View Full Version : 4.6 (Modular) Mustang
  1. So I finally did the gas pedal mod...
  2. Cheap CAI question...
  3. Ford GT Pump
  4. BATTERY??
  5. 97 gt temperature
  6. stallion edition mustang?
  7. Need help with o/r H pipe
  8. MGW shifter stops
  9. Stock Throttle Body
  10. car cover recommendations...
  11. broke my car.
  12. $3000 to $4000 to spend...what should i buy?
  13. Grantelli K-Member Kit Install
  14. 2v owners WITH cooling mod
  15. vortech blown cobra loves to hesitate help me
  16. J-Mod?
  17. MORE SCT X3 PROBLEMS
  18. Foxbody Springs on a "New Edge"
  19. Torque specs and sequence for lower intake bolts
  20. turbo, vortech, and kb 4.6
  21. tuner question need opinions
  22. Rear end noise, I got video need ur help please!
  23. Check Engine light on
  24. I have the following OBDii codes...
  25. Convertible top wont go down
  26. 4.6 to 5.4 swap
  27. Code P0420
  28. suspension
  29. shift kit
  30. What's it worth?
  31. California Special...
  32. Replacing AC compressor.. need help
  33. Big Problem
  34. 01 Cobra or 03 Mach?
  35. NEED HELP !!!!!!!!!
  36. transmission question please help!
  37. stock terminator power?
  38. auburn ected...best diff?
  39. What fan temp values?
  40. port and polish
  41. pictures
  42. SCT SF3
  43. Cooling issue.. update:new Problems
  44. Set on Procharger
  45. is there a way...
  46. Odometer stopped working....
  47. car stalling out while moving
  48. rear end
  49. Front end squeaking like a mouse
  50. Air intake tube
  51. worth it?
  52. should i swap in my 4:10's
  53. engine cuts out @1800rpm, '03GT
  54. Ugly Squeal + New Symptom
  55. Best Short shifter??
  56. DIY tint kint
  57. KB vs. Saleen Series IV
  58. Idle RPM not constant
  59. GEARS
  60. supercharger
  61. I need help spending my money. . .Camshaft advice
  62. Idler pulleys and timing chain
  63. 6.58 1/8 mile ET @ 101 mph Video !!
  64. Bad power loss
  65. Engine oil in the Coolant
  66. Maintenance Questions
  67. need help Kenne Bell..
  68. ATTN: yellow034.6
  69. bought a vortech v-1..
  70. Trouble starting when engine is warm.....
  71. What do power pipes do for fi
  72. Major Cooling problem... I think?
  73. coolant leak in cab
  74. tire pressure
  75. tranny ?
  76. WHY?
  77. stock h w/o cats
  78. custom turbo headers and valve spring tip, pic added
  79. PI Cams.... help
  80. White Smoke Comming out
  81. My GT... Finally finished
  82. Suspension noise after lowering
  83. real quick driveshaft question
  84. Quick tranny question
  85. PI CAM AND INTAKE SWAP
  86. Procharger people answer me this.
  87. !Need an answer fast!
  88. 5.4 stroker.
  89. AC Problems!
  90. Fair asking price for a 1996 Mystic Cobra
  91. Engine stutter please help!!!!
  92. Pro Motion T45 help...
  93. My Mistake please help
  94. newly added
  95. Built Rearend Which Brands?
  96. loading brenspeed tune PROBLEM
  97. procharger concerns!!!!!!!!!
  98. PROS and CONS
  99. Trouble code P0411?????
  100. potential problems??
  101. Lower inake gasket leaking again!
  102. pro modular performance?
  103. How to get emblems off trunk?
  104. My quarter mile time
  105. Are these headlights any good?
  106. PI head non pi head valve lift question..
  107. Off Road X-Pipe
  108. pistons....engine builder....no VT
  109. Eaton M112 kit on 96'-98' 4V ? Already Purchased
  110. my 2003 GT auto... anyone want to trade?
  111. someone educate me on stroker kits.
  112. Time to replace the fuel pump?
  113. that one hurst shifter
  114. 8.8 rear all assembled
  115. Starting Car w/o Belt Attached? Update
  116. Made some minor changes to the little 4.6 turbo
  117. plan B!
  118. throttle body question
  119. gsxr 600 wants to race GT
  120. 80,000 tune up???
  121. Throttle body and Intake spacers....
  122. idle issues
  123. Kenne bell vs. prochager stage 2
  124. tire gets loose...
