PDA
View Full Version : 4.6L V8 Technical Discussions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25
  1. Gear Question
  2. Should I SC my automatic? Comments please!
  3. auto tans
  4. under drive pulleys
  5. Help - Fluid On Rear Axle!
  6. Cam Change/Cylinder Sequence Change
  7. exhaust vs. pulleys and gear
  8. TQ converter vs. 1 piece driveshaft ?
  9. cams
  10. Spydershaft
  11. 10 psi whipple or saleen??
  12. shifter
  13. ready for my longtube header install
  14. tune and gears???
  15. Questions about TB and Cams before S/C
  16. Hurst 5 speed shifter #3910201
  17. what exhaust should i get for a good, low, aggressive rumble?
  18. 08 manual tranny
  19. Whipple Crew Club Meeting {No Saleens Allowed JK :)}
  20. Which air intake is best?
  21. SC Fuel Pump which one
  22. What Off Road X-Pipe are people using?
  23. Dyno tune vs. Canned tune...difference?
  24. severe hesitation
  25. Exhaust question
  26. Performance Difference 3.55 vs 3.31
  27. Military discounts
  28. JBA vs. BBK?
  29. turbo or super charger
  30. Shelby GT 500 6060 Tranny Into Our Cars: What's it Take?
  31. Coil on plug question.....
  32. IAT Sensor
  33. GT500 Throttle body on saleen s/c
  34. CAI questions and other compatible mods?
  35. FRPP 4.10's GONE EVERYWHERE!
  36. Long tube headers
  37. 08 GT 3rd Gear Grind Cold Start
  38. Can't figure out problem with mcleod twin plate clutch!!!
  39. 351 windsor swap
  40. Pypes O/R H or Mac prochamber
  41. Ebay Kenne Bell Scam!
  42. 16 HP from UDP's and coil packs???
  43. Takeoff or rebuilt tranny
  44. Which gears Motive or Ford
  45. CAI AND TUNER
  46. which clutch would you buy?
  47. Synthetic Oil...when to switch?
  48. 5 speed owners
  49. UDP's
  50. 3.55 or 3.73 in a auto
  51. ATI Procharger
  52. pi torque converter
  53. 4.10 gear help.
  54. Burt Clutch??
  55. Aluminum Flywheel and Clutch.
  56. 2006 Rear Axles
  57. Crank Pulley Bolt
  58. Roush Supercharger Advice
  59. i need hp
  60. manual valve bodies
  61. Higher HP Applications - Prothanes and/or Torque Limiters?
  62. 2006 Mustang GT spark plugs?
  63. short block
  64. 4.10 question
  65. New 08 GT - Blue smoke on start up?!?!
  66. Current mods on my Cervini
  67. c&l racer or jlt tuner package
  68. Whipple
  69. Borla/FRPP Exhaust Problem/Leak
  70. Shift Light?
  71. Loud Obnoxious Rotational Noise Right at 80 MPH...
  72. Accell Coils question
  73. Fail Safe?
  74. Whipple install finally scheduled
  75. Drivetrain Vibration?
  76. CIA and TUNER
  77. STEEDA POWER PAKS?????
  78. What kinda oil?
  79. Randys ring & pinion?
  80. Next mod for Auto?...
  81. gear set??
  82. Side exhaust question for Cervini's side exhaust problem
  83. Corvettes - Classic Cars - and Hot Links
  84. what gears for turbo'd car?
  85. Turbo-PRO Performance Module
  86. Throttle Body
  87. BBK 62mm throttle body w/Saleen S/C
  88. DS vibration?
  89. Stainless or Ceramic Headers
  90. 4:30 auto?
  91. Turbo install shops in Southern California
  92. Speed Governor
  93. 05 stang s/c vortech question !?!
  94. 05+ exhaust
  95. best one piece driveshaft?
  96. To tune or not to tune! I am lost, help!
  97. Roush Axleback + what O/R pipe?
  98. Engine Re-Wiring Kit?
  99. Straight talk about headers.
  100. Does Anybody Make ENGINE Lifting Hooks
  101. Spydershaft
  102. My motor is being rebuilt, can you help identify the cause of the problem?
  103. which model whipple?
  104. off road h pipe
  105. Engine Rumble
  106. Differential Cover Gasket
  107. ford racing girdle
  108. Rear end fluid
  109. Intercoolers and boost controllers
  110. Power how much?
  111. turbos???
  112. HP Perf. Turbo Kit
  113. Lets Talk Aluminum Driveshaft
  114. 8.8 rear end fluid capacity
  115. auto trans mods?
  116. MAFia and fuel injectors
  117. Custom fabricated twin turbo set up
  118. differential cover
  119. Trading V6 for 08 GT... Already a problem
  120. BBK Headers Install?..
  121. 05-up block internals differerent than 99-04
  122. Aftermarket Girdle?
  123. Spydershaft/Aluminum Flywheel
  124. why is it that....
  125. removing cats
  126. No muffler Question?
  127. Turbo kits
  128. How do I ID which Gears I Have?
  129. 3.55 gears with Whipple Is that good enough?
