View Full Version : 4.6 (Modular) Mustang
  1. Eibach or Stock/4cyl Springs??
  2. 96-98gt vs 99-04 gt
  3. JLT CAI question
  4. Is this worth The Buy???
  5. Engine Swap
  6. NEW CLUTCH
  7. Mahle Powerpak specs for 1997 Cobra?
  8. Cam and S/C labor hours
  9. Auto Transmissions
  10. do i have T45 or tr3650 ? 2001
  11. KENNE BELL VS VORTECH
  12. will sn95 exhaust fit a new edge?
  13. Where do I find 4.6 dohc torque specs?
  14. Black knob on iac
  15. KYB GR-2 for my Gt
  16. PI swap info
  17. TB and Plenum problem(after market)
  18. npi heads
  19. have a check engine light
  20. Drilling holes in the fuel basket (SVT Focus pump)?
  21. got a brake question
  22. 98 gt top speed with performance upgrades?
  23. 2000 ford mustang GT how much oil?
  24. Mach1 System?
  25. Help! Car turns over but won't start...
  26. T-3650 ~ T-56 swap with complete instructions
  27. AmericanMuscle anthracite bullitts...do they match stock?
  28. And now it's ticking...
  29. affordable, mild, cams
  30. URGENT PLEASE HELP!!!!!!!!
  31. do airbags from a sn95 fit new edge and other ?'s
  32. How many bolts is the windsor flywheel?
  33. Posting pics.. Need help
  34. auto transmission goes into neutral on its own?? is it blown?
  35. O/R H and super 44
  36. A shop in El Paso area!!!
  37. RPM Hang on 99 5spd GT
  38. new style rims for new edges?
  39. transmission help!
  40. SN95 Body Kit
  41. Rear end install kit question
  42. Low fuel light on with full tank of gas
  43. Stock drivetrain-How much can it take?
  44. recap on the nexus gauges!
  45. Trouble shooting help
  46. 96 mustang!! helppp
  47. 3rd gear and transmission problems !! help
  48. starting problem...
  49. supercharged or SVT?
  50. how do i....
  51. To Tune Or Not To Tune???
  52. Oil for guys with S/C
  53. Dyno or no?
  54. lowering spring questions
  55. HEADERS
  56. low oil pressure
  57. Back from a night at the track...looking for advice
  58. Suspension Upgrade
  59. cheapest place
  60. MODS: Please add to How to/Info sticky
  61. low idle after intake
  62. adjustable fuel regulator
  63. twisted my caster camber plate?
  64. Getting off the stock H?
  65. changing motors
  66. Axle swap
  67. 03 mustang gt delete tune?
  68. Brain buster...
  69. man to auto quest?
  70. Aluminum Driveshafts
  71. how do you brighten or dim headlights?
  72. Does anybody have a 4R70W transmission
  73. Radiator function?
  74. signs of a bad harmonic balancer???
  75. upgrading big 3
  76. Auto engine harness and ECU?
  77. Nothing helps
  78. gas mileage
  79. Help on Stall Converter!!!!
  80. New fuel rails leaking
  81. new hood painted??
  82. Rusty lugnuts ..
  83. c4 transmission in 02gt?
  84. Quick question about headlights.
  85. 4.6 missing at idle
  86. Clutch Adjustment??
  87. 8.8 rear in a mustang 1997 v6 please help
  88. Hydraboost question
  89. Question re: O2 sensors and offroad X-pipe.
  90. Not starting
  91. 2003 GT UPR O/R X W/ MAGNAFLOW WELDONS
  92. cams install help
  93. having a problem
  94. 99 Cobra for Sale (good deal)
  95. c-clip eliminators?
  96. Help changing headlight.
  97. Trans Rattling help
  98. Need help on dignoses of idle problem (with video)
  99. Im turboing my 97 Cobra Need some advice!
  100. Tremec 3650 how much can it handle
  101. 2001 Cobra Questions and Times
  102. Too much compression for turbo?
  103. Nitrous?
  104. changing motors?
  105. HELP!!!
  106. Summit upper and lower control arms
  107. New Transmission In.... kinda.
  108. WHAT IS POWERBALANCING??
  109. Edelbrock intake Questions
  110. Rear power window motor
  111. Missing part? and coolant leak
  112. 4.6 2v missfire, Please help!
  113. old school guy question
  114. best mod
  115. Little cam research
  116. Aftermarket radio wiring
  117. Lost resistance in steering wheel
  118. ? about whats next
  119. smooth tranny
  120. quick question about air filter and silencer.
