- Car spudering randomly while driving.
- Need Help ASAP please!!
- Computer?
- driveshaft rubbing the firewall after a drop with springs
- Squeak when I let off the brakes
- SVO cam
- anybody know of a rebuild kit?
- Newby needs advice on 93 LX 2.3L
- 2.3 turbo 89 hatch for sale
- 2.3t running oil pressure-how much you guys have?
- New guy with a question already
- Looking for 2.3 or foxbody to buy
- 2.3 turbo motor rebuild
- Going to look at a 2.3L Convertible, advice...?
- mass air flow sensor?
- Convert 5.0 to 2.3 or look for 2.3
- 4 cylinder to 5.0 can I use stock 5 speed manual tranny
- Want a 4cyl, need Carfax help...
- 2.3 down for the count?
- New guy to the 4 cyl.
- Hi guys
- svo mustang pictures/mod lists
- carb trouble
- Here we go, doing a Turbo Coupe swap
- Battery drained with new battery and alternator tests good.
- ignition/start
- 4 cylinder to 250 swap
- A/C question
- air intake question
- considering buying a turbo'd 2.3
- Tire size chart for Fox body's
- stang broke down at the gym need help
- swap info pleaz help
- '78 vacuum hose layout/chart?
- TC swap?
- need help with a few thingzzzzzzzzz
- volvo head swap
- Can I switch my front seats around with no problem
- 87 tbird turbo coupe air cleaner question
- 93 4 cylinder cold air intake or ram air
- 79 Mustang Limited Edition?
- 88 t/c vs. 86 svo longblock
- 88 stang swap 2.3L T HELP MEEE!!!!!
- will ranger springs fit on mustang?
- 2.3 transmission info.
- trans noise?
- Help with an odd noise
- Yet another exhaust thread...
- Convert a A4LD 2-wire car to a 3-wire tranny?
- Need help ASAP
- Cluster Accessories Issue
- Acceleration Problem...transmission?
- 88 auto transmission problem
- 2.3T cooling issues
- lower shock mount bolt
- charging problems
- '90 overheating
- im havin an issue with a mount i think,,help please
- need to improve my mpg
- will a 4.0 v6 ranger engine swap into a 91 mustang and other ?s
- TPS Adjustment
- Regular gas doesn't work properly?
- Transmission fluid blows out at high speeds
- 93 keeps cranking won't start
- What size inv. Torx bolt for diff?
- Manual conversion
- need to know what this is
- gas guzzling 4 cyl n/a
- AC problem
- Where do you go for turbo rebuilds?
- Just Wondering.....
- steering wheel shaking??
- where can i get this part? im desprate
- 90 2.3L in a 86 SVO
- new noise.. dont like it
- Need help
- Intake Manifold Gasket Sealant? Use or not to use?
- svo help
- External wastegate issue
- swapping auto to manual '81
- Transmission oil seal
- Bumper Cover Install
- something electrical?
- EGR
- Clutch pedal gears
- Tune with aftermarket cam?
- question about 93 4cyl
- misfire?
- 4cyl to 5.0 swap?
- 2.3 T5 swap, does not fit!
- boost bounces at WOT
- 76 2.3 into an 81?
- Cruise control
- 93 lx steering problem
- PERFORMANCE PARTS ????
- 5 LUG CONVERTION ?????
- what tranny?
- 351 Modified in 89 LX
- Rad fan
- Need help with a airbag light error code
- 1991 mustang LX 2.3L Faulty fuel pump?
- 91 mustang LX 2.3L interesting shifting problem
- Driveshaft Problems. Need help
- a couple things
- new to the 2.3 game need help
- svo's 7.5 vs gt's 8.8 suspension set up.
- headers
- underdrive pulleys
- BP or MAP sensor location
- Here's how to remove/install a gas tank EASILY, all by yourself!
- Computer chip mod
- tach problem
- 92 mustang wiring diagrams
- Aftermarket K-Members
- Where I can buy a Cold Air Intake
- Need help with 2.3 t-5 Bearing Retainer
- 2.3 trans problem
- 92 trans problem
- trans toast
- Need some advise
- Some one willing to do swap near maryland
- Who's done the 2.3t swap?
