View Full Version : 4 Cylinder NA and Turbo
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14
  1. oil pressure
  2. Transmission Identification
  3. Fuel Gauge
  4. Flywheel balancing
  5. 79 turbo wastegate lines
  6. oil cooler
  7. vin decoder?
  8. trans fluid
  9. Another No Starting Stang..any ideas? UPDATE 2
  10. HELP! cars not starting
  11. Engine choice?
  12. timing belt
  13. Car wouldnt start,so i removed the maf sensor and wala it turned on
  14. can some get there hands on the metal bar that protects the undercarige???
  15. Transmission Issues
  16. backfiring and spitting at 3000 rpm
  17. Transmission problem, looking for help
  18. Still no boost
  19. Looking for a good sounding cheap exhaust ,will this work?
  20. turbo motor?
  21. injector size?
  22. 2.3 LX Fender Question
  23. help! tach needle spiked now it idles at 350 (problem solved)
  24. Radiator size
  25. changing timing belt
  26. turbo problem
  27. factory tach?
  28. Hyd Boost on 2.3?
  29. It's good to meet new people
  30. Please help quickly! Pin dimensions
  31. 88 T bird blow off valve
  32. Help! DISMAL milage!
  33. oil pan
  34. Can't drive at constant speed
  35. 4 cylinder 2.3L turbo help
  36. Ranger Rollers?
  37. Stock 2.3L looking for turbo...!?!???
  38. HELP! Tranny Modulator Issues.
  39. Update
  40. 16x8 Cobra R's on a 86 2.3L Mustang
  41. super charged turbo?
  42. iac and egr
  43. Oil Return line
  44. looking to buy a 2.3 fox
  45. need a little help; 92 na lx tach
  46. 2.3 turbo video
  47. exhaust problem
  48. No Boost
  49. Mostly torndown garett T3 (.48/.60) turbo (56K WARNING!)
  50. How To: Repin your harness
  51. The Need for a Computer?!?!
  52. block heater?
  53. Trans problem?
  54. Strange Idle Problem
  55. Found a part rolling around. What is it?
  56. 88 2.3t in 79-86
  57. Replacing stock gauges with Digital ones
  58. boost gauge HELP
  59. Tuner for 2.3's?
  60. Parts Car
  61. Another Spring ?
  62. 92 lx problems...
  63. Up-Date on Project 66 Mustang/SVO 2.3 Turbo
  64. 46# injectors
  65. Turbo Rebuild Crisis !HELP!
  66. Idle Problems
  67. dont flame! What kind of oil you guys running ?
  68. help needed with a4ld wiring questions
  69. keep blowing rear main seal
  70. Turbo talk (beating a dead horse!)
  71. 86 2.3 na oil pressure
  72. questions regarding 92LX Turbo swap
  73. My turbo pony Runs
  74. rearend
  75. AC robbing engine power
  76. 86 4 cyl carb
  77. new 1990 mustang lx questions
  78. how to hook up the cooling fan to with a on/off switch?
  79. shifter knob
  80. 65mm throttle body
  81. rear axle?
  82. Ebrake Handle
  83. Help to fix a Hack and Slash Head Unit Install :(
  84. Ouch
  85. Project Smoking Stang
  86. I need your help PLZ
  87. 2.3 Crank Strength
  88. 2.3 Crank Strength
  89. n/a 2.3 ignition questions
  90. still cam ?'s
  91. 1986 Stang-smoking need help
  92. Door Handles
  93. EEC Codes
  94. exhuast
  95. AC help
  96. Update on my ride, 3" exhaust, FMIC and questions.
  97. Need help on a 93 lx. thank you
  98. Ebrake cable length
  99. 93 2.2 trans change
  100. pix of the 93 lx for sale!!!
  101. Coolant Temp
  102. mint 93 mustang 4 sale 44kmiles!!!
  103. bad alternator
  104. 2.3L Transplant Question
  105. ranger transmission
  106. cam timing
  107. Need help with turboing
  108. 79-86 turbo swap?
  109. what year came with D port head
  110. New to the 4cyl world... help
  111. tranny question
  112. Boost and Idle probs
  113. hugee!!! leak!!!!
  114. Turbo Coupe Rear Rotor and Pad Options
  115. Searching Idle and Stumbles On Acceleration In Boost
  116. 1989 MUSTANG LX 2.3
  117. What BPV?
  118. codes
  119. throttle issues.
