IT LIVES
- D4 block
- Where to go from here..
- Cam choices
- Thermostat Needed???
- Need opinions for Winter Plans
- 351W bottom end
- what heads and intake for 351windor?
- injectors?>>>???
- to stroke or not to stroke that is the ?
- Z304 heads fit?
- 351w mustang Sway Bar
- 99 mustang engine swap
- 30lb. injectors
- 351w newb
- Need some extra tall valve covers for my Windsor
- AFR 185cc should I buy them?
- 351W Cooling fan question?
- Help! No Fire!
- swap ???
- before the power what about suspension?
- What is your setup N/A???
- intake help
- Flat top pistons with Heads
- good deal on 351?
- Edel RPM Combo H/C/I good deal?
- Is it possible?
- 1990 LX engine id???
- 351w and stroker varients times
