View Full Version : 4.6 (Modular) Mustang
  1. MIL codes help
  2. pinion snubber
  3. Stayed in first gear waaaaaayyy to long.(7krpm) Got a question
  4. gears and shifter install
  5. ticking 4.6 please help!
  6. Engine Coolant Leak
  7. About to buy a fuel pump for the build, 100% this is the one?
  8. Maximum Motorsports Aluminum Rack Bushings?
  9. info on lunati stage 3 high lift 2v cams
  10. Lowering with Fox body springs?
  11. Transmission clunk
  12. P0113 PO102.....WTF
  13. quick answer needed!
  14. Choppy whirring
  15. Driveline vibration/chatter
  16. Gauges resetting with every start
  17. temp/hvac control cable
  18. Removing Woodruff key
  19. I need to reset the anti-theft lock.
  20. Which springs for HP blower cams?
  21. 2002 gt
  22. What do i need for higher RPMs?
  23. Air/Fuel Issues...
  24. Intake problem that will not go away.
  25. need advice for Dropping a new 4.6 with longtube headers already installed
  26. 99 GT rear seats in a 97???
  27. will 03 powerdyne supercharger fit on my 98 gt
  28. Question for those of you with the VT/CMS stage 2 cams
  29. ppl using qa1 k member/stock arms please respond
  30. Whining from timing?
  31. New here and got a question
  32. urethane motor mounts, car shakes...
  33. Car Still wont run, anymore thoughts? Plz?
  34. How does this go back on? pics, Help!
  35. QA1 k member, please help, problems
  36. *390V8 Swap/2000 V6* (can it be done?)
  37. Rear diff whine and stutter
  38. bad plugs
  39. Scary Problem...HELP ASAP!!!
  40. belt swap w/vortech unit
  41. 1996 GT exhaust
  42. running lean under load
  43. how to prime an oil pump
  44. Loud Clicking Noise in 1st and 2nd Gear
  45. Cranks but doesnt start 1996 Gt
  46. oil press problem
  47. Advice on MAF,Throttle body & Pelinum
  48. running a nitrous setup-help!
  49. 96 gt rear caliper rebuild help.
  50. QA1 install and small accident
  51. Offset LCA's???
  52. what else should i do when switching out my transmission
  53. New Exedy USA 4.6L Clutches and Flywheels
  54. Steering Question
  55. p1sc install help in my 98 cobra???????
  56. Oil Leak...hmm..
  57. "Spongy" Brakes?
  58. Quick Brake Question (97 Cobra)
  59. P1SC vs D1SC
  60. diy cobra upgrade?
  61. K Member
  62. Coilover Spring rate question
  63. Functional hood scoop on stock GT hood
  64. slow 60's
  65. New pulleys coming, which belt?
  66. iat sensor
  67. Slicks 26" or 28"
  68. Vibration in Brakes, Steering
  69. Chip for nitrous? or tuner?
  70. fuel octane
  71. Fuel Injectors?? Header Install??
  72. better gas mileage?
  73. o3 cobra gauge illumination ?
  74. 5.4 2v to 4v swap
  75. Nasty Electrical Problem
  76. stuck lifter = misfire code?
  77. 3.73's on 2002 Mustang GT
  78. XYLENE as an octane booster
  79. wow trans down again in a month
  80. Crankshaft pulley bolts
  81. Strange Vibration/Noise
  82. Diablosport Predator Tuner for 2002 Mustang GT
  83. Car just died now wont run help please
  84. Clutch Question Please!!!
  85. 24# injectors?
  86. timing chain and oil pump help...
  87. Sudden Acceleration Issue
  88. Wheel help for a newbie.
  89. Clutch Question
  90. Header Trouble
  91. IRS swap.
  92. 1998 cobra wont start??? need help
  93. helix throttle body spacer
  94. Tuner issue?
  95. clutch chatter and engine vibration
  96. Headers install?
  97. Please HelP!! UDP Install problems
  98. Does this sound warm?
  99. brakes squealing help me!!!
  100. Eagle F1 All-Season
  101. First dumb questions from a Noob
  102. I have a leaning problem, please help
  103. little problem with nitrous tune.
  104. Just put in the O/R H Pipe. Is all this right?
  105. rearend?
  106. loose driver side mirror
  107. help guys! trouble codes!
  108. gain LOW END power?
  109. How to remove Dual Side Mirror Control Switch on 94-98?
  110. Car wont run, plz help guys
  111. Please help, engine skipping, running out of ideas.
  112. no power to radio and one HVAC blower
  113. reinstall temp control cable?
  114. CC plates needed?
  115. Speed Calibrater for Auto
  116. Wheel Bearing Load??
  117. stuck on stupid
  118. TR-3650 Output Shaft Spline #
  119. 8 Stack Fuel Injection?