  120. Lowering the car
  121. Engine noises
  122. 2.3t Hatch Now Underway
  123. Replacing the A4LD Vacuum Modulator
  124. Steering wheel
  125. fender, door, and rear question!
  126. SVO parts
  127. dual plug head?
  128. Video: why wont she crank??
  129. turbo power
  130. well on my way out
  131. What sensors or Lines go here?!?!?!?!?!?!?!
  132. intake ??s
  133. Drinks Gas
  134. 4 cyl troubles
  135. Top removal???
  136. door removal???
  137. 90 Mustang lx convertible????????
  138. taking out console?
  139. Possible wiring problem???
  140. Weird Question....
  141. HP
  142. Stuck Valve?
  143. Front 11" brakes
  144. looknig at buying a 4cylinder stang
  145. '92 4cyl into'89 4cyl car need wiring help!
  146. Gas in my cam!
  147. 2.3l turbo
  148. 92 mustang 2.3 swap with 350 engine
  149. 2.3l n/a vs 2.3l turbo
  150. 2.3 carb to fuel injection help
  151. 2.3l help
  152. fire damage
  153. 2.3 in a Sn-95
  154. New pics... Figured id give my fellow 4 bangers some love
  155. T3/T4 Manifold
  156. Random RPM drop
  157. A4LD help different plugs for OD!!
  158. Changing my mind...
  159. Finally
  160. 2.3T wiring harness!
  161. dead cylinder in 2.3T
  162. transaxle ford 2.3
  163. Need a stock exaust elbow
  164. Electrical help.
  165. NO oil
  166. Timing Belt Tensioner
  167. Question
  168. Where can I get...
  169. Should I Or not?
  170. na piston
  171. i need help alinigning my timing belt!!!!
  172. 1992 Ford Ranger Stalling
  173. 2.3 turbo project is underway
  174. wnated
  175. need a little help with a part...
  176. Project Grim Sleeper
  177. turbo
  178. camshaft
  179. dyno results PICS!!!
  180. price of a 4
  181. why wont my doors lock?
  182. Paint Scheme
  183. what is a distributor gear?
  184. i need more horsepower in my 2.3
  185. Codes 223, 224 and 543 on new Project car :)
  186. a quick fix question
  187. i have some problems!!!
  188. anyone live close to arlington washington?
  189. does anyone know where i can get a cheap 5.0 engine?
  190. I GOT MY 2.3 turbo!!!!!
  191. can anybody help with a distributor problem
  192. HELP, LOST OVERDRIVE
  193. to much for doors?
  194. audio codes?
  195. block?
  196. Auto Turbo?
  197. Turbo Rebuild to T3/T4 Hybrid
  198. engine trouble codes
  199. 2.3 Finally Died
  200. Intercooler
  201. timing...
  202. OVERBOOST
  203. stock t3 psi
  204. timing pulley
  205. My brothers car needs help!
  206. Tring to guess what year this mustangs is!
  207. Intercooler Setup
  208. rear end
  209. harmonic balancer?
  210. calculating compression
  211. PERFORMANCE
  212. clutch issue
  213. Project Betsy
  214. merkur engine in 93 notch?
  215. Bad gas mileage?
  216. Oil Pan
  217. muffler
  218. wiring?
  219. 7.5 Rearend
  220. Mysterious Red Light
  221. Wiring Diagram
  222. Ranger 7.5 Dif
  223. oil leak
  224. CLutch Safety Switch
  225. Good Replacement Engine?
  226. TRW?????
  227. My Third and Final Try
  228. posi trac???
  229. HELP
  230. match porting intake to head
  231. installing trans in late 2.3
  232. Circuit Short
  233. Selling my 1988 2.3L - Pictures Added
  234. Burnt valve?
  235. New Project
  236. New 2.3
  237. cant find turbocoupe.......
  238. 91 lx blown head gasket
  239. Hood update
  240. catalytic converter
  241. I Return.... With Questions....
  242. a4ld shift question
  243. pics of my 2.3!
  244. Update on the GreenMonster
  245. 88 chrysler 2.5 turbo motor, what size turbo?
  246. length of 2.3L engine
  247. Help Blower Controls 92 LX
  248. Starting problems??
  249. injector cleaner
  250. Headlight problem
