View Full Version : 4.6 (Modular) Mustang
  1. Allright i'm stuck and need some help...
  2. how much to repaint the fender?
  3. Stuck in a rut need advice!!!
  4. Burning oil.
  5. PIC OF TIMING PARTS? DESPERATE!!!!
  6. Release lever where?
  7. What should be the votage at the fuel pump?
  8. questions on my 4.10s
  9. what about the damn 3rd gear?
  10. Threw another code p0340?
  11. new stang
  12. axle - cross pin
  13. Venting a little bit
  14. What gear (rear end) do I have?
  15. Carbing a 4v cobra engine
  16. new noise...
  17. Same fuse keeps repeatedly blowing.
  18. 6 trouble codes and no a/c
  19. Input on the Romeo Block vs. Windsor block
  20. rear end - axels??
  21. Airbag question
  22. Brake lights not working
  23. Fuel Problems with BAP
  24. Doesn't fire in first to turns
  25. Doesn't in first two turns of ignition
  26. Horsepower???
  27. Twin Supercharged Lightning
  28. remove dash
  29. Looking at an 04 GT, what do I look for?
  30. Rattle caster camber plates
  31. Kenne Bell 2.1L on stock GT
  32. 1 wheel burnouts? upgraded replacement part
  33. will a Vortech S-trim V-1 from a 98 fit an 01?
  34. Radiator support question.
  35. 04 GT rev limiter? Shift points?
  36. Quick Clutch question
  37. Valvetrain Rotating mass and power loss...
  38. CEL and problems starting
  39. Leather Seat Rip
  40. "accufab" huge single plate TB worth anything?
  41. weird vacuum issue?
  42. a question from the books..
  43. Relocating second temp sensor
  44. INstrument cluster
  45. Need some opinions on a car swap
  46. "cracked my intake"
  47. should i buy b heads?
  48. 2001 4.6 Timing
  49. 96 cobra rear sway bar, bolts missing??
  50. Replacing an axle, need advice.
  51. Seat Belt Alarm Disconnect
  52. Nitrous in a 98GT
  53. 3V motor in a New Edge?
  54. HIDs not working...HELP!!
  55. Serpentine Belt Problems
  56. flywheel bolt tighness
  57. Cobra Brake Swap Issue?Brake Gurus please
  58. UNDERDRIVE PULLEY Problem!!!!!!!!!!!
  59. SN95 Cobras vs New Edge Saleens?
  60. HP ESTIMATE????
  61. 99 gt exhaust install
  62. INtake plugging, need help NOW
  63. Engine Rattles in the morning?
  64. Speedo Callibrator ?
  65. Squeak while backing up and gear whine!
  66. HELP percy's seal-4-good gasket question
  67. Question about the diablo programer. (newbie)
  68. Installing Long Tubes and Modifying Mid Pipe
  69. Cams or more boost?
  70. Still have wheel hop.
  71. where to buy 03-04 Cobra irs..
  72. TriAx shifter position??
  73. clutch/flywheel
  74. No Response.
  75. Dieing when driving
  76. coil over systems?
  77. 1/8 mile race
  78. egr and pcv?
  79. torque converter and valve body
  80. SRA IRS Drivetrain loss
  81. Shift kit needed??
  82. 4.30 gears
  83. Who makes the best NOS system??
  84. New midpipe w/ headers??
  85. fuel injector cleaner with Supercharger?
  86. Lazy rear axel question
  87. 4.6/5.4 Swap
  88. 1998 GT Fuel Rail Leaking - help!!
  89. Fuel filler neck leaking like crazy on an '01 GT
  90. which wires
  91. Edlebrock Jr. 4.6 intake
  92. Trickflow Plenum and 75mm TB install
  93. How much boost...and still 93 octane?
  94. Boss. White smoke coming from exhaust.
  95. F/I plus GEARS
  96. Self-adjusting clutch?
  97. Cobra Mass Air
  98. Alum drive shaft
  99. Newbie with a manual tranny 2001 Roush
  100. Strange NO-Start dilemma
  101. Lack of Boost.
  102. 5.4L Questions
  103. Vavle Guide Seals...
  104. getting dyno tune wed. stock motor will 150shot be ok?
  105. Knocking Problems in head!!!!!!
  106. Okay.. Exhaust install
  107. Eibach Sportline Question
  108. good deal
  109. stock cobra to 5.0L longblock and bad MPG?
  110. question for my friend
  111. Expedition shortblock in a GT
  112. Last Opinions/help needed. Car performance horrible
  113. what all do i need for gears?
  114. SN95 needs a new fender. Any advice?
  115. Please explain proper gear accessories needed?
  116. Window Sticker & Other info?'s
  117. Help! Terrible tranny noise!!!
  118. what times to expect...
  119. DIABLOSPORT PREDATOR TUNER
  120. Interesting sound from my car
  121. BPV placement...
  122. help!!..play in sterrting wheel!!!
  123. 12" sub in trunk
  124. New Shocks
  125. 02GT rear axle - IRS swap question
  126. Short shifters
  127. ok everyone, what do you think?