  120. Fuel/Air Engine Light After Clutch Job
  121. rear end ?'s
  122. tinted tail lights
  123. Does your mustang?
  124. radiator swap
  125. 96 Mustang motor blew many ?'s
  126. what do you guys think
  127. shifter ratlle
  128. Head installed ?
  129. BBK O/R H-pipe Q's...
  130. '96 come with R134A refrigerant?
  131. npi to pi swap
  132. injector harness removal
  133. low fuel pressure
  134. Spun a bearing and not sure where to start.
  135. Questions about a Mark VIII Engine swap.
  136. need help quick
  137. what is the difference 2003 Ford Crown Victoria 4.6 sohc and a mustang engine.
  138. Turbos or supercharger
  139. Need Parts!! Engine Mounts and Oil Pan!!
  140. auto trans 2nd to 1st gear banging
  141. auto trans 2nd to 1st gear banging
  142. Bleeding the brakes
  143. Transmission drop...problems
  144. A/C Compressor Pulley Sparked and Lit on Fire
  145. Gears done and....
  146. clicking when I acclerate, 5-speed
  147. Time for a rebuild/new transmission? (TR-3650)
  148. cams and head swap
  149. Engine Noise, Need Advice!
  150. Rear caliper piston problem
  151. CEL problems W/ new 70mm TB and Ported plenum
  152. De sludging
  153. Creaking noise while turning the wheel
  154. Rear Caliper Issue
  155. HID help
  156. air bag replacement?
  157. Transmisson
  158. Is there a way to tell what gears I have?
  159. Update to my engine noise problem
  160. Exhaust fitment help
  161. quick vortech tech. question
  162. street and road course Sn95 shocks and struts
  163. Newbie needs some help!
  164. Tire blew out? What is this garbage?
  165. Hahahaha.. uhh suspension help please
  166. emergency brake
  167. Cracked intake manifold.....
  168. feels like somethings rubbing
  169. Water water everywhere.
  170. slp question
  171. vibration on deacceleration what's causing this?
  172. what would u do?
  173. intermittent tapping noise...
  174. two coolant sensors
  175. 3.6 pulley to 3.33 do I need a new belt?
  176. gear wear pattern
  177. stock ride height
  178. Idle dropping in my auto
  179. AC Condensation, holy crap i'm wet.
  180. Snow Tire Size?
  181. Acceleration flat spot / PI Swapped Confusion
  182. Auto Trans, What's your options?
  183. mgw shifter install
  184. airbag replacement question
  185. tranny rebuild question
  186. RWHP seem right?
  187. 2v to 4v accessories
  188. New gear end let go. Is it my fault or is the shop feeding me a line of crap?
  189. PA racing suspension
  190. 1999 GT Motor Swap?
  191. Supercharger safe to drive?
  192. Will this engine swap easy??
  193. Inside of the car is hot????
  194. Weird Idle
  195. Lots of questions
  196. ? for people with SFC's
  197. Car is steering HARD to the left
  198. Passing emissions with Long tubes and no cats???
  199. Clutch related: Throwout Bearing clearence!
  200. oem clutch cable mod.
  201. Help! Longtube header fitments!
  202. 4.6L engine tick
  203. trans spec questions
  204. Electrical Nightmare!
  205. Anyone try this performance intake for non PI motors?
  206. T-3650 Info
  207. trick flow heads..stock cams?
  208. Need Help Now 2003 mustang gt missing.
  209. Timing on 4.6
  210. clutch cable/quadrant woes.
  211. Will 315's Fit?!?!?!?!?
  212. 03-04 cobra supercharger question
  213. Short Throw Shifters (MGW mostly)
  214. Speedo Going crazy..Help!
  215. Installing gears tomorrow. Couple Questions
  216. swapping sail panels..help please
  217. Will a 1997 GT MAF work on a 2003 GT!?!?
  218. Passenger side window control not working
  219. 01 cobra/ mach 1 shortblock?
  220. Need some advice and opinions.
  221. MT broke 2nd gear! Best Option to Fix?
  222. Valve cover leak
  223. Predator Programmer
  224. HELP!!! VERT SUB BOX!
  225. Street/Strip tire help
  226. Slight miss on cylinder 4
  227. Help my car is bugging out??
  228. How do I check manual transmission fluid
  229. clutch question please help
  230. quick question about underdrive pullies
  231. buddy's cobra running like ****..help
  232. Good Or Bad Idea? (PICS)
  233. mach 1 motor - lifting eyes?
  234. S/C Help. How does the intercooler come into play?
  235. couple simple questions
  236. which transmission mount?
  237. battery terminal
  238. Help: IAT sensor... wtF??
  239. 01 bullit is idling to high
  240. Ignition Switch
  241. Clutch Replacement on 2001 Cobra
  242. need some info on the fuel pump
  243. Header question
  244. New to the Mustang World
  245. Snow Tire Size
  246. 88mm pro m MAF on 2000 gt?
  247. SES Light on on a 32k 04 GT
  248. Saleen Chin Spoiler?
  249. PI Swap and Intake Gaskets
  250. pinion gear removal
