- oil pan drop
- MOVED: Xpipe?
- Brake replacement
- Driveshaft rubbing
- wheel size & lowering
- ordered gears and shifter..
- thinking of buying a Mach 1
- Pro 5.0 shifter
- Speed Sensor/gear swap
- Wiring/computer for 2.3 to 5.0 swap
- Anyone used one of these lowering kits?
- need mod advice
- Should I change weight?
- maf worth it?
- is it possible to change an automatic to a manual transmission
- MOVED: wireing for 68
- Steering wheel shake
- patriot performance heads?
- 1995 Mustang Gt converible window sticker?
- HELP
- instrument cluster lense
- Idle Rpm
- Transmission
- 2002 mustang 3rd gear sticking...
- How many quarts of tranny fluid does a t-56 need?
- Auto trans: Leave it in D or N while waiting at a stop light?
- Window slightly off track? NEED HELP.
- clutch pedal hard to push in
- 89 2.3 mustang running rich
- Dunlops....
- Really Dumb Question: Let's stress the "dumb"
- Porting?
- MOVED: nitrous for 95 5.0
- Guys, NOT GOOD
- Help - How Can I go FAST !!!
- 1994 GT quad Shocks
- DUE TO EXPENSIVE FUEL COSTS
- 1970 mach1 428 cobra jet
- Ram Air w/stock Scoop
- input on SpiralMax
- shipping?
- smooth ride
- Can i fit a 5.4l long block in my stang?
- looking for a tire/rim expert
- Tire Size?
- need opinion on KYB
- is this what I"m lookin for?
- Speedo is off. help?
- stupid question
- temp gauge pegging instantly
- Do chips work?
- Steering wheel swap
- Can anyone help me!?
- How can I improve the brakes on my 04 GT?
- Ford fastener reference book?
- New alternator on a 90 GT
- does anyone...know...mach1 recalls?
- 1320 times for most cars/compare
- Anyone know of a shop near St. Louis?
- Is there really any reason?
- 99 cobra sale
- Upper Radiator hose
- Anyone use the SpiralMax??
- Jacobs ignition
- question about seat weight
- steeda upper and lower control arms
- Traction Control Indicator
- flame on
- 95 Mustang GT convertable...what is the widest tire i can get
- Have a question about Seats
- MOVED: New Car?
- coil or distributor
- 13'S
- installing the C&L inlet pipe
- valve piston cleareance
- Ball Joint
- 97 cobra stock hp?
- Rear end blow out
- difference between 86lx rotors and 87gt rotors
- haneline kit on 67 stang
- TELEFLEX HANELINE DOES NOT WORK
- revs jump
- Help plz
- head light switch
- problems with p.i. heads
- brake rotors too big
- sn95 slick sizes
- seats
- Time for a New Clutch Any good ones out there
- noises at air filter housing
- gas peddle/dead peddle-install
- Plugged exhaust, but read clues wrong!
- Throttle body
- Need some input
- headers
- Engine Swap
- Water Pump is Weeping Like Crazy
- Speedo cluster question
- Idle sucks after coming off highway!
- original springs Sizes
- engine dies
- cobra lowering springs
- I want help with Installing the Original Springs
- Tranny help ASAP!
- Eibach Sport Line...Opinions Needed
- my cars history
- Free/Cheap mods
- lol and I thought that I made up my mind
- [Deleted]
- will this do 12's?
- want to drop it
- what size torx bolt on rear shocks?
- cobra stance
- ABS/Traction Control Get it or Not?
- speedo
- What is the OD gear ratio in an AOD
- 351 Windsor headers
- cut out exhaust
- Coolant light stays on all the time
- 289 heads decoded?
- Just started getting a Pop under Little throttle
- What's the purpose of the loop on the backrest that holds the seatbelt?
- 87 or 91 octane for the GT?
- After accident/ Caster/Camber kit one side?
- gears and shifter
- 92 octane recommended??
- What are the guidelines for driving a new car?
- Staring Problem HELP ME !!!!!
- Python Mustangs???
- air ride
- Cars won't start when it's hot???
- flamethrowers
- Interior electircal problems
- what type of chip?
- Lowerd 03 cobra
- Quad stock setup
- Gas Question
- LT Headers & O2 Sensors
- Gear Install
- WIDER TIRES MEANS MORE TORQUE TO THE GROUND RIGHT?
- mass air
- Fuel Pump constantly running
- Tremec
- Bassani Headers or long tube?
- ne one with good suspension site
- 92 vert question
- Hp on a 93 mustang
- Polishing rims?
- Bad Batt. or Alt.?
- 98GT Front End Accident, Loose above 55mph
- Convertable Top
- 17x10.5 rims
- 90 GT Bolt Pattern?
- Steeda Short Throw
- Progressive or Specific?
- Auto Cross
- fuel or electrical?
- Jet Hot question
- If it is not one thing, it's another
- what do bad rotors look like?
- conversion kits
- Speedo fix after gear change, Help!
- need help with NHRA rules
- Disabling the airbag light?
- runnin lean questions????!!
- takin out rear seats?
- Have a rear end Question
- 5.0 GT auto transmission problem
- Everyones opinions please??????
- Torque Converters
- Anyone ever take their HORN BUTTON off before?
- remote thingy costs $85.00 through ford
- conversion...?
- Strongest gears and setup for my T5 to make it strong.
- 02 sensors
- Will a 94-95 T5 Cobra tranny work with a V6 of the same year?
- BW T5: Was this tranny rebuilt with performance parts?
- what kind of gas and coolant for '99 mustang gt
- Help
- Old Front End Parts
- C&L MAF installed!
- WHAT VERSION?
- Reverse lights on at all times
- Tokico Shocks....springs help...
- High Powered Coil's Question
- car not starting
- Electronic key/alarm thingy won't work(???)
- Remote Thingy Won't Work
- stupid brake ? i think
- Rotor Plating
- Cig lighter outlet not working...
- Bullitt Suspension
- Other Mustang sites...
- urethane isolators
- smog pump removal question
- My 86gt under my knife...lol
- pulley opinions? does the brand matter?
- Squeeky Front End
- Fiberglass Doors
- ****in t-56
- Wierd issues: battery light comes on at 2500 RPM
- injector size
- Ford power drum brakes
- can someone run a carfax for me?
- Performance on a 93 mustang gt
- Distributor Installation
- 460 + supercharger
- Intake manifold change? Advantages?
- Shift Kit?
- Suspension for getting traction... Help???
- Slack in clutch pedal
- Slowly learning...
- next suspension mod...............
- [Deleted]
- What's does this extra smog control stuff do?
- master bearing kit necessary?
- question about rim fitment...
- need help with block ID.
- [Deleted]
- need 12 second runs
- my 428 Eng
- Fuel Pressure Setting??
- whats a better mod?
- Install cost?
- C&L install
- going to look at a stang
- 302 Stroker kit
- Adjustable Shocks vs Lowering Springs
- oh hell no....
- HELP: Front end makes a thud when I turn and creeks
- [Deleted]
- Short throw shifter.
- What Next?
- Door Moldings
- Headlight alignment
- Car dies around slow cornering????
- What next?
- Help with car
- Flycutting pistons info
- Dynos in central VA
- Need Help
- Battery Relocation Kit
- What pipes to get?
- odometer busted
- GTech
- weird "super charger"
- A/C and Heating question
- lookin for someone who had been in a wreck
- Ignition and Distributor
- CAI or just Filter?