  130. 3.73's Or 4:10's?????
  131. Best Shifters
  132. ford racing 4.10 sound
  133. Aluminum driveshaft
  134. Who has drive shaft loops? Advise?
  135. STEEDA INTAKE ELBOW ISSUE
  136. Stroker Kit
  137. top speed on 4:10 auto?
  138. 500(b)HP?...whats bhp?
  139. Problem, please help!
  140. LTS vs shorties
  141. Hurst Short thorw bushings
  142. 331 vs. 373 gears
  143. New Wheel/Tire combo
  144. GEARS OPINIONS
  145. Bamachips strategy code
  146. FRPP 4.10's are here but I've got a question
  147. 2008 GT/CE new problem with bent valve-help
  148. HP rating for a 5 speed
  149. Is anyone using methanol injection
  150. FRPP VS. Motive gears?
  151. Tuner question..
  152. What's my hp?
  153. tunning
  154. Dear lord I'm so excited.!!!!
  155. WEIRD NOISE. OPINIONS. PLEASE HELP!
  156. Almost Sold On Saleen SC After This.
  157. upgrading tuner/UDP/CMMV/Driveshaft ?'s
  158. Auto-Manual Switch
  159. 4:30s na??
  160. Mustang Gears
  161. Supercharger new installation???
  162. 5.0 Mustang Growl
  163. Torque convertor
  164. Spark Plugs for Nitrous
  165. Those with 4.30 gears
  166. Poly Motor and Tranny Mounts
  167. Still to quiet!!
  168. has anyone lost a motor yet cuz of supercharger
  169. Dnyotech driveshaft
  170. kenne bell ebay fraud
  171. that big of a difference??
  172. Procharger BOV
  173. STS single Turbo kit Mustang 05-08
  174. Engine mounts or gears problem?
  175. detonation?
  176. auto driving habits?
  177. Power steering failure GT 08
  178. Steeda Diveshaft vs. Spyder Driveshaft?
  179. MOVED: did anyone hear about the baddest mustang of all time? SHELBY SUPER SNAKE GT500!
  180. ATI vs PAXTON
  181. auto tranny prep?
  182. What the hell is that whistling????!!!
  183. atnn: 4:10 daily drivers!!
  184. Steeda UDPS.new thermostat?
  185. Car Acting Crazy
  186. Forged Internarls. Wich and Where ?
  187. Tunes and Trouble codes
  188. keep the 4.10's or switch to 3.73's?
  189. midpipe install write up
  190. supercharger/boost question
  191. Gear Swap Install Price - PLEASE VOTE
  192. short throw shifters
  193. Oponions on the MGW shifter from owners
  194. h or x
  195. small mods to lower 1/4 mile time?
  196. Whipple + comp stg 4 cams ?
  197. Pulled the trigger on a fitch
  198. Supercharger Accessories
  199. GEARS
  200. Boring instead of stroking the 3V
  201. TB question
  202. UCA AND LCA for my 07 need help this might be it.
  203. QUESTION ABOUT X PIPES
  204. Mechanical Vs Electrical Boost Gauge?
  205. WHIPPLE OWNERS?
  206. Sniffer Inspection Laws
  207. Non Intercooled Whipple Question
  208. MAC LT's & O/R Prochamber
  209. CHARGE MOTION DELTE PLATES
  210. MOVED: GT500 CONVERSION KIT & FIBERGLASS HOOD
  211. Ordering internal parts. Advise needed
  212. 5 speed questions
  213. NITROUS
  214. x pipe
  215. Delete plates
  216. SCT livelink problems.
  217. TIME TO BUY! H pipe whatcha think
  218. offroad pipe and emissions Q?
  219. Vortech Charge Cooler
  220. Are all Blocks created equally?!?!?!
  221. Stainless steel vs aluminum
  222. Shaftmasters 3.5" Driveshaft Install, Review, Track test!!!
  223. GT supercharger?
  224. CAMS
  225. Boost management systems
  226. Roush axleback similiar to mac axleback?
  227. Best CATTED X-pipe!!!
  228. Mushy cornering
  229. Exhaust - adds hp? sounds 30-40% louder than stock, not killer
  230. I need some SCT2 Tuner help
  231. 2007 mustang Gt tuners
  232. longtube installation
  233. Want to wake up my GTA's a bit
  234. Driveshaft
  235. 2008 4.6 vs. 05-07 4.6 - Different?
  236. longtubes and muffler deletes
  237. Idle Stang
  238. 2006 Mustang GT. Normally Aspirated or Supercharged?
  239. driveshaft issues
  240. 5 speed ...
  241. anyone regret going with an auto?
  242. for all the auto guys
  243. best bang for the buck mods for auto?
  244. 800 - 900 rwhp Trans. Question
  245. oil leak
  246. Vortech Q's
  247. Advise on Pypes mid-muffler
  248. Low to Mid 10 second car
  249. automatics...20 questions lol
  250. Thinking of going with 4.10s
