View Full Version : 4 Cylinder NA and Turbo
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14
  1. NPR intercooler install
  2. rear drum
  3. Car burning oil why?
  4. Coolant Temp Sensor Location?
  5. Delete this thread
  6. 2.3 throttle body ??s
  7. Need help on switching my 2.3 to a Carb 5.0
  8. electical issues (i think)
  9. Which Engine: Mercury Capri RS or Thunderbird TC
  10. brake proportioning valve.
  11. n/a cam??
  12. EGR VALVE BLOCK WARNING!!!!
  13. need help!!!!!!!!!
  14. Updates for "No Hands?"
  15. Re my doing Suspension
  16. Boost Spiking Issue
  17. T-5 Steel Bearing Retainer?
  18. will a 5.0 radiator fit in a 2.3?
  19. 2.3 mysteriously missfires.
  20. oil covered ignition coil
  21. replace steering rack?
  22. Newbie here with a problem. Fuel Mileage sucks.
  23. na turbo 2.3l cutting out
  24. the ecm i have
  25. Speedometer gear
  26. f/s na 2.3 engine and 5 speed tranny
  27. Fords we did not get in USA
  28. need advice
  29. 89turbo lives again.
  30. Manual to Auto Tranny Swap
  31. 2.0 block?????
  32. A4LD Rebuild
  33. Fixing code reader plug?
  34. Intercooler size?
  35. How Much Air Is Too Much Air?
  36. not throwing spark out
  37. no oil pressure at idle only?
  38. Code 114...
  39. Svo Not Starting.
  40. Need your help guys
  41. intercooler options for 2.3t
  42. Friction or not?
  43. 1990 Mustang 2.3 Charging Problems
  44. Manual Pedals
  45. Automatic Transmission Modulator
  46. A few pics of my 89Coupe project car.
  47. Am I crazy?
  48. 84 SVO T-5 Info???
  49. fu*k me!!
  50. ??
  51. 140 Spedo...?
  52. Interior
  53. whining noise from tranny
  54. t5 swap back up harness help
  55. KYB Strut Question..
  56. What are the DIFFERENCES between an 87 LX 2.3L EFI & 87 LX 5.0L EFI from the factory?
  57. dualspark ignition control module question
  58. drive shaft question
  59. driveshaft problem v8 or 4cyl
  60. t-3 to t3/t4 hybrid conversion
  61. Catalytic convertor
  62. HELP fast! Tryin to finish trans swap today
  63. Vacuum
  64. Help! No Brake Lights!
  65. New Guy
  66. everyone please help with this im new
  67. Engine running rough
  68. valve cover gasket
  69. My $5.99 turbo heat shield.
  70. t5 rebuild problem :(
  71. automatic tranny question need some help here
  72. What transmissions will fit the 2.3
  73. {PICS} Building a 24 hours of lemons cars (1992 4 cyl LX)
  74. Not starting in cold
  75. Cam problem
  76. fuseable links
  77. 93 Mustang Tachometer and Check Engine issue
  78. Need suggestions on parts.
  79. keeps burning fuseable links please read
  80. EDF electro drive fan need definition please
  81. fuel line??
  82. 1989 2.3 won't start in the cold! :(
  83. I finally got an SVO!!
  84. Trans shifting ok?
  85. Electrical Question
  86. what year did the fule pump relay go to the black box
  87. Engine trouble
  88. Fuel Pump Relay, AGAIN!
  89. ill ask the token tard question
  90. How much can it take safely??
  91. Brake Upgrade
  92. A few questions...
  93. cheapest way to turbo my 2.3
  94. 1989 Calibraion code needed
  95. clutch lever boot question
  96. Driver Door Window Tech
  97. posi unit out of 85 gt into a 93 7.5 rear?
  98. last t5 swap question, promise lol
  99. Maximum Motorsports clutch cable
  100. 2.3 clutch cable help
  101. t5 swap problem with parts.....
  102. will this shifter work?
  103. will this driveshaft work?
  104. Engine Teardown
  105. Cruise Control ????
  106. How to replace FPR (fuel pressure regulator)
  107. PCV Valve HELP
  108. car sitting-- no power at all, battery fine
  109. surge at full throttle
  110. FPR
  111. Problems to fix before winter
  112. help with a 1992 4cyl exhaust
  113. 87 mustang 2.3 motor mounts
  114. Drag Times
  115. manually shifting an automatic
  116. 79 Pace car pics
  117. Still Running Cold!
  118. Transmission Questions
  119. Sold my Mustang.... BUYING A SVO!!!!
  120. Just picked up a 79 Pace car.
  121. Car just died.. :(
  122. 87 Mustang Throttle body
  123. tv cable on 93 question
  124. Car had didnt start in the morning but did in the afternoon???
  125. Starting the mustang
  126. play in axle
  127. won't drop into passing gear
  128. 93lx how is the t.v. cable supposed to be at closed throttle
  129. Multitude of Check Engine Codes: What Should I do/Focus on?
  130. How to do a compression test
  131. The ultimate donor car for a turbo swap!!
  132. Tired 2.3L
  133. My odd ball transmission problem
  134. oxygen sensor
  135. racerwalsh big bore 65mm t.b. is really a 94-95 5.0 mustang t.b!!!!!
