View Full Version : 4.6 (Modular) Mustang
  1. 01-04 Cup Holder Console
  2. Rough When Cold
  3. Coolant question.
  4. BUSTED!!!
  5. What causes the airbag light to come on?
  6. Weird Idling issue!
  7. Oil Pump Upgrade?
  8. Trans Oil
  9. help new code for me.
  10. quick head question
  11. Cobra spoiler on a gt
  12. Helpful Directions (Shift Kit)
  13. Control arms
  14. Windshield Washers
  15. Water leak?
  16. What tires are better in the corners?
  17. 96 GT Convert. Needs Painted
  18. 97 gt- PI swap- Head Gasket Size Choice?
  19. Wtf!? Fuel Filter perhaps!!!
  20. trying to isolate squeak: should there be ANY play in tension pulley?
  21. Hydroboost leaking. Could this cause idle issues?
  22. strange noise
  23. Is my stock 2004 GT axle 7.5 inch or 8.8?
  24. Electronic seat adjuster.
  25. 3.73 Gears
  26. Aftermarket Automatic Shifter for 2001 GT
  27. 5.4 2v conversion
  28. SCT Data Logging
  29. V1 fuel pump question
  30. Larger I/C?
  31. Sticky caliper causing bad tire wear?
  32. Camshaft issues-PTV, degreeing, etc.-Please experience!
  33. new guy from wisconsin
  34. 5.5" in. backspacing..15x10's or 15x8's? gettin greg welds cheap
  35. Bumpy Ride
  36. tokico hp's
  37. Need recomendations for cams on 04 GT
  38. Need upgraded brake advice
  39. Changing the oil in a mustang
  40. Did i need to install this with H&R SS Springs?
  41. PBR Brakes on 98 Mustang - Good, bad, or ugly?
  42. Procharger Venting to Atmosphere
  43. mufflers for a 97 with a bottle and blown
  44. Buying a 2000 gt with kenne bell supercharger
  45. Fuel Pump
  46. Dumps or not
  47. Need Help!!!
  48. I'm doing a PI headswap on my 96 Gt...got some questions
  49. Okay I got the codes for my check engine light
  50. Cam Help!!!
  51. O2 sims with cats.
  52. mods
  53. Mustang Valve Cover Question
  54. Still scratching my head
  55. Replacing rear blinker bulb?
  56. 3.90 gears
  57. New Radiator Support???
  58. Transmission question
  59. forged crank??????
  60. 110k matience?
  61. tuner questions.
  62. HELP, broken somthing....
  63. cobra fuel system swap and BAP limits
  64. O/R X-Pipe without aftermarket catback?
  65. Convertible Suspension - Track and daily driver
  66. Need some advise
  67. really high idle
  68. Clutch not disengaging
  69. Patriot Performance Heads - Do they still have problems?
  70. REMOVE 2001 GRILL
  71. TIMING HELP!?!?
  72. trouble codes???
  73. valve cover oil filler neck
  74. changing spark plug
  75. fuel gauge help
  76. is this the right walbro pump?
  77. Stock Intake Q
  78. MUSTANG cobra bumper help?
  79. 4v 2v?
  80. Need an egr delete kit.
  81. Lights question?
  82. Mach 1 Air Intake Question!!!
  83. Anyone have any tips for timing
  84. Top End with 3.73 Gears?
  85. starting issues
  86. Anyone have a tutorial for this...
  87. What would it take or is it possible?
  88. new motor. rwhptrq range?
  89. Car unleveled
  90. track suspension setup
  91. New cooling system complete and powdercoat.
  92. Whats the best was to 0 in on a squeak.
  93. Am I retarded? E-brake problem...
  94. CEL: Manufacture Fuel Air Metering Control
  95. Super Charges for 07 GT
  96. Rear-end "wiggle"...
  97. Rear Noise
  98. Patriot Stg 3 and N42 cam? possibly....
  99. 98 gt diablo sport tuner..need some help
  100. aftermarket k-member
  101. ROLLING FENDERS???
  102. steeda side exhaust
  103. Fuel Rails & Intakes...
  104. which sfc? and why
  105. Breaks Question!
  106. navi 5.4 heads?
  107. tranny locked
  108. Few questions bout tuning
  109. Nx wet kit ?
  110. HELP car idling a little rough
  111. Whats this fitting?
  112. Temperature sending unit locations *PICS*
  113. going from a 3.8 to 4.6
  114. STB help!
  115. Exhaust Leak
  116. Local Connection?
  117. O2 Simulator - New schematic and pictures
  118. I want close to 300whp, will this get me there?
  119. 96 gt what gears do i have?
  120. Removing power steering pump and having problems
  121. Can I clear a stage 2 cams??
  122. New from Ohio with car troubles!
  123. new fuel pump?
  124. AFR Question
  125. mustang gt 4.6 NEED HELP!!
