View Full Version : 4.0L V6 Technical Discussions
Pages : 1 2 [3] 4 5 6 7 8
  1. K&N CAI Issues? (63-2565)
  2. 8.8 or 7.5
  3. what to do with o2 sensors?
  4. 7.5 Takeoff Rearends
  5. t-lok and 3.73 question
  6. BAMA Tunes ordered!
  7. Picture of my ugly Y pipe!
  8. How much hp do you have with mods?
  9. Please help! Which supercharger to go with!
  10. H and X pipes
  11. what should i hit?
  12. Before & after Exhaust Pix's!
  13. Best tuners
  14. between 2005 and 2007 motors
  15. Sound is great but what about performance?
  16. What's next?
  17. GT500 Suspension
  18. x-pipe, mid-pipe question
  19. Ford Racing GTA vs 5GT
  20. Check this vid out
  21. What kind of spark plugs should I get?
  22. What tuners are you guys using?
  23. ford performance "package" questions
  24. How do you check your transmisson fluid?
  25. Flowmaster American Thunder
  26. Muffler Help
  27. MSD wires for our cars SUCK!
  28. Procharger Installed
  29. Squeaking from the motor. Help !
  30. internals and tranny?
  31. What is a good starting point on modifications
  32. accel & e3
  33. oil capacity
  34. TCS Response Time
  35. Does dual exhaust void the warranty?
  36. X Cal or Diablosport???
  37. Common Question... FRPP Dual Exhaust?
  38. 70mm throttle body install?
  39. Got the Zex kit installed!
  40. Need picture of your Zex install
  41. auto to manual
  42. Question about Sniper tuner
  43. T-Loc absolutley necessary?
  44. About to cut
  45. frpp cak
  46. Question about a tuner?
  47. Total Re-vamp... Need some Input
  48. need help with frpp duals
  49. Putting a gt take off muffler on my v6
  50. Trust the Midas touch...
  51. T-5 TRANNY PROBLEMS
  52. Splash blended fuel= bad MPG?
  53. somebody please help
  54. Problems with the x
  55. Cant Get GT take off itermediate pipes to go over axles
  56. Grinding 3rd to 5th?
  57. Should I Buy a New Intake
  58. does an intake make the exhaust louder?
  59. 3.73 install guide
  60. best way to dump cash on a stang
  61. t-lok and 4.10 gears?????
  62. SCT X3 Tunes
  63. 6 Speed Swap
  64. Manual trans Tune benefits
  65. Newtakeoff.com?
  66. Fidanza Lightweight Alum Flywheel
  67. short tube headers
  68. Tuner shift adustment question
  69. K&N w/ Hood scoop?
  70. 4.0 Power Adders
  71. Zabteck TB
  72. Kooks headers?
  73. which tuner is better?
  74. Kooks headers?
  75. Zex Nitrous Kit for V6's
  76. Procharger,Vortech,Xcharger,Powerhouse turbo??
  77. X-Charger Help
  78. tuner
  79. MAC Long Tube Headers
  80. "Popping" from Factory Muffler
  81. Aftermarket ignition ?
  82. v6 shifters
  83. need help with headers
  84. short throw for the v6?
  85. turbonator?????
  86. Looking For A Good Cold Air Kit
  87. transmission swap?
  88. Does anyone have this?
  89. V6 Auto Tranny
  90. To CAI + Tune or not to CAI + Tune? That is the question
  91. best turbo or supercharger????
  92. does a throttle body spacer work?
  93. C&L cai / Xcal3 Question
  94. When upgrading gears...what do you need exactly?
  95. I"m looking for performance parts
  96. Help with Gears
  97. Hurst STS
  98. New gears make a humming noise
  99. Should I install the headers myself
  100. Axle shaft Problem need help
  101. First time to the track, what are you guys running with tunes?
  102. Will a x CAL 2 tune work for the new x cal 3
  103. GEARS WORTH IT??
  104. Long Tube Headers
  105. v6 engine, gt performance?
  106. performance questions
  107. Weird Overdrive Problem
  108. Thottle Body/Position Sensor?
  109. 3.73 or 4.10 Gears?
  110. C&L CAI
  111. Another satisfied customer
  112. Turbo Questions
  113. Exhaust poll
  114. How much to install gears?
  115. Replacement Clutch
  116. Anyone have this grill!!!
  117. Helps!!! is my clutch out???
  118. UDP removal
  119. 0-60 time and launch question PLZ HELP
  120. Gear installation kits
  121. SCT LIVEWIRE TUNER
  122. Performance upgrades for V6??
  123. 8.8 Rear Swap
  124. Turbo, H-Pipe?
  125. gear change...breaking in...whine
  126. 3.73 installed, tuner modification?
  127. which D/S
  128. Dual Exhaust for V6
  129. Which oil?
  130. Bearing kit
  131. 92/93 tune recommendations?