  136. brown top turbo coupe injector questions
  137. NEW TO THE 2.3L SECTION, NEW CAR
  138. Public Service Announcement
  139. cam question
  140. Oil Pressure Gauge Drops Below Zero Randomly
  141. Engine noise found but not solved yet.
  142. 93 LX 4 cylinder
  143. fuel pump
  144. whats the best automatic for a 2.3?
  145. mustang problems help
  146. Trans problem
  147. exhaust! i finally got it
  148. 2.3 guys help me out
  149. what would it take for 12's?
  150. 2.3 turbo into a Ranger
  151. Cant fix in a week its being SOLD.
  152. 2.3 t swap
  153. Found 2.3l pcm and harness.. whats it worth?
  154. TurboCoupe wont start
  155. mustang vrs srt 4
  156. how do you set the timing on a 88 2.3l
  157. Help?? Can't find were to get new one's
  158. throttle body question
  159. injectors
  160. No 2.3 for my bro...
  161. Teach me about turbo please
  162. anyone turbo a n/a engine?
  163. brakes "popping"
  164. ditching ps pump-also 88 AOD
  165. Sea foam
  166. How to swap in a manaul T5 transmission
  167. CAR trouble
  168. 4cyclinder dohc turbo vovlo motor in a fox??
  169. Pulling my hair out PLEASE HELP!!!!!!!!!!
  170. Check engine light...
  171. goin turbo
  172. Setting the timing/ checking it
  173. coil pack questions
  174. Tach wire
  175. Fox coil spring install tutorial
  176. Hazard light/amber crazyness?
  177. exhaust
  178. c4 mpg?
  179. t5 trans question
  180. compression test results
  181. horn
  182. 302 or 460 swap????
  183. Converting to aftermarket ignition. What's involved?
  184. probe intercooler
  185. is the automatic transmission out of a 1990 mustang LX strong enough?
  186. 2.3 for my bro
  187. Steering
  188. Your thoughts in NO2
  189. Wiring info needed
  190. Cut Springs..
  191. 2.3 missing and losing power. Please help me!
  192. 92 convert quarter window
  193. Project Resurection
  194. single or twin turbo?
  195. EGR and O2/Cat Issues
  196. Stiff Suspension?
  197. GT Headlight Switch=No Headlights
  198. Car computer code questions
  199. Might be getting an SVO
  200. what year ranger roller cam?
  201. Clean 2.3T stang. 11's
  202. need tach and hood release handle
  203. A few problems with my stang need help
  204. 2.3 turbo vrs vette
  205. 2.3 non turbo --> accelerates poorly
  206. NEED HELP ASAP!!!!
  207. 92 2.3l not shifting
  208. help on body work?
  209. please help
  210. Downtube bolt sizes!!?!?!?
  211. dyno
  212. 93 4cyl to 5.0 - final list
  213. the shakes
  214. gears
  215. Fuel Pressure Problem
  216. good and bad
  217. Front Rotors
  218. Combustion Chamber Size
  219. 89 2.3 turbo feels soooo slow HELP!!!
  220. Friends of Hellion_79
  221. somebody help me!
  222. pos mustang...
  223. 4cyl turbo in a 85 ranger, is it possible?
  224. fuel floats
  225. valve springs???
  226. Brakes/Bearings help
  227. Very strange idle problem
  228. engine codes need help
  229. New here was told this was where to ask
  230. Brake Booster?
  231. fuel pump questions
  232. heads?
  233. 4cyl question
  234. Central California Mustangs
  235. 5spd Transmission Mount - Rotted
  236. tranny probs..
  237. HLA (Hydraulic Lash Adjuster)
  238. Anyone think ill have a problem running this setup with 10's in the back
  239. positive cable end turning black
  240. Tuckin 8" RIms
  241. 2.3 c4 swap help
  242. Speed/Odometer Hookup???
  243. Wooooooooooooow!!!!!!!!!
  244. best aftermarket turbo.
  245. Turbo questions?
  246. omfg
  247. 12's
  248. Gonna build an engine on forum opinion!!!!
  249. unassisted brake problem
  250. Advise on a 2.3t Swap
