- newbie to site
- Accel Coil Pack Issues
- Choosing Cop's
- CAI...JLT or C&L
- 2005 mustang
- underdrive pulleys steeda vs bbk/and roush
- CAI,THROTTLE BODY AND PLUGS QUESTIONS...
- MAF volts help needed: Educate me.
- Oil Change - Got me Nervous
- 06 4.6L Engine Vibration
- Tires
- New CAI and don't know what to do!!!!!!
- TCS Switch
- 'check charge system'.
- Fuel Gauge Off - HELP
- 2008 GT Third Gear Grind Syncro Replaced
- Will they work on '05+ GT's????
- Mutha Thumpr cam review
- 05-06 Vortech V-2 supercharger fuel pump help!!!!
- anyone seen this shift kit??
- 08 Spark Plugs
- MAF pin out needed
- Looking for switched 12v underhood
- Questions installing gauges
- Gear experts - question for ya
- Throttle lag at 3000rpm
- Porting our Heads?
- Major CAI Problem Please help
- should I risk doing spark plugs?
- Need help with limitied slip!
- Please help ASAP with Pulleys URGENT
- Any way to smoothen out the Pro 5.0 kit shifting action?
- help with roll controle
- 4.10's starting to whine
- Confused!! need clarification for x cal3
- 97 mustang gt 4.6 ~ 5.4
- 2009 <700 miles 2nd gear noise
- Low RPM Knocking - Should I worry?
- Supercharger Gauge Readdings ?
- CMCV & FRPP Cams
- Tuner opinions/recommendations/warnings
- What a way to start the day
- sct x3 question..
- exhaust leak at collector
- 8.8 Ring and Pinion Gear install
- gas smell???
- what did your forged bottom end cost you?
- Loud squeaking noise from rear suspension
- Help! Broken Spark Plugs
- bad starter or what??
- What gears should I get?
- Having to add coolant normal ??
- Nitrous Set-up Help
- Custom Backspacing Question?
- high stall TC first impressions?
- FRPP Handling Pack + Spyder Shaft = What Pinion Angle
- Tuner Question
- Shorty Header Install
- Pypes Mid-Muffler Install Question
- What GEARS to choose?
- Car stalled and now I have 15 codes...
- 500+ HP without super/turbo?
- VERY loud ticking from engine...need help finding problem.
- Keeping the "startup" rev behavior
- O2 sensor
- Check engine strategy code after custom tune?
- Stock sounding cams...
- supercharger install
- Help Pls codes p0351 & p0352
- TR-3650 Gear Ratios
- wrecked 98 cobra questions
- GT500 blower on a 4.6?
- Tuning ?
- 600 hp
- Gear gurus: Gear noise help needed
- X pipe or new cats
- Is the motive bearing kit good?
- Questions about NOS kit and Tuners......
- Rearend Noises
- clutch noise
- Need some throttlebody help
- Low Idle after battery swap?
- Gear Questions, need some opinions
- Problems @ WOT
- AC/Heater fan not working...
- Supercharger for DD
- New supercharger choice - Edelbrock
- ? for SCT tune guru's.........
- CAI and Tuner
- Blinker light trouble???Please help
- Auto with 3.73 gears
- throttle body for whipple
- Double Clutch - Hurst Shifter - Rough??
- 4.10's installed
- Headers,sparkplugs, and WTF was ford thinking
- P0135
- 4.10 with AOD
- Comp Thumpr - Cam Phasers?
- OBDII Will not complete
- How much power could I get out of my car N/A
- engine noice please help
- Short tube headers for 07 Shelby GT
- TC or 3.73 gears? need advice please
- want to get some engine work done
- abaco digital maf
- 3rd Gear Issue.....
- Automatic transmission leak...
- Help taillights on a 2005 GT
- lost a # of boost after long tube install
- Ignition hesitates in snow
- Delayed throttle response.
- Troube Code: P0172 SYS BANK 1 RICH
- N0S Questions
- axle ratio
- Supercharger Question: A real head scratcher
- RAM AIR
- Naturally Aspired Build - Looking For Help
- BBK longtubes and SSS catback
- Supershaker Install Questions
- 1st MODS
- Shorty Header Install How-To?
- Requesting Advice on a 'possible' shifting problem
- Need your opinion!