  125. MOVED: Black hood scoop and spoiler on Sonic Blue?
  126. cams
  127. Bullitts
  128. hurry xpipe ?
  129. free revv mod
  130. Tires rubbing when turning.
  131. Help-Bogging
  132. changing valvesprings
  133. removing hood scoop
  134. FULL EXHUAST SETUP HELP!
  135. VT stage 1cam lift specs UPDATE***
  136. Camber Bolts?
  137. 02 Mustang GT
  138. I have 2 questions I need answered
  139. mustang buying help
  140. Can someone help me understand?
  141. The thing isn't TOTALLY shot...
  142. Steeda Mustang?
  143. will ford do gears
  144. Exhaust question
  145. So I'm ditching the side pipes.
  146. What Fuel Pump?
  147. so there i was.
  148. is race fuel worth it
  149. Oil Pressure problems
  150. Another boring bolt-on post.
  151. Building my Heads
  152. HAving problems with tire size's!!!!
  153. Lowering question..
  154. For all that wanted to see the dyno chart
  155. Tapping/knocking at around 2000rpm's
  156. superchager guage ?
  157. A/c Refill Location???
  158. 03-04 cobra
  159. ***CLUTCH CHATTER*** ???
  160. Is supercharging worth it for a 2valve
  161. 180 degree thermostat install
  162. 93 Octane Tune
  163. need help what is it?
  164. trans and clutch problems
  165. Pulling the Trigger on KenBell S/C
  166. lost transmission bolt help needed asap
  167. What is that screech?
  168. oil weight?
  169. best mod to get
  170. Nitrous on the 5.4????
  171. What all do I need for gear install?
  172. Who knows about motors?....
  173. squeeking problem
  174. Brake Problem
  175. pi heads or just cams
  176. roush supercharger fitment question
  177. supporting mods for supercharger, lots of diff questions
  178. Need Performance Mod Help!
  179. cattted pipe for long tubes
  180. Removing spare tire for weight - good idea?
  181. please help
  182. 4th ver 5th Gen Stangs?
  183. Tuning advice?
  184. code pulled p1443? need help!
  185. coil pack
  186. Broken crankshaft pulley, need help asap.....
  187. Harmonic ballancer issue
  188. Starter issue
  189. please help
  190. Disconnecting GT Muffler
  191. pi head swap question
  192. Oil type
  193. Pop/ Tick noise
  194. please help... wire
  195. Noob question! Sorry!
  196. I need a new belt.
  197. Head swap question
  198. DELETE THE OIL COOLER?????
  199. What's going on...?
  200. which tool...?
  201. Single Wire MILs
  202. brake upgrade
  203. subframe connectors
  204. 96 cobra
  205. bullitt intake swap
  206. Hmmm.. idk
  207. Aftermarket TB/Plenum Hanging idle/low idle issues!
  208. Head swap question
  209. New and Have some questions
  210. spec clutch?
  211. AGX KYB adjustables
  212. Differntial??
  213. dyno
  214. Which Throttle Body?
  215. Need help troubleshooting please.
  216. How do you jump the fuel pump?
  217. Tuner Advice
  218. tire size
  219. It's Back !! Forged Rotating Kit
  220. 1999 supercharged GT cobra motor $2500? WTF!!!>??
  221. check engine light..pulled code need help!
  222. If I should buy this 2000 GT
  223. Anybody have this yet?
  224. Who makes the best shocks?
  225. best differential
  226. gas mileage
  227. what is needed to build a rear end
  228. Filler tube gasket replace?
  229. diablosport/deltachip question???
  230. mustang forums disccount code?
  231. More pictures from the last post on the New Trick Flow Modular items.
  232. 98GT Battery/ ALT ISSUE
  233. TRICK FLOW NEW 2V & 4V MODULAR FORD PARTS
  234. Removing Spring Isolators?
  235. Suspension Install
  236. put new rims on
  237. exhaust bolts
  238. Not the normal "gears" question
  239. 5.4 pi heads?
  240. my mustang exploded!
  241. HELP HELP HELP 5.4
  242. Safe NOS Kit??
  243. Where can i find a gas tank?
  244. Saw an amazing Cobra, I think. . . .
  245. smokin a T/A
  246. fiberglass hood
  247. What bolt-ons will get me to the RWHP of a z28?
  248. CAI
  249. What will work with my BBK Long Tubes?
  250. lower intake, best deals?