- Clattering from trans in 2nd gear only
- remove cat
- spark problems
- Tempo Engines?
- Think i got something rare?
- Black smoke. running rich
- Good Aftermarket Paint?
- 2006 4.0 v6 mustang engine replacement
- The volvo head swap, are there other options???
- 04 gt 2 vavle mod upgrades
- 87 to 93 tranny swap
- i think i might have a small to VERY LARGE problem
- Starting problem
- A few questions about a 2.3t swap.
- A/C & Cooling Fan
- 93 2.3L wanting a turbo....
- IHI AND T3???
- questions about rear end?
- Seats from a Ford Probe
- 92 2.3t complete no start or fuel pump
- 5 lug convertion
- Instrument panel question
- blown turbo?
- i am in need of garrett turbo part suppliers
- massive tranny leak!
- 1992 SVO motor swap help. Expert turboers help please.
- Question: If a part exists, but has no function... should I keep it?
- Are any of you guys running a bigger intake?
- how much can i do with a auto 2.3 4cyl?
- PCV valve questions
- 1990 Mustang lx Starting Problem
- 1989 turn signal problem
- 89 2.3 to 5.0 swap
- spark plug torque
- mach 1 style hood
- Fuel Pump Question
- new shocks/struts
- '87 Turbo Swap
- SoCal LA Cruise
- LOOKING TO PURCHASE FOXBODY MF I NEED YOUR OPINIONS
- 2.3 problems please help
- 2.3 non turbo no start
- a couple of problems.
- acceleration stutter
- Won't pass emissions, misfires while idling.
- what style compressor for the 2.3?
- 2.3 lx change over to s dual plug 2.3
- Picked up a fuel sipper today
- Help replacing vaccuum system
- NEED HELP!!!!
- 2.3t swap gurus need help please
- Finally got my intercooler on.
- quick question for those out there!
- why no boost? come on in turbo experts
- Timing jumping or moving
- Quick weight ?
- Is this turbo to big?
- What head should I use??
- turbo exhaust is smoking like on fire!!
- 1987 2.3 issue
- 2.3 t5 swap driving me crazy!
- 5.0 swapped have a question
- New '91 LX has a few issues, help please?
- fuel pressure under boost?
- convertible side cylinder
- fuel pours out during fill
- any way to tell injector other than by color?
- Help Oil Pump Bearings
- tps voltage?
- Wastegate rod
- NOS and turbo anyone?
- C4 Conversion, help with Console
- Hesitation under boost?
- Auto to T5 swap couple questions
- ecm question
- replacing ecm and other stuff
- sick engine
- clutch's is turbo better then n/a
- help on 65mm throttle body swap
- New 4 cyl
- anyone on fuel regulators?
- help
- Looked at a 92 Vert..Need opinions
- steering column
- 2.3t swap ?
- 2.3 turbo kit
- 2.3 turbo HELP oil in throttle body
- no start
- T5/clutches question
- Radiator Fan DEATH
- External wastegate(35-38mm)...Whats best?
- Radiator 1 row or 2?
- 2.3t ?'s
- 93 LX hatch rear brakes
- Clarification on some 2.3 mods
- 92 coupe turbo swap
- search engine for Craiglist
- Thermostat
- Turbo cars at the 'yard in NorCal
- codes on my 93 lx 5 speed
- Instrument Panel
- brake line
- map sensor ?
- 93 lx hatch
- Quick Gear ?
- long time lurker has ?
- Car wont start need ideas
- 91 convertible LX need ideas
- Hey there New guy here!!!
- Pics??
- what can i do for a little more power
- Racing front covers???
- Smoke out of the left fender
- Trans Info
- Need Help With VIN Plate
- door lock and door handle mechanism??
- 89 2.3l stalling out
- IHI rebuild
- EVR Problem
- Need help with 90 4cyl
- NPR intercooler install
- rear drum
- Car burning oil why?
- Coolant Temp Sensor Location?
- Delete this thread
- 2.3 throttle body ??s
- Need help on switching my 2.3 to a Carb 5.0
- electical issues (i think)
