View Full Version : 4.6 (Modular) Mustang
  1. Cams install
  2. HELP!! Idle problems
  3. tuner just broke
  4. ignition switch?
  5. new part's coming in
  6. diff cover
  7. Quite Pronounced Backfire
  8. x pipe install gone bad! HELP!
  9. tossing around some build options for my GT.
  10. 2002 mustang gt
  11. catback choice
  12. SCT Xcal2 custom live tunes
  13. Eliminating ABS?
  14. Clutch Replacement Guide?
  15. Innovate LC-1 Wideband Wiring?
  16. new to mustangs do i need a tune?
  17. 2003 Cobra Upgrade
  18. tapping intake for pi head swap
  19. How to quiet down my O/R H pipe?
  20. new DD wheels ?
  21. What is this X-Pipe? Help me identify this.
  22. PI head swap HP Gain?
  23. Project "Mary" underway....help me out a bit guys!
  24. 7-9 psi Vortech Kit??
  25. degreasing engine
  26. rear popping noise on 01 GT
  27. somthing wrong
  28. oil on plugs
  29. 300 hp
  30. Misfire from bad O2 sensor?
  31. Boost and A/F
  32. Dome Light Wont Turn off
  33. Weird Noise?
  34. Ever take a look at your undercarriage?
  35. Stalling and Idle problems
  36. Painting Calipers
  37. cooling problem
  38. Cobra Brake Upgrade ?
  39. K & N cold air intake or Short Ram?
  40. hooker maxflows
  41. new exhaust & fuel pump
  42. tsb 03-6-2 oil seepage from the head...:^(
  43. how many cats???
  44. Electric Cutouts?
  45. Convertible sub-frame connectors
  46. shutting off
  47. 03 sohc for a mach1 dohc complete engine swap
  48. Is my rear end going south?
  49. Finally cracked open the black box
  50. O2 eliminators
  51. 1996 cobra wheels
  52. C & L MAF w/o flange issues
  53. cheap motor...
  54. stripped slot in strut
  55. MIL Eliminator's or Programmer for Pipes?
  56. need a little help
  57. New Headlight Assembly?
  58. 02 gt clutch
  59. U/P ARE GARBAGE!!!
  60. Annoying Noise!
  61. Need a how to on cylinder head assembly
  62. harness ground
  63. Diablosport temp. injector tune?
  64. Noise after intake swap
  65. Will Stock 07 Mustang Rims fit on a 98?
  66. clutch
  67. Help on Timing Chains
  68. wiring in resistors
  69. screamin demon coils
  70. Where to buy this piece?
  71. Couple quick questions.
  72. pi head swap question
  73. help me please
  74. Question about exhaust.. ??
  75. sup everyone
  76. What PSI for 275/40/ZR17 tires
  77. OEM MAF Bracket
  78. Trying to get more Car Smart lol
  79. I fear I broke something again!
  80. Please help, squeaking when first started?
  81. Does anyone run open headers?
  82. Mid Pipe Im boggled!!!!
  83. MPH KB blower cams...
  84. Screamin demon coils
  85. 1999 Cobra Exhuast Setup
  86. Instrument Panel, new gauges
  87. lowering the car
  88. oil seperators for brand new 2v
  89. replacing the oil pan..
  90. help
  91. 2002 Saleen S281 Specs
  92. Shifter Handle Gets Hot?
  93. SVT Focus Pump
  94. where to hook water temp guage sending unit??
  95. mustang saleen warrenty is it worth it
  96. '96 GT basic brake & rotor replacement...
  97. Supercharge NON blown cobra??
  98. Lowered suspension noises
  99. Is this legit?
  100. Oval TB question?
  101. K&N FIPK CAI for 99-04 GT
  102. Clutch slave cyclinder or tranny??
  103. difference in npi vs pi cams
  104. Going to the track
  105. How does this sound...
  106. Head gasket--> compression ratio
  107. Automatic to Manual transmission complete!
  108. selecting suspension parts
  109. Fuel Pump Wiring Upgrade
  110. Replace or Upgrade the Brakes?
  111. please help
  112. Whats the best oil to use?
  113. Did all 2003 GTs come with factory superchargers?
  114. Did all 2003 GTs come with a factory supercharger?
  115. Help with Weird Vibration
  116. Swapping 4.6 liter for 5.4 liter
  117. Where are the spark plugs on a 4.6???
  118. Car wont idle
  119. P1131 Code
  120. VSS (speed sensor)
  121. Cams?
  122. n20 setup question
  123. Nitrous Wet Kit 150 Shot Requirements
  124. Narrowband A/F guage?
  125. MPG help....13mpg?
  126. Clunking noise in trans or rearend?
  127. HELP! Spark plug blowout w/ another prob
  128. Got Gas, Check Engine Light, misfiring????
  129. Question from the new guy
  130. grinding noise from the rear end.