  132. 2005 V6 Auto transmission won't change down from 4th ot 5th?
  133. frpp or pypes
  134. clutch replacement
  135. Overheating possibly but maybe not?!?!
  136. airbag light flashing
  137. Can I shut off the traction control w/Xcal2?
  138. sts turbo
  139. FRPP V6 duals trim pieces wanted
  140. where in the hell can i buy ford 4.10 gears!!!!
  141. What are factory headers mad of?
  142. 4.10 gears w/ tlok v6 Auto PP --- Brand
  143. Gear purchases
  144. Injen CAI Pics
  145. Limited slip defferentials: help/advice needed
  146. Upgraded to GT front brakes on my V6 today (56 K beware)
  147. Shifter List
  148. pypes ??
  149. Gears...Who's left?!?!?!
  150. Exhaust system
  151. Reputable Dyno facility in the Norther VA, D.C. area?
  152. Engine Swap for factory V8's
  153. pypes x-pipe question
  154. pypes mid muffler video
  155. duel exausts?
  156. Cold air intake and exhaust upgrades
  157. V6 O2 sensor and tuners
  158. V6 Bumper, GT Bumper
  159. Auto Tranny Flush.......not too sure
  160. im torn between 3 types of exhausts
  161. WANTED!!!!!!!!!!! 3.90s
  162. well im mad as heck now
  163. Coil and wires
  164. bbk cai problems
  165. Replacing my Axle to 4.10 Will I need a Tune
  166. Battery disconnect and custom tunes?
  167. GT take off dual exhaust
  168. Lethal Performance Dual Exhaust
  169. Need info on Exhausts please
  170. anyone who has put on 8.8 rear need info??????
  171. Is a new DS worth it for a N/A DD stang?
  172. what the hell ford.
  173. Clutch problems with 2006 Mustang and Ford Customer Service.
  174. rear gear change--how much of a difference in performance?
  175. How hard is it to replace the second gear syncronizer in the tranny?
  176. Improving fuel mileage via air filter?
  177. Axle code/gear ratio?
  178. Transmission help please!
  179. Question for Sancho805
  180. FRPP Exhaust, Headers.
  181. GT muffler install - mechanic recommended welding hanger?
  182. Auto Trans
  183. How much am I looking at for an install?
  184. Seven steps to pinion heaven..
  185. Please explain Wheel Hop?....
  186. Short Tube or Long Tube
  187. Motive 4.10 DILLEMMA
  188. Cam help please?!
  189. MOVED: gt40 heads
  190. V6 manual trans harsh accel vibe or growl
  191. wierd vibration on my 07
  192. 4.10 Q
  193. Race fuel or pump gas
  194. Halfway Ripped off Exhaust
  195. Dual Exhaust for v6
  196. musclecar exhaust
  197. V6 swap to V8
  198. Plastic between our hoods and windshields?
  199. Would T-Lok have helped?
  200. FRPP LSD and 4.10 gears
  201. gettin dual exhaust
  202. airbag light.
  203. where to buy 4.10 gears
  204. No Cats on my Pony?
  205. CAI do you have to re-flash?
  206. so...
  207. Wouldn't go into gear
  208. Questions about purchasing Magnaflow Catback Exhaust
  209. New guy here! Q's about nitrous
  210. 3.73 or 4.10's
  211. t-loc
  212. Gear change and mpg
  213. Ford racing tlok
  214. Question about auto shift lag
  215. Tuner Questions
  216. 200 for a dual exaust..good quote?
  217. noob here, need help with CAI/tuner
  218. Ford Ranger Tranny in my 06??
  219. Ninosport pipe Kit
  220. Safe to buy used gears/t-lok?
  221. Flowmaster
  222. not sure which tuner to get
  223. Drive shaft Install
  224. Tune support?
  225. diablosport maf.ia
  226. Yukon Gears?
  227. New Clutch
  228. ? about improved performace ?
  229. x-cal 3 from bamachips
  230. strange noise after gear&tlok install
  231. CAI sound
  232. Changed my mind
  233. ABS on Axle
  234. tune whp numbers
  235. Ford Ranger tranny in my 2006??
  236. V8 swap into 2005 v6 stang
  237. Locking Diff Price
  238. T-lok and True Track
  239. 2005 clutch vs. 2007 clutch
  240. installed a CAI, how to backup the stock tune first
  241. manual transmission
  242. Drive Shaft
  243. JBA headers and SCT X3
  244. This may sound stupid, but I honestly don't know.
  245. GT Take off Question(updated w/pics)
  246. NEW *** Corvettes - Mustangs - Links - ***NEW
  247. Cost to install new take-off rear end?
  248. stock d/s
  249. 8.8?
  250. noob questions about a tlok