- I NEED HELP WITH GEARS DECISIONS S197
- oil sending unit
- Billet fuel rails w/ Y-block
- Question about FI hp on stock block
- Upgrading the MAF on BBk CAI
- FI Guys....Especially Vortech.....Question..
- pulling the trigger today,vortech or paxton?
- New product from Trick Flow
- automatic transimssion question
- For those with the JLT intake...
- a little help please
- Shift Points HyperTech III 4.6 2005 ????
- manual transmission question
- HELP.....P0900 CODE 05 GT MANUAL
- Won't Start after new Tune
- Need help with inop gauges.
- what kind of fuel you use?
- KR Exhaust on a 4.6
- lean or rich?
- Mass Air Flow Sensor
- engine/tranny build up?
- Paint problem?
- Question on amount of differential oil needed, and whine noise.
- CAI and tune question
- thumper cams
- All 3 FRPP packs on a GT? Anyone know the end result?
- 07 GT Parking Brake SNAFU
- need help please ((o2 censor))
- New Valve Covers
- Tune Review: Brenspeed 93 Octane vs. BamaChips 93 Race
- Changing Tunes
- Won't Start!!! Please HELP!!!
- Is Paxton Novi the best of the best???
- opinions please..
- Violent screetch coming from pulleys. Help!
- PRO 5.0 Shifter Question
- POWER sHIFTING THE S197 NEAR IMPOSSIBLE!
- Has anybody messed around with their tuner options
- Regearing question
- P0135 Code
- FRPP hot rod vs Comp Cam Thumpr
- Supercharger Set up
- A.E.M. Brute Force
- Exhaust question
- Suspension
- CAI Cleaning
- 4.10/tune thread..
- Blowoff or thru, is either one better?
- new eldobrock blower for 4.6 3v
- Should I push it and upgrade to Saleen Stage 3 package from Breenspeed?
- 08 Spark Plugs
- stock H VS. aftermarket H
- Problem with Charging System
- 03 Cobra Supercharger on S197 4.6L?
- Supercharger with Cams
- Am I crazy? Too much gear?
- saleen supercharger
- Hellion single modded to Blow Thru
- Check engine light with new exhaust
- cams and vortech non-intercooled...
- Throttle Body Spacer
- New Throttle Body
- Head light diagram
- missing a gear
- Vortech supercharger 01
- SCT X3 Question
- Install Cost
- 2007 4.6 needs more power!!!
- Volant CAI?
- those with vortechs
- Headers+what else
- JDM Engineering or Evolution Performance
- 3.73s installed and have a ? for those with 4.10s
- Idle?
- Need help connecting the dots!
- Parking brake
- Need Help regarding Saleen Racecraft S/C Mustang
- 2007 mustang gt recalls ?
- oddball auto gear question..
- manual to auto tranny???
- Transmission noise... need help
- Help! Car died 3 times today!
- Drag radials and Short Throw Shifters
- Is there any way to lower just the rear of my 07GT
- the infamous 3rd gear grind
- iPod interface
- Pop/backfire out of right rear exhaust
- anyone running this kit...
- Sequential FI
- speedo problem 2007 Gt
- NEED HELP,2009 GT cruise control not working
- Whipple charged! What spark plugs should I run?
- Which tune to order?
- 2008 Tire Pressure Sensor
- spring mod list...
- superchagers
- Comp Stage 2 vs FRPP Hot Rod Cams
- My car has a new trick
- Emission test failed
- tpms
- I need some advice
- Fuel Pressure Gauge ???
- 2005 GT Spark Plug Install 48 K on Car
- Most efficient power adders?
- Stage 2 cams without springs
- traction control
- Charge Plates?
- question with hid xenon
- Have not a clue
- What are the advantages and disadvantages to installing 4.10 gears?
- Windows and In-Dash Dvd Stopped Working
- consistant vibration at 1100 and 3100 RPM pissing me off
- Clutch replacement question
- Oil pan drain plug diameter? '07 4.6
- Electric Problems
- SC belt question
- 2006 Mustang - No AC/Heater Fan & Fusebox Diagram
- FR500S specfic mufflers for sale?
- Upgrading trans, where should I go?
- shift into reverse?
- Driveline Vibes
- exhaust question from a fabricator.
- 06 Mustang GT Front 12V Aux not working
- Feed me NSR cam info (performance, dyno, pricing)
- Having a "pop" sound when i start my car
- MSD's Blaster 2 Coil On Plug High Output Ignition Coils
- No Springs Required Cam install difficulty
