View Full Version : 4.6L V8 Technical Discussions
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13
  1. No Springs Required Cam install difficulty
  2. sensor issues and wiring problems...any guesses?
  3. Bama 87 Performance - way less power
  4. Need some advise on guages
  5. Gasket Problems 2007 4.6
  6. 295/45's out back.....
  7. going FI, what gauges are needed
  8. NEW SUSPENSION MODS
  9. Ford Racing AXLE GIRDLE
  10. going FI what plugs??
  11. Newbee CAI/ tune install question
  12. Need Help!!! Bad knock
  13. 12s possible?
  14. Predator tuning questions
  15. high flow cats- worth it?
  16. Livernois Stage 2/3 Heads
  17. Saleen blower with 550 HP for 08 GT
  18. Brenspeed Tune and Emissions
  19. Saleen stage 3 + thumper cams ????
  20. wider tires?
  21. 2008 GT Exhaust System
  22. Low tire pressure light came on..
  23. Stock camshaft specifications
  24. SCT 3 vs. Diablo Predator Tuner
  25. General Brenspeed Programmer Questions
  26. Reflashed software - car runs like crap!
  27. questions about forging
  28. Long tubes on the way!
  29. Ford racing Drag Pak ...
  30. Leaking Whipple
  31. Necessary Gauges and Brands / Supercharged
  32. Gears Question! Quick Response Needed!
  33. 4:10 Gears
  34. tranny woes , maybe it is 6 speed time???
  35. Is there an RPM "governor" for 1st gear
  36. gear installation question.
  37. I make the right choice?
  38. Dead Spot @ ~2750 RPMs
  39. Anyone conquered the dreaded "Gear Rollover" noise?
  40. LTs design problem?
  41. long tubes add good sound?
  42. Shorties?
  43. LT install
  44. After CAI and Tune, whats next?
  45. New Supercharger edelbrock at sema show 08
  46. ACC Torque converters ?
  47. What cam to use
  48. Steeda UPD
  49. What Tuner?
  50. My Car Is Broke!!(transmission)
  51. New Gears
  52. looking for 350+whp on 91 pump... N/A.. ?
  53. Transmission HELP
  54. Need Help in AZ
  55. motive gears...
  56. Whipple Gen I vs Gen II
  57. 4.10 gears questions
  58. BBK CAI and TB installed, Idleing high?
  59. traction control
  60. B&M shift Kit E4OD
  61. rear end clunky
  62. Getting blown, gear questions
  63. 1997-99 svt cobra 4.6/t-5 into 1967 mustang?
  64. Where'd you get your gears put in at? (TX/LA shops)
  65. insturnment cluster on off
  66. Steeda delete plates and UDPs
  67. eaton blower
  68. Problems w/ '08 5 speed stick
  69. drive shaft
  70. Spydershaft.
  71. Shortie Growl?
  72. FRPP Hot Rod Cams
  73. 2006 Automatic Broken Shifter box!
  74. 2 Questions on LTs
  75. Compatibility - Hot Rod Cams / Whipple?
  76. FRPP Exhaust difference
  77. Whippled stang gets VMP tune
  78. What to do
  79. Are all LT headers street legal?
  80. gear ratios
  81. Gear Oil Change?
  82. ET for STOCK GT/auto trans/3.31 gears
  83. LTs versus Shorties...what is the truth?
  84. X CAL 2 Failure
  85. question about supercharger necessitys
  86. Clutch Upgrade
  87. Transmission... ripped it apart
  88. Best place to get axle shafts?
  89. Synthetic ATF change?
  90. Twin clutch kit
  91. Need Help Picking An Exhaust!!!
  92. Gear Question (Yes another one.)
  93. Pypes Violators installed!
  94. Cams...FRPP vs. Comp Thumpr
  95. Bassani vs. Flowmaster
  96. MAC LTS and prochamber
  97. ACC Torque Converter ?
  98. Mustang Performance Comparison
  99. differential seal replacement
  100. hurst shifter installation
  101. PRO 50 3.90 GEARS
  102. Trans. whine on stock car (not normal)...
  103. Thinking about switching intakes
  104. gt500 brake kit will it fit?
  105. CompCams Stage 1 SPR Blower cams
  106. 05 GT with 4.10s,UdP, C/L CAIw/brenspeed tune/Mac axlebacks vs. Racecraft
  107. spark blow out?
  108. Want more HP
  109. Changing throttlebody
  110. MPH for each gear with 3.90's?
  111. Anyone who has had the T.S.B for 1-2 clash...
  112. if you adjusted you pinion angle, come in!
  113. just ordered 4.10's
  114. Injector Change
  115. Kenne Bell~vs~Whipple??
  116. 3.90 or 4.10's with a 150 shot!?
  117. Should i put NOS on 100,000 gt with minor mods
  118. Another what gear should I use?
  119. What am I missing??
  120. So how much can the GT 4.6L really handel???
  121. Auto drivetrain loss w/ shaft
  122. Was My Gear Install Right?
  123. when to change tranny fluid/ rear end fluid
  124. stock torque converter...