  121. Miss in engine, Tranny problems
  122. Turn signals wont work and other slew of problems
  123. S/C air/fuel ratio
  124. Whose good with a multimeter?
  125. tuner
  126. Chip Keys
  127. hp and exaust question
  128. shocks and struts question
  129. engine overhaul gasket set ????
  130. diablosport Mafia question
  131. new engine
  132. Emission Legal
  133. Argh which catted X?
  134. 97 gt questions
  135. HID Question, Will This Kit Work??
  136. How much HP is this engine!
  137. Longtube Headers for Automatic Mustang
  138. spark plugs???
  139. Front Tire Locked up
  140. ABS light
  141. Weird "Dinging" noise!
  142. Turbo 4v setup quistion!
  143. intercooler question
  144. 2002 4.6 sohc
  145. 3.27 to 4.10 gearing question.
  146. Starter Removal Help
  147. Gear install cost
  148. cold air intake
  149. Romeo or Windsor?
  150. tailpipes
  151. Drive Shaft Question?
  152. tr6 spark plug gap for a supercharger
  153. Comparing Stock 4V Heads
  154. MAF..Do i Need one?
  155. Help car wont start
  156. Oil pressure numbers....normal?
  157. Vortech intercooling question
  158. I JUST DID A MOTOR SWAP
  159. 78K miles auto is SC safe
  160. Stall Converter Help.
  161. need help with oil leak
  162. PI SWAP DONE, NEED INFO ON TUNE
  163. How much of a gain am i going to see?? (Full exhaust)
  164. need help!
  165. vortech oil feed problem
  166. MIL eliminators
  167. Anyone else have this problem? (shift knob reach)
  168. 5.4 navagater swap
  169. Help with car will not start and blows fuse...
  170. noisy control arms
  171. I have 2 questions about tuning?
  172. adding boost...re tune??
  173. DS PREDATOR quick question
  174. Very hard to shift into 1st gear, please share some insight!
  175. 96 cobra
  176. Gear question.
  177. Brake Rotor Resurface?
  178. 2000GT is vibrating in curves
  179. Rear axles
  180. How do you clean the cylinder walls?
  181. Clutch adjustment problems
  182. Crappy Seatbelt Retractors
  183. Cams
  184. timing...
  185. Help me choose new set of tires (18")
  186. 04 cobra brakes in my 03 GT????
  187. upcoming engine swap
  188. Headlight knob
  189. Do I need to retune? Please help...
  190. engine needs rebuild
  191. Does this kit include Axle Bearings?
  192. 04 cobra gauges in a 03 GT
  193. Which cams?
  194. Grinding noise in the front.
  195. mistake during lowering
  196. crracked intake...i think
  197. Tubular K-member + Long tubes.
  198. 99 Mustang Cobra FOG LIGHTS
  199. Another Gear ?
  200. Quick Injector Question
  201. Need to figure out what exhaust
  202. damn wide tires!
  203. Installed the 4.10's!!!!!!
  204. roush shifter handle
  205. Gauge Cluster Removal ***VIDEO***
  206. cheap chips
  207. Wooooohooooooo!!!!!!
  208. dome light issue
  209. Clutch Help
  210. lowering springs/ clearance
  211. what's the difference?
  212. shorty headers
  213. Clutch cable help!
  214. Antifreeze leak in the back of the engine?
  215. is a motor swap carb legal?
  216. shifter install question...
  217. americanmucle
  218. gear question
  219. Leak at manifold/X-Pipe Connection
  220. coilover spring rates?
  221. Will 275/40 tires fit?
  222. 97 GT Speedo/Odometer Trouble---Any Suggestions?
  223. Does a check engine light rob power
  224. pushing stock block to limits, what combo is least stress on internals
  225. Long Tube Headers
  226. 2 wierd problems.
  227. how wide?
  228. brake upgrade??
  229. 01 Bullitt, Belt Change: Cannot get new (or old) belt on.
  230. Ihave a problem I think!
  231. Are 315's too much tire for me?
  232. Dyno sheet analysis needed!!!
  233. 2002-2004 Mustang GT/Mach 1 dyno info
  234. magnafuel fuel pump?
  235. How to; Upper and lower control arms
  236. Slapping sound from engine?
  237. Suspension Setup to support 400rwhp
  238. PCV with supercharger..
  239. rack and pinion question
  240. 1998 Mustang GT Electrical Problems
  241. Taking the mirror off
  242. High beam problem, possible short or break in light pig tail???
  243. Installation of HID's
  244. mach 1 gauges speedo off by 5 mph
  245. Brake light/running light mod
  246. Ford Service Manual
  247. chocolate milk look
  248. Tune up Questions
  249. trans swap?
  250. Changing out head light bulbs. Help...