  126. Need help fast please!!!
  127. x2 ball joints help
  128. Guys with 4.10's how are you keeping your trans cool?
  129. One Windsor, One Romeo head
  130. Opinions of this intercooler kit please
  131. Lazy
  132. stock exhaust
  133. i want IRS for my 2000 GT convertible- what will i need?
  134. SHIFT KIT
  135. Bad miss at idle and can't figure out
  136. just bought shocks and struts
  137. fixing foglight button?
  138. Who has measured piston to valve clearance
  139. Which gauges do I need?
  140. Reading AFR Gauge
  141. mil eliminator help
  142. new motor installed, Now rear wheel are no engaging!!
  143. new clutch questions
  144. Ipod in mustang. . .
  145. CEL help
  146. tune and dyno finally - numbers and video inside (soon)
  147. Head Bolt Kit and Gasket
  148. Canton 7q Oil Pan?
  149. keyless entry blinking fogs
  150. IAC Restrictor...does it work?
  151. seat belt locked
  152. Strut/Shock/Coilover Question
  153. worn out seat...new foam?
  154. Got a terrible miss at idle and no power
  155. Guage Bulb Question
  156. how hard is a head swap
  157. F*cked Up 3rd @ The Track...
  158. 2001 gt automatic to manual conversion
  159. what to go with dohc or sohc?
  160. Couple Suspension questions
  161. won't crank while WOT
  162. couple questions about my 4v 4.6
  163. Did someone make this hood functional? - *Pics*
  164. Cam questions
  165. Engine install help
  166. Flushing Power Steering Fluid?
  167. photo shopping
  168. Mustang Supercharger
  169. Hydrolock :(
  170. will any walbro pump work?
  171. Deleteing egr
  172. Headers
  173. Long Tube Install Problem Need Help
  174. Knocking sound
  175. How Much!
  176. wheel vibration!!!
  177. HID Help Again!!!
  178. 03/04 term parts cheap
  179. 96-98 gt ignition control module.
  180. side view mirrors
  181. Another coolant temp position option!
  182. Spec stg 2 or 3
  183. Anyone use this MMR Fuel Pump?
  184. 5.4L swap ??
  185. Possibly Intake Crack
  186. battery
  187. 4v navi heads
  188. Supercharged GT with COG PULLEYS???
  189. Windsor head spark plug wires
  190. I thinkin of blowing a ton of money
  191. squeeky noise in rear
  192. Window Rattle
  193. Keep blowing my rad hose under full throttle??
  194. What should my fuel pressure be?
  195. 4.6 Cobra vs 4.6 GT
  196. Clutch cable slipping!?
  197. Which shifter will bring the handle closer to the driver?
  198. cams finally! question
  199. seat match - up?
  200. GT pump and a BAP?
  201. Cobra brake conversion? What do I all need?
  202. What shocks and struts??
  203. zex nitrous kit
  204. Mileage or date opinions
  205. Need help with new mustang
  206. P-51 Cooling Mod
  207. Diablo Tuner
  208. ACCUFAB PLENUM TECH QUESTION/SALE CONCERN
  209. COMMON QUESTION..
  210. Check Engine Light/ PCM
  211. Flywheel-Replace/or not
  212. superchips
  213. How can I tell if used clutch/flywheel is good?
  214. 2003 mustang cobra rear bumper???
  215. BRAKES! Help :) rotors etc.
  216. Review my suspension upgrades
  217. Label on Head
  218. Change EEC for 4v swap
  219. one quick question
  220. Anyone running Ford B springs
  221. New Clutch/Fly installed, Quick Q on Adjstmnt
  222. converting a power driver's seat to manual
  223. Weird vibration, any idea?
  224. When i press the brakes it turns right,why?
  225. Starting issue, THEFT, No Fuel or Spark!!
  226. cracked intake at sensor mount
  227. 2001 cobra bumper conversion
  228. What Fuel Injector Is Needed??
  229. Fan Blade Question
  230. after pi swap low power and trans knock...
  231. Fuel Pump took a dump
  232. Question: PI head installation?
  233. 2001 GT = 300 miles per tank???
  234. DriveTrain Vibrations???
  235. which rear o2 sensor is bank 2?
  236. oil ?
  237. Caster Camber plates
  238. car knocking/fuel injector not working
  239. Exhaust help
  240. Need Help! 96 GT, not running strong..
  241. Moving the Temp Sensors.... Ox!
  242. 02 GT ticking at Idle- TImesert Issue?
  243. Headers/emissions q
  244. cigarette lighter
  245. Water Pump wheep hole locations
  246. typhoon intake manifold vs blower cams
  247. catted x-pipe?
  248. Cloyes Timing Chain Adjusters
  249. Cams, IAC mod, Tune
  250. Ported PI heads- New Cam or Advance Stock Cams
