View Full Version : 351 Mustang
Pages : 1 2 3 4 [5] 6
  1. 351w fox
  2. starter "missing"
  3. SVO 351W "Sportsman"
  4. how do i make 302 hedas fit a 351w
  5. Carb size for 408 stroker
  6. questions about 351w
  7. 351/C4 TRANS
  8. Build or Buy a 408 Short-Block?
  9. 2 for 2 now! Msd distributor gear?
  10. Tremec
  11. 351 Block
  12. Used 351w Questions
  13. Some pics of my problem finally....
  14. twin turbo or supercharge
  15. over 500 hp to the wheels
  16. -->Turbo 351 c project!!!!<--
  17. 351 swap
  18. 351w efi intakes
  19. Got my wiring worked out!
  20. 5.8 idle problem
  21. '71 351C in a fox questions
  22. header ?
  23. carbs, intakes, and trannys oh my
  24. need to resolve part 2
  25. 351w setup
  26. 750 proform baseplate and mainbody...
  27. 289 mild build or 351w in a '67
  28. help in my lx 351
  29. WTF?! Help PLZ
  30. 4cyl to 5.8
  31. 351W swap in a 66
  32. cam selection
  33. Need some part #'s.....
  34. trick flow 3
  35. MAF meter selection
  36. anyone happen to know?
  37. need to resolve this before summer
  38. i want to drop a 351 in my 4 banger
  39. Wiring Problem-no temp, alt or oil pressure gauge readings
  40. long tubes
  41. 351W wiring nightmare... NEED HELP!
  42. a/c and power steering bracket.
  43. 351W header gaskets suck
  44. spotted 351 + some ?'s
  45. Mcleod Clutch disc shred to pieces/?
  46. 351w in my 83 startup (vid)
  47. Compression Question
  48. JEGS 351w Heads
  49. what vehicles
  50. 351W ticking noise
  51. Need power out of my 351w!!
  52. 351w
  53. 95 5.8 heads different from 5.0 heads?
  54. rearend
  55. 5.8 fox swap...header question
  56. I'm almost done!
  57. what is your base timing set at?
  58. approx. with s/c?
  59. 351W Distributor?
  60. d0oe + c9oe question
  61. 351 M
  62. 351M
  63. 351w buildup with Cleveland heads
  64. SN-95..302 or 351
  65. i've got one for ya
  66. Sparkplug leaking?
  67. 408 Build up
  68. What would be the best Intake for Me?
  69. 1999 351 mustang gt
  70. 351w vavle covers
  71. nitrous on a 351w?
  72. new motor
  73. supercharged 351w
  74. 351C In an 88 Gt conv?
  75. the 351w i got
  76. Need More Throttle!
  77. Another AFR head question
  78. when
  79. converting 302 to 351
  80. SN95 Headers
  81. AFR 185 question
  82. 351 Piston Choices
  83. Procomp 210cc Aluminum Heads
  84. i win
  85. 351w oilpan ?
  86. cleveland
  87. 351W stroking questions
  88. 351 cobra jet?
  89. 351c 4v Heads
  90. 351c weight?
  91. Old 351 W
  92. 351W Flywheel
  93. 351 Headers
  94. Spindle
  95. 350rwhp on 351W
  96. ac/power steering bracket
  97. Need help, i might get a 351 any day now!
  98. 351 Into a 99-04
  99. 302 to 351w swap problems
  100. camshaft help
  101. 351w how high?
  102. 1 of 201 made
  103. Should i switch to carb?!?!?
  104. fuel injection question
  105. 475hp on the engine dyno :)
  106. 351W MOTOR CAM HELP!!
  107. YES! Dual Quad intake for 351W is Comming!
  108. Build Ideas 351w
  109. 12.4:1 compression.
  110. 351 swap
  111. 9 sec runs with my 85/418W
  112. heads
  113. Flywheel???????
  114. Best 351 swap engine???
  115. 351 Swap question???help
  116. Few Question
  117. Carb to EFI conversion
  118. Need Help... Complete rebuild
  119. 351 dart 4.000 or 4.100?