  128. Timing advance on a stock 99GT
  129. Why won't this bellhousing detatch from the motor!!!!!
  130. HEADLIGHT PICS
  131. Ideas for the ULTIMATE exhaust system for my 98 mustang GT?
  132. Fox Lake P-51 Intake Manifold
  133. undrive pulleys
  134. Manual engine and auto trans
  135. im having problems with the transmission
  136. Which rotating assembly...
  137. speed cal. and gears...
  138. Inspecting Used supercharger...
  139. Clearing Up Issues with Mid-Pipes
  140. question about steeda lowering springs
  141. rpm
  142. Tranny Pt.2 Help Needed!!!
  143. Running rich after high boost / rev
  144. The Rev-Limiter
  145. Head Swap-fuel line removal tool??
  146. Questions about xcalibrator II programmer
  147. code p0401
  148. HELP! Replacing pads.
  149. E/T street radials with stock rear end
  150. looking for SLP race pipes post if u know
  151. Best Exhaust setup for a 99 Cobra?
  152. Is my clutch going?? Idk what the Fakc happened
  153. Vinyl Taillight Outlines
  154. SCTX2 93 Octane Tune - what does it do?
  155. de-stroking a 4.6
  156. 98 GT ORANGE TOP INJECTORS ? LB
  157. Traction control indication
  158. Down shifting
  159. Joke gas mileage
  160. PI Swap Question??
  161. Help? Whats should be next for the Stang?
  162. missing 1000-1500rpm.
  163. 4.6 Information
  164. Sloppy shifting
  165. when cutting front springs, which side do i cut?
  166. Mustang Tranny
  167. H pipe install tips?
  168. Rough Idle, Acceleration
  169. Knocking..need opinions
  170. Exhaust Experts please help
  171. MAF gutting?
  172. f250 4.6 and mustang 4.6 ?
  173. Engine RPM vs Speed
  174. Is this a safe idea?
  175. QUESTIONS!?!
  176. any transmission removal technique?
  177. Spark Plug Blow Out???
  178. Are Coil Packs worth the money?
  179. I need a 3 core intercooler please help!!
  180. good or not?
  181. Car stuck in open loop????
  182. How to change headlight bulbs?
  183. where to buy the timing chain tool?
  184. Speedometer Gear
  185. selling tko600 to friend with 4.6 bellhousing?
  186. Going to the track, What should i take out to lose weight
  187. New Tremec Trans
  188. IRS, who has swapped to it??
  189. Transmission Trouble (TR-3650)
  190. Diablosport help
  191. need info on swaping a 5.4 into a 00 GT
  192. Im stumped.
  193. Buying C Springs
  194. bad fuel pump
  195. 3:73's to 4:10's
  196. Problems idling/drivability
  197. Anderson Power Pipes
  198. headers
  199. New fluidyne radiator, now i need help with a fan.
  200. Most subtle lowering springs?
  201. any gains of msd coil packs?
  202. catback suggestions?
  203. Long tubes
  204. Help! Problems all at once!
  205. Looking for a nitrous kit
  206. Slower turn signal flasher?
  207. MSD digital Window Switch problems cont..(vid)
  208. zex tps switch issues
  209. Brake Swap, Putting Cobra Brakes on GT - Help please
  210. Recommendation for power steering coupler
  211. TKO 600 and Procharger, and how much boost?
  212. PI heads on my 97 GT
  213. auto for 5 speed
  214. I HATE THROWOUT BEARINGS!!!
  215. h&r sport springs vs h&r super sport spring
  216. AUTO TO 5 Speed
  217. I found the answer to the clutch squeak!
  218. Weird (grinding) sound already =(
  219. Throwing Code P0307
  220. not starting first try
  221. 2000 Mustang GT Problems
  222. Hesitation..then oil smell ??
  223. What trans' will bolt up to 96 gt?
  224. O2 Sensor Length???
  225. o2 sensor?
  226. NEED A SHORTBLOCK!!!
  227. 98 mustang gt AOD trans.
  228. Car sits higher after tokico struts?
  229. Ported heads or cams?
  230. Misfire in the engine !!!! PLEASE HELP !!!!
  231. fuel pressure problem
  232. couple questions
  233. HELP with front Struts/camber kit problem
  234. bullit intake on a gt
  235. Im thinking of switching to a Mach 1, is it worth it?
  236. rear axle leak?
  237. headlight issues!!!!
  238. Would anyone buy and install used gears?
  239. WTF! clogged fuel tank?
  240. a couple of questions for you pros out there
  241. stock h-pipe has 4 cats?
  242. mongoose kit
  243. Grease or no grease on T/O bearing retainer?
  244. help.will o3 eaton bolton 4.6 lincolnmark eng
  245. will eaton s/c from cobra bolt on lincoln mark
  246. the plan.. now need $
  247. UPGRADING BRAKES
  248. 2002 GT 1/4 Gears
  249. thinking about buying a 98 cobra
  250. Rotor question and a couple of pics
