- AFR question????
- RedAlertlb is good seller!!!!!!
- Special on BBK intake Plenum $109
- cabin air filter?
- Borla Side Pipes
- Mineral Grey stangs...let's see your rims!
- exhaust tip question
- SCT Tuner
- couple of basic questions
- Best intake
- Gear changes 1/4 mile
- headers nightmare!!
- gains from going catted X to a O/R X???
- what size nitrous shot
- tranny tremec question
- Ordered.....
- Good deal? Lowering springs w/ Struts & shocks
- Just a quick question
- ONE SICK COUPE
- why is it that...
- just makin sure
- spline axels
- roll bar or light bar for a 98 cobra vert
- bbk longtube+x pipe+ bassani cat back
- bumper inserts
- weld wheel balance?
- It's ABOUT TIME!!!!!!!!!!!!!!!
- Tuner question...
- tuning?
- 300 HP?
- First suspension mods?
- New pics
- Where should i install the wide band sensor???
- can the horn be rewired to beep twice instead of once when locked??
- Installing my O/R H 2morrow
- new to mustang forum
- What to do next?
- Exhaust clip question?
- 2v shootout
- mass air flow help
- need stock head and cam specs for 4.6 liter 2v
- New Pics of the car.
- Where to get New Valve Covers for 4.6
- PI Motor Question...
- Using remote to lock car, honk and double honk?
- Ford Performance B Springs
- PREDATOR TUNE-SLOWER THAN THE STOCK TUNE?
- buying a mach 1
- Ext. mods.... Pics and Vid.
- Patriot heads stage II vs Stage III
- Oil Change - Need Advice
- another dumb tuner question
- Another spark plug thread
- Foxbody Springs
- U/D Pulleys with Nitrous?
- gauges
- forged internals
- 98 gt, speedo off
- control arms???
- Need help
- got new bushings and shattered cobra oil pump
- Test to find out gear ratio
- Just bought supercharged 1998 GT...have some questions:
- Cold Air Intake
- Idle probelms
- Stang vs LS1 - Your Record
- The giggle gas is a comin'
- UDP and battery voltage
- California Emissions
- long block or used motor, or head swap
- Painting calipers
- p 51 intake
- shifters
- motor swap question, shock/strut question
- Pics..v6 reborn as v8
- what has 700hp and does 0-60 in 1.8 seconds? A production vehicle....
- electrical problems?
- hello eveyone here is my progress!!!!
- Realistic top speed with 4.30 with 4R70W?
- Part quality of link inside(ac condenser)
- advice on a new car....
- a funny tire review...
- PREDATOR DATALOGGING, ANYONE?
- Need to know bolt size
- another exhaust post
- Exhaust
- engine swap for a 4.6 SOHC
- WIN A FREE SHORTY ANTENNA!!!!
- ALARM, DOES IT HAVE ONE?
- shocks and struts
- BEST MOD YET?
- Great Deal on a Vortech v2 sq if anyone is interested
- CAIs and strut tower braces
- stock specs???
- exhaust
- H-Pipes and Headers?
- 7 cylinders? HELP
- 7 cylinders? HELP
- 1996 cobra supercharger questions
- CHECK ENGINE LIGHT IS ON
- Tires
- Leaky Brake Lines. Plz help.
- 2003 transmissions
- Car won't hold idle
- how much gain?
- boring her out
- Injector/ Fuel Pump?
- Spark Plugs
- Plug Gap
- McLeod Clutches
- My Roush or Mach 1?
- my engine, what to do
- rear end
- question on buying a tuner?
- throttle body idel
- Faster?
- finally got some pics
- PI Swap....
- CHAT???
- anyone have accufab TB/Plenum?
- Diablo MAFIA questions....
- 1st mod going on in the morning
- fluidyne auto 97-04 radiator cheaper than $405 out the door?
- Cecil
- Question about spec stage 3 clutch
- i saw a mustang...
- Need Help with choosing a short block
- DID SOMEONE DYNO TEST A C&L PLENUM RECENTLY AND GET HIGH HP GAINS?
- GOT CHROME!!!
- o2 sensor wiring
- what are the pi heads/intake??
- What do you think?
- eibach springs
- what should i do?
- New Pics Today
- 99-04 Blackouts
- Service Engine Light
- slicks and rims
- What Should i set my spark advance to?
- for code3gt
- restoring interior update w/pics
- Good deal on supercharger???
- ATTN: All Austin Tx area Mustang folks
- pics of my new wheels
- lowering my car ?
- Need some advice/tips
- Vortech V2SQ question
- Nitrous with a S/C?
- GOOD METRO DETROIT AUTO BODY/PAINT SHOPS?
- threw it in first instead of 3rd
- clutch question
- Upgrade mid-pipe, need tune???
- pro-kit?
- PI cams
- Im pissed, my A/C died!!!
- Carbonware has moved to a new location
- New Bullitt side scoops are on.
- Exhaust, not typical
- PI Heads
- Track Night
- procharger...
- 5th gear grinde.....HELP!
- Woodward Dream Cruise
- shifter price
- Need a little help guys come on in
- UDP's yay or nay
- 97 gt Shifting
- Spring Isolators or Not?
- 1/4 mile
- cam position sensor?
- Tire Size need help please!!!
- the fastest N/A stang!!!
- Fog Lights
- Shift Kit Heat...
- What do you run?
- (2)Tool Tickets Detroit 9/22
- My first install
- electronic speed cal
- daytona tonight
- Strut/Shock
- 4.10s are finally in
- PCV system
- so i changed my rear brakes
- close race??
- launching
- 03 Cobra decklid
- DOES ANYONE KNOW ABOUT THIS STANG??
- T56 swap?
- a/c acting up
- Clutch install
- Hesitation, stumbling, lack of power
- Stock H/P
- squeaking while accelerating
- Radiator replacement...
- check engine light
- Air temp sensor?
- 99-04 headlights
- HHHH PIIIIIIIIIPEEEE!!!!!
- GAS Question for 01 gt?
- O2 sensor a B#%*^
- blown fuses
- gears installation?
- Spark Plugs...AGSF 32P
- electric water pump
- Dyno results and questions
- cluch ?
- C&L True Flow Pipe (link)
- Rod/Piston swap?
- 1/4 mile times
- Question about Seats
- Driver's Side Window
- what rims would i need...
- Diablo tune
- torque spec
- x vs. h pipe
- My Wipers are cursed!
- Best suspension set up?
- series IV saleen, MAF, 2003 GT Questions....
- my home made sequential tailights
- WHAT ABOUT THIS?
- Progress on the coupe
- Hypertech power programer?
- pi ?
- mac LT header install
- Locked wheels
- mgw short shifter
- Which tuner:SCT or Diablo Predator?HELP!
- cracked valve cover need a new one
- CAI Help
- changing air filter
- shop installation question
- o
- taaaallll gearing
- OoHh Kenne!
- FOR SALE!!!!!! PLEASE DON'T MOVE
- car temp goes up with ac on?
- Need your Opinion on a New Car
- debadging
- 03 cobra exhaust clip
- blue oval performance
- Mach 1 Hood.
- exhaust clip
- Ebay CAI
- Are we in Jepordy?
- Tming Adjuster
- so i took my car to the dealer...
- 98 Tuner work on a 97
- exhaust install
- new numbers
- 25% HP Gain?