  125. twin turbo 2008 gt
  126. New pulley for novi 2200
  127. How to be kind to your [stock] clutch/tranny when your GT is mostly a DD?
  128. Drive Shaft and U Joint
  129. Can you do a burn out with a manual trans?
  130. Why Recommend 3.73s for Auto?
  131. Need Help with mods
  132. Driveshaft results
  133. Where to purchase FRPP cams?
  134. rear-end
  135. Axle problem...need some advise
  136. Sulpher Smell
  137. Injen CAI
  138. 5.4L GT
  139. Stock tranny limits
  140. what drones worse: mac or bassani?
  141. 3.73
  142. Transmission problems sighz
  143. Gear break in period
  144. Gears or headers
  145. Aftercharge cooler add to supercharger?
  146. Auto shifting issue after 3.73's
  147. HELP engine mods on a 06 GT with a low budget
  148. Aluminum Flywheel
  149. BEST AXLE-BACK FOR GT?
  150. question:do the k&n fipk intake and bbk throttelbody work together
  151. New hanger brackets on Slp loudmouths?
  152. Rear end chatter...need help!!!
  153. 4.10 gears
  154. Shifter bind success?
  155. Short throw shifters with 40+% reduction?
  156. 05 GT 5 spd question
  157. Any Ideas?
  158. 4.10s installed
  159. question... CEL
  160. 3v education
  161. clutch problem?
  162. Computer Detuned Itself?
  163. speedometer a ticket and making changes
  164. Pro 5.0 3.90 gears & tuner
  165. A few questions for the pros
  166. Will IAC plate mod lower the mpg or hp/tq?
  167. best CAI + tuner for '06 GT?
  168. off road X pipe dyno ?
  169. 2008 GT what thermostat? 180 or?
  170. PI swap questions
  171. Thinking realistically.
  172. Problems with spec stage 2+
  173. x pipe install
  174. Questions about adding power, need help
  175. Switching Tunes On Tuner
  176. Steeda sport shifter
  177. New Gears
  178. Starter Mods
  179. Plastic or Aluminum CAI
  180. 4.10 Gears, Just Do It, Period
  181. my first thread here
  182. idle dipping...
  183. 05 stock intake question
  184. PI Stallion 3000 RPM TC Installed
  185. decisions decisions
  186. tuners?
  187. Clutch is Chattering...24k miles
  188. FRPP Hot Rod Install
  189. Whipple is installed!!!!
  190. slow RPM drop when shifting
  191. Build List Help, 2008 GT
  192. supercharger question
  193. Aftermarket Driveshafts
  194. Anyone have any luck with a throttle body
  195. Gear Question
  196. Supercharger Belt Came Off Today
  197. Clutch warrenty on 07, if needed?
  198. frpp differential w/4.10's
  199. how much boost saleen sc
  200. Losing Power during accel at 3k+
  201. Steeda UDP squeeking
  202. hurst shifter w/ alot of movement
  203. 2005 and NEWER!?!?
  204. 3.73 Gears and 20" rims
  205. Shift Kit
  206. Warranty Issues
  207. Question about gears
  208. exhausts sounds between L/Ts and shorties
  209. E-brake won't lock up tires
  210. Need help/advise with Brake upgrade on '06 Mustang GT
  211. Whats the loudest/best sounding axle-back system (w/mufflers)
  212. rearend help
  213. Should my tranny be making a noise?
  214. Motive 4.10 break in period?!?!?!
  215. Intermittent Battery Indicator Light, "05GT
  216. Will Slp loudmouths put my engine at risk?
  217. blown gasket
  218. Intake Problem/Concern
  219. ckosiek messaged me about 4.10 gear Evolution install???
  220. BBK 62mm Throttle Body
  221. 4.10's VS 4.30's
  222. UPDATE: Hissing from rear end
  223. Lincoln tranny into GT ?
  224. American Muscle Tune?
  225. Check Engine P0340
  226. Difference between Hurst Competition and Hurst Billet Shifters?
  227. belt tensioner upgrade kit - 05 mustang GT ???
  228. Dennys DS
  229. Brenspeed S/C custom kits
  230. 4.10 gears and the speedometer question
  231. 2007 mustang GT gear ratio?
  232. intercooler look
  233. 07 GT is feeling sluggish
  234. headers/Performance Chip?
  235. Transmission Crossmember removal? PIC*
  236. A/T fluid change
  237. Defrost knob turns on airconditioning
  238. Granatelli CAI, tuner ?
  239. 05 GT transmission sounds very clunky
  240. Its time to go TT
  241. Motive Gears
  242. Thinking about a Turbo
  243. Gear Oil
  244. Next mod ?
  245. intake mod
  246. slp loudmouths vs corsa catbacks??
  247. catback system and x-pipes?
  248. Help choosing clutch, flywheel and slave
  249. 2007 mustang GT coolant change
  250. ...and so it begins
