View Full Version : 351 Mustang
Pages : [1] 2 3 4 5 6
  1. AFR cylinder heads
  2. 8.8" or 9" rearend for 351W build?
  3. 358W Compression
  4. could use some help
  5. GOTTA BIG QUESTION....
  6. 408 Stroker eventual build.
  7. 351 question
  8. Calling people with a supercharged 351 carbd
  9. 351W Build inputs... Pt. 2
  10. Questions about alum heads
  11. 393 build ideas?
  12. Nude girl holding camshaft inside
  13. Street Stall Converter
  14. GT40P Heads...
  15. 351windsor compared to 351cleveland
  16. What kind of cams are you guys running in your 408's???
  17. Hooker headers
  18. im idiot and cant find the classifieds
  19. what cam to use in a 351
  20. okay 351 help
  21. which rotating parts on a budget?
  22. where is the best place to get a long block 351
  23. Building a 408ci
  24. 351w shortblock weight?
  25. 351 help from the old dogs.
  26. how do i know if its a 351
  27. Internal vs. External balance
  28. 351w average temp with procharger?
  29. 351 Identification? Help ASAP!
  30. short block or long??
  31. DSS short block questions
  32. 302 efi to 351 carbed
  33. cant get car to crank
  34. whats these tags on my block
  35. 302 TO 351W HELP!
  36. questions on 351w shortblock swap
  37. 351w wondering if the pistons are cast or forged...i couldnt find out..thank you!
  38. 1986 351w engine specs. . . ?
  39. 94 351 block
  40. 351w stock rod strenght
  41. hood and intake requirement for 351w in 95 GT?
  42. 351w(393) daily driver??
  43. Downsides of a 427 build?
  44. 351w into a fox whats a good donor
  45. 1978 351w build
  46. 351W Build inputs...
  47. starting problems
  48. TF twisted wedge heads breathe enough?
  49. intake manifold
  50. 500 horse 351w build
  51. $1000 351 yes or no
  52. Rocker Arms
  53. Fuel Injected 393 stroker or Carb?
  54. A quick question.
  55. Which 351 Block should I buy
  56. suggestion for 351w build
  57. Fuel system for carb conversion
  58. New Edlebrock RPM XTREME 351W heads?
  59. Starting a Build Soon. Need All Advice
  60. starter relay blown I think
  61. 95 GT Motor Swap
  62. will Foxbody Long tubes fit in a 95?
  63. A few questions about a build I want to start soon
  64. computer for a 95 mustang w/393 stroker???
  65. 1971 351w block vs 1994 351w block??
  66. 1992 lx 351w to 408 stroker problems
  67. problem....going on 2+ years.....HELP!!
  68. problems with my motor
  69. CR versus HP
  70. 2.3l EFI to 351M Carb swap
  71. dart versus World Products
  72. 3in straight pipes on 351W
  73. swap headers
  74. 393 stroker true dual exhaust???
  75. need help with a vibration
  76. 393 in a new mustang
  77. Hello
  78. 427w: where do i find this motor
  79. 302efi to 351 carb conversion
  80. 351W shuts down
  81. 427 build(finnally got the motor back)
  82. best flowing long tubes for 351w
  83. oil pressure problem
  84. EFI 393 throttle body size question
  85. 351 oil pan
  86. looking for short/longblock
  87. Hey guys
  88. My new build. What ya think?
  89. First 351
  90. need some advice !
  91. What can it handle??
  92. stock replacement valve springs???
  93. same question, new motor choice
  94. what would you do?
  95. possible 5.8 swap
  96. Budget Rebuild/Road Coarse Engine
  97. flywheel on 351
  98. 393w Transmission
  99. 393 Stroker Ran 11.11 at 120MPH,need combo help..
  100. 351w long tube headers on gt-40p
  101. Blown 351w versus 408 N/A
  102. "Ford Pro-Billet Distributor" for a 351W efi, 94 and up reviews?
  103. just a few swap and buildup questions
  104. New to 351W and have one question.
  105. Lifters for 1969 Mustang with 351W
  106. 351w tapping
  107. stock timing for 351w?
  108. year of the block matter?
  109. drive gears?
  110. looking for parts
  111. here's a new one for ya'll
  112. What gear ratio?
  113. List of what I need for swap. Help please.
  114. 400 hp with gt-40 heads
  115. 351 tuning problems
  116. need info
  117. Anyone want to guess what hp I'm making?
  118. 351w with C4?