  120. 1983 LX / 351HO
  121. cylinder head question
  122. Headers for 351w in sn95
  123. Im baaack, but with a 351 :D
  124. 351 to 408 in '69 convertible
  125. 351C install
  126. 5.0 H.O to 5.8w
  127. 427 is alive
  128. 351w
  129. 70 Mach 1 underdash wiring, need help fast
  130. 302 timing cover for 351w
  131. 351w UDP's
  132. 351w worth
  133. camshaft dowel pin
  134. 357W ready for blast
  135. hp?
  136. 351w lower intake
  137. compression ratio question and others
  138. Forged Internals
  139. 351 swap "how to?"
  140. Engine purchase help needed
  141. stock t5 from an 83 question.
  142. I've got the urge...
  143. 95 Gt to 351W
  144. my 351 came today!
  145. 408 bore size?
  146. 351 intake not seating fully
  147. Halfway thru 351W swap
  148. 351w swap in to 86 v6 mustang
  149. 351w
  150. 351 w vs c
  151. carbbed or efi?
  152. 351w bottom end on Ebay
  153. Canadian 351W's?
  154. Where'd it come from?
  155. Bracing the subframe
  156. 69-70 351W Heads vs. 87-93 302
  157. 393 and 600rwhp?
  158. First post!! Timing question...
  159. Yes, another cam question...
  160. Calculating compression ratio?
  161. putting 351w in a 95stang need Info.!
  162. Hood selection
  163. fuel system and a 351?
  164. 351 build
  165. ?'s on a 393 build
  166. Oil Filter
  167. 95 351W crank pully
  168. 351w build
  169. What Cam?
  170. Will a t-5 bolt up to a 351.........
  171. hp expectancy?
  172. 351 into an Edge Stang.
  173. 351W Block Weight
  174. 351W Block Weight
  175. 351 windsor
  176. 408 power?
  177. Identifying a 351W motor at a junkyard?
  178. silly question for all......
  179. 302 or 351 HO? Egads.
  180. The fun question
  181. 351W Donor List ??
  182. 351W EFI
  183. 408 stroked 351w--heads and compression
  184. 351w help
  185. 351w tuning
  186. Question On A Stock Tranny
  187. intake question
  188. 1970 mustang 351w heads onto 91 302 HO
  189. 351 EFI crate engine?
  190. 5.8l swap questions
  191. cleveland in a 2001 gt
  192. 351W -> 393 Stroker
  193. opinions bout the 351?
  194. 1984 351w?
  195. poor boys swap
  196. '90 351 EFI to Carb
  197. Help... info, links, anything!
  198. 351
  199. few questions about swapping
  200. price for a 351c block
  201. My 351, info please
  202. 94 351 in a 1987 GT
  203. 351 limits?
  204. 351 swap
  205. how much cost for a 351 swap
  206. how much cost for a 351 swap
  207. 5.8L Bronco
  208. Stock fox with a 351?
  209. Info on my 351 windsor
  210. 351Cleveland Swap into Fox Mustang, Whats involved?
  211. 351 swap
  212. Budget 408
  213. 351W Engine Factory
  214. how strong is the 351W block
  215. Oi! Cliffy got a Q
  216. 460 BBF
  217. post those pics!
  218. 351W timing cover bolts
  219. 351w swap
  220. 408 cam question
  221. 5.0 to 5.8 conversion
  222. 351 Qs
  223. 351windsor & 351 clevland
  224. 351w p/s bracket
  225. Fuel injected or Carbed??
  226. 393 combo... what do u think
  227. Difference between a 351w and a 351c
  228. Yet Another 351w ?...
  229. 351W vs. 351 Lightning series?
  230. need info on 351W heads.
  231. Good 351 block
  232. 5.0 to 5.8 swap
  233. 351w stroked - 408?
  234. Bought an '87 with a 351W...Have some Questions
  235. 351w into a '66, clearance issues?
  236. my car won't start
  237. where to find roller block 351
  238. 351 Clevland or Modified Question????
  239. swapping a 351 into a 96 gt
  240. 351 into a 99'?
  241. 5.8 liter 5.0? Who's done it
  242. 185s heads too much head for 351
  243. ford 351 changeout ???
  244. hood?
  245. clutch
  246. retrofit kit
  247. How to books
  248. Anyone looking for a big boy upgrade?
  249. big block fox
  250. 351 stroker
