View Full Version : General Tech
- tell me what you 96-98 cobra owners think
- What's wrong with my car? please help
- 1966
- Rusting and Subframe Connectors...
- 2" Drop
- RPM-Air Gap 351-W or Performer RPM 351-W
- Which cold air intake?
- What is detonation?
- Swap Throttle bodies?
- speedo/odo not responding
- monster tach installion
- Removing dents?
- DOORS
- [Deleted]
- Fuctional Side Scoops (Brake Cooling)
- Eaton Differential
- i need an opinion(as many as possible
- Alum. Flywheel on Daily Driver
- Clutch Installation!!
- Cobra 2?
- how to tell witch gears
- FMS's new gears?
- I need HP
- got another question
- Tip's on chaging my sprak plugs (NEED HELP PLEASE)
- What kind of ignition box?
- Slight hesitation...
- Do Long Tubes lose low end torque?
- How to stop body flex in 2003 GT
- Dating my motor..:)
- Intake Manifolds
- Engine Swap Help!!
- Engine swap trouble - Please help!!
- NEED HELP- ROAD RACING QUES. ABOUT EXHAUST
- Bullitt Suspension
- help choosing year to buy
- how much time
- Help!!! T45 Issue
- V-8 Conversion???
- Air/fuel gauge?
- Odometer/tripometer stopped
- MOVED: Show me your stang
- Power Windows
- Wheels and Tires
- aftermarket heads
- a few fun questions
- Steeda setup
- Need to get some HP
- HELP! Throttle problems???
- suspension ideas
- New engine
- x-pipe or h-pipe
- timing on a tfi-iv 4cyl how to
- cobra question
- 93 COBRA Question
- which engine should i get
- Windsor Jr.
- Cam selection
- Intake Manifold gaskets
- Traction Without Losing handling
- Sub frames
- heads swap on 98 gt
- need help deciding
- gas mileage?
- line locks???
- Brakes for a 94 GT
- which tires??
- MSD Digital 6 plus
- any do P&P PI heads on 96 romeo block?
- Crown Victoria Flowmasters and Volvo
- Carb'd Conversion
- Street suspension rebuild for an '85
- demon
- Don't neglect your fuel filter!
- opinions from EVERYBODY on the forum
- 1997 Mustang, broken rear power window
- Help...
- Anyone know the official 2005 release date?
- TREMEC TRANNYS
- want new wires and plugs want the best combo please help
- New Gears, nos, suggestions?
- Convertible top leaking?
- Still idling hot
- first mod
- Lakewood Bllhousing/K-Member Brace Problem
- K&N air filters
- TransGo shift kit question...
- Free pep for your Mustang!!!
- Need some info?
- is squeaking suspension normal on mustangs?
- Skipping Gears
- K&N's claim
- speaking of engines
- the gifts of life
- transmission squeaks
- Boyfriends MR2 Turbo...
- No tailights or guages
- Burn out
- new gear ?
- Supercharger vs. Turbo?
- gt vs. v6 conversion
- whats that whinning?
- I'm addicted...
- Help - thinking about purchasing a used Mustang
- engine brand?
- '01 gt a/c probs every year dealership giving me probs.
- water leaking?
- Door Handles
- What's that noise?
- 302 Engine bored .40 over... to much??
- engines?
- Electric Fan Q
- good proformance manufacture
- Exhaust size & Brand for '87 GT
- Please Help
- info on radiator reservoir 2000 mustang
- 87 gt o2 sensors
- Need help, hard getting into 3rd gear.
- I saw a wierd setup on a mustang....
- 86 electric problems
- stangparts.com reliable?
- are theses rims for real....
- any recommedations?
- Straight pipes?
- 3.8L Headers?
- Help, this isn't supposed to be hanging is it?
- Nitrous
- speed limiter is driving me crazy
- Formulae
- Thirsty Pony
- Mufflers
- hey i'm a new member needing some advice
- 2004, 2003, 2002 Mustang different?
- Trouble shifting gears
- [Deleted]
- short circuit - no power in my car
- CAI with less bends
- O-Ringed heads
- Power window problems???
- ELECTRIC FUEL PUMPS ,,CARBED ONLY
- water wetter
- Impending 94 V6 upgrade
- Door Hinge problem?
- Driveshaft
- 94 Mustang dead spot
- Battery Question
- Cobra or GT?
- Mechanic in Central FL
- internal engine build-up 4.6L
- crank pulley and idle
- Newbee with tire question
- Cooling Issues
- 1968 conv. squeaky / popping suspension
- mod guestions
- Cerevinies Ram Air Hood Kit
- t/b and plenum addition help
- Squealing sound
- GT Guages in V6
- This is how you disable the seatbelt reminder on your Ford:
- Mustang club FREE w/sponsors
- Problem with brakes?
- gear selections
- Tremec short throw or UPR
- Shift Kit VS. Diablo Predator Tuner
- rear shock tower brace
- Fox Tire Width
- Takin' up the slack in the throttle cable?
- Drag radials need them! help!
- Ive got a timing question Too?
- 99 mustang cobra oil question
- Will these wheels fit?
- filler neck grommet
- Timing....Help!!!
- Pulley Install
- opinions on steeda parts
- computer thing for a mustang?
- powder coated headers
- CAI question...
- backfires when i shift
- Did the 1966 GT come with automatic
- how much work would it be to throw a manual in a stang?
- 3.73 for a 289?
- WHO IS RUNNING THEIR CAI W/O THE MAF SCREEN?
- kill switch
- Stock RWHP/Torque
- short or long headers?
- Waz up
- Electrical question...alternator or voltage regulator?
- Car Dyno'd Drivetrain Loss Q?
- Transmission Issues!!!!!
- fuel injector cleaner
- Another Pulley Question...
- do i need casters
- 252 rwhp stock
- Basic mod help.
- Basic suspension mods
- remote kill switch
- What Carb to get
- BUILDING ANOTHER STROKER
- Stall converter???
- What does a 8.9 1/8 transfer into in the 1/4?
- Torque Converter
- supercharger help please
- running like ****
- Late model GT with Auto: Does your tranny clunk when you do this...
- 1994 manual trans
- [Deleted]
- Called about an LX
- 408 stroker
- What is the diff b/t types of superchargers
- Might buy a 5.0, but want Camaro. help
- still no luck
- Hey gear heads need your opinion!
- rear end question
- Mr. Clean Autodry
- help with vibration ***problem solved***
- tapping noise from front wheels????
- Best Oil & oil type for your Pony
- Your diagnosis please?
- help with add ons please
- MOVED: Loudest Exaust
- BBK's Installed
- my dyno sheet...
- Im too high up on 20s
- Need some suggestions
- oh my interior is a lil bit cooler now...
- IRS & A/T
- U guys remember purple hornies?
- Bored over
- Rear popping noise
- top loader 4 speed?
- stuff to look for
- spinning tires??
- Timing, Mods, & Year
- 96 rim specs
- Ooohhh Junk, just got the pulleys in
- any one using SSBC extreme brakes on a 65?
- headers
- alarm system
- 289 efi?
- i found another stang???
- cleveland question
- How detectable?????
- TRANSMISSION SWAP?!? OR NEW PONY?!?
- help me guys.
- exhaust
- Mustang Generations
- What struts should i get?
- Timing adjustment
- I am a little Confused