  119. 408w turbo
  120. Push rods seem loose. Maybe I'm crazy?
  121. no budget 351
  122. Might buy a mustang with a 351 swapped in
  123. 351m...
  124. 351w information help
  125. which trans?
  126. what carb cfm's to run?
  127. 351 windser engine performace help!!
  128. Carburated? efi?
  129. Intakes?
  130. good starting point
  131. How Do I measure valves?
  132. Good 351w supercharger?
  133. boss 351
  134. Top End Power Packages....
  135. Cheap Heads
  136. What is a reasonable price for a 351?
  137. Picking out valvetrain
  138. What tunner and wideband are you guys running?
  139. Brakes...
  140. Need a head/intake combo for my shortblock
  141. complete suspension overhaul.
  142. 2.3l to 5.8
  143. 4cylinder auto to 351W 5 speed conversion
  144. dizzy problem
  145. Anyone want to guess what hp I'm making?
  146. Which front end setup?
  147. 351 for this winter...ideas?
  148. 351 oil pan
  149. 351 what to do with it
  150. 351 swap questions
  151. Different 351s?
  152. Fuel pumps
  153. 351w tear down problems
  154. .340 lift camshaft??
  155. Pulled engine apart
  156. u guys remind of ls1 owners
  157. u all do drive 13 sec cars thats cool
  158. Ignition question
  159. Header Install Question
  160. 351w Head Gasket help
  161. nobody has a fast car
  162. lots of carb questions
  163. anybody with a 10 sec setup
  164. anybody with 418 with 225afr
  165. New to 351w's
  166. Stock 94+ 351w Specs
  167. 351W EFI Camshaft?
  168. 84 351W Flywheel Swap?
  169. 351w EFI/ Supercharger?
  170. Are these heads any good?
  171. SN-95 stock hood clearance with a 351W
  172. HELP! 351w Back Fired and shut down!!!!!!! Help!!!
  173. 351w PISTON ???
  174. 351w oil pan
  175. Kenne Bell Questions
  176. 351 Distributor
  177. 351W engine positioning...
  178. Motor build question.
  179. longtubes on a 351
  180. 289 heads on a 351?
  181. timing cover question
  182. What's your favorite 351 long tube
  183. 351 bored 30 over = 408??
  184. 351 bored 30 over = 408??
  185. what is this car worth?
  186. 1986 351HO block questions
  187. starter solenoid won't disengage
  188. any one ever heard of or seen these RPM MAXX blocks?
  189. manual steering rack
  190. thoughts on K-members
  191. 351 block ?
  192. What should I expect
  193. new to 351's
  194. Rebuilt t5 behind a semi built 351.. Opinions?
  195. How difficult is dropping a 427 into a 88 foxbody
  196. 351M
  197. 26 spline transmission
  198. 351c? or 460?
  199. 351 in a 95 model
  200. lowering springs
  201. how to make 427ci
  202. who makes shorty 1 3/4 swap headers?
  203. 351w swap into 87-93
  204. Pulley
  205. brake caliper's?
  206. 69 351 stoker options
  207. rockers
  208. cam
  209. GT-40 Lower intake
  210. head selection
  211. 5.8 crankshaft
  212. 351w build
  213. installing 351w in 94 mustang
  214. 351 393 408
  215. police interceptor heads???
  216. transmission 4 351w
  217. 351 w
  218. 347 vs 408/428
  219. HP guess
  220. Alternator?????
  221. Rear suspention setup opinions
  222. cam suggestions?
  223. Block Main Webbing Discussion
  224. 351 4 bolt main
  225. throttle body, injectors?
  226. need help with roller explanation
  227. Here are the pics...
  228. 351 build questions
  229. porting stock heads
  230. Need your HELP ASAP...
  231. 351w 4bbl
  232. 351w HP question
  233. An old KARKRAFT issue???j/y 351
  234. older 392 crate engine specs.
  235. Carb to fuel injected???
  236. adding a bottle
  237. Stock 302 Headers
  238. Can I call someone? lol
  239. 351w crate sites?
  240. Largest Bore (Safely)
  241. 351C 2V High rise manifold question
  242. 351W and AFR 185 heads
  243. what are the chances?
  244. .875 solid roller lifters
  245. trying to figure out
  246. 1974 351W with 302 crank and rods???
  247. buying 408w stroker kit... where?
  248. a couple top end questions
  249. cam size?
  250. need suggestions!