  131. What K members can I use with a stock lowers?
  132. 2v vs 4v 4.6
  133. ugh- Camshaft position sensor
  134. over rev
  135. Tuning ???
  136. Diablo vs. Custom SCT Tuner or Nethier!?!?!
  137. Fuel Pump Noise
  138. Upgrading trans - launching concerns
  139. Help with offroad x pipe for a 1998
  140. Is it possible to supercharge and turbocharge?
  141. valve covers
  142. my windows wont work anymore help
  143. where to buy shift fork for 3650
  144. Calling all procharger owners
  145. 10th anniversary brakes are discontinued??
  146. DOHC combustion chamber volume
  147. New rims! what tire should i go with?
  148. Help with rearend gears and twinscrew supercharger
  149. Newbs guide to your first SN95...
  150. ROB AKA 2000AZ50GT and BLOWNSVT!
  151. alignment
  152. Idler/tensioner pulleys
  153. O/R X-pipe smell or no smell
  154. Too Slow
  155. Thinking of doing clutch install myself
  156. 8.8
  157. A little confused on tuning
  158. Stock H Pipe Help!!!
  159. 10% Overdrive crank, boost gains vs. pullying down
  160. Gear Question.
  161. Looking for 2003 GT Mustang Fuel Sender Empty and Full Ohms Values
  162. Auburn Differentials??
  163. Ignition coil question
  164. Any ideas?
  165. 180 thermostat
  166. pi swap might be pinging!!
  167. coil problems
  168. new edge mustang ride of the month nominations...
  169. Let's talk about return style fuel systems.
  170. How hard is it to drive a 5 speed manual GT?
  171. New Mid Pipe on 01 GT!
  172. 98 to 99 Engine Differences?
  173. trans swap??
  174. Will 315-35-17's FIT
  175. trouble code p1132
  176. Special Forces & SFS Scrape installed, base tune ?s
  177. Newb putting a '00 interior in daughters '96
  178. Weight reduction
  179. The Light goes On!!!!
  180. modding fuel system
  181. New grill ideas needed......
  182. lowering mustang question?
  183. Compression Test Results (Am I okay?)
  184. Tuning help
  185. Transmission problems
  186. Help calculating c/r please.
  187. 03/04 Mach 1 Springs vs. Steeda Sport Springs
  188. Anyone with a Hurst shifter?
  189. 4r70w to t-45 crossmember
  190. Im still having BOV issues
  191. JLT and strut tower?
  192. battery issues
  193. autometer install??
  194. clunking noise
  195. RESALE MUSTANG SALEEN SUPERCHARGED FOR PROFIT
  196. Untuned with Long Tubes...
  197. Spec stage 1 clutch?
  198. Transmission Help
  199. camhaft swap needed on new used head?
  200. Idle issue when in reverse
  201. Patriot heads, stg2, how has them...
  202. weird gas pedal "sticking"
  203. dropping the K what to do?
  204. Service Engine Soon - Code PO460
  205. Alum. Driveshaft for AUTO
  206. 3 bolt or 4 bolt C/C Plates
  207. bout to do pi head swap couple of questions
  208. Where can I get the piece of the mach 1 grill delete that covers the bumper holes.
  209. How do I remove rear o2 sensors without throwing codes?
  210. Can stock shifter bolts be reused?
  211. Can stock shifter bolts be reused?
  212. Help with Dash
  213. you guys were right...
  214. Throw out Bearing (plastic re design)
  215. 4.6 won't rev past 2500 and has NO power
  216. Transmission hissing while cold?
  217. Problem with BBK mid pipe for a GT
  218. hmmm worth a shot? lol
  219. Got a new short throw but need a good handle
  220. a/c and ps delete
  221. H pipe install
  222. code P0125
  223. Looking for Rims
  224. Will 11" Wheels fit on a 99 IRS
  225. Before/After painting Saleen supercharger 56k no way!!!
  226. Squeak/creak noise from front end
  227. Lower Control Arm features
  228. Not for sale yet but........
  229. A/F Ratio Gauges
  230. Quick question (Mach 1 and Termi block)
  231. Timing Help
  232. Automatic tranny fluid change
  233. stroker kit
  234. 4.6 pulleys Q
  235. Stripped Bell housing bolt!
  236. Figured I would ask the best
  237. Which shocks????
  238. New set of injectors
  239. Roots vs. Centrifugal!?!?
  240. Pilot bearing question
  241. EGR delete
  242. Winter Project is done
  243. 96 GT New Intake now runs rough
  244. I need a pic the stock h pipe
  245. Best bang for the buck under $300
  246. Best bang for the buck under $300
  247. Roots Tork Supercharger!?!?!
  248. 2003 GT Mustang 4.6 Anti-Slosh Module
  249. when to tune??
  250. Need some Help and answers!!!!!!
