View Full Version : 4.6 (Modular) Mustang
  1. 100k miles should i change oil weight?
  2. Sparkplug shot out of my head!
  3. 02 sensor color
  4. How do you adjust the "rolling idle'
  5. Help convince dad for 4.10's
  6. 2001 Saleen GT with 40k miles wether or not to put procharger
  7. Please - HELP! (Exahust Issues)
  8. Anyone with a procharged 03/04 cobra
  9. brake/power steering loss on 96 GT convt
  10. 3.75 crank
  11. Making hood scoop functional?
  12. Another ticking noise Thread, Help seriously.
  13. hey guys i have some questions about buying a mustang!
  14. z-28 camaro
  15. Are these Borlas in good condition?
  16. knocking on startup
  17. T45 Wiring Harness Question
  18. 01 cobra mods
  19. Summit Underdrive Aluminum Pulley Kit
  20. 96 Convertible Lift Cylinder question
  21. Intake Manifold blew out
  22. Check engine light?? help!!
  23. will 315's rub at all?
  24. Track Time
  25. 2v to 4v heads
  26. how much should i offer?
  27. Fitment issue?
  28. Tires rubbing struts, uh oh
  29. Bullitt Alternator in 02 GT?
  30. Need advice on future mods....
  31. wide tire with stock rim.
  32. Where to place jackstands???
  33. Kenne Bell BAP install write up?????
  34. ? about my Nittos
  35. Will 205/65-15 fit?
  36. 4.6 engine
  37. Driveshaft
  38. what is the usual gain at the track after installing 373 gears?
  39. BBK Throttle body Plenum all in one.....Any good?
  40. what not to do .
  41. Who Wants to See a Broken Timing Chain Cover
  42. Lookin for a 03-04 termi! help me look!
  43. Rough estimate of cost on BBK Shorites
  44. Just back from the strip and now another question
  45. TF Underdrive Pulley's:
  46. fuel pump question
  47. Is it wise to buy a 2001 mustang gt saleen clone with 101000 miles with a salvage title?
  48. Seafoaming?
  49. Spec Clutch problems
  50. flowtech header on my 98 GT
  51. RPM surge issue
  52. Gas Tank
  53. Auto Question
  54. Anti drainback oil filter for 2003 GT SOHC
  55. Loudest Exhaust w/ stock H
  56. ABS & traction lights
  57. SCT TUNING QUESTION
  58. Free mods??
  59. Help with low rpm misfire
  60. Just bought Bullitt brakes.
  61. 1/8th mile questions
  62. Need help?
  63. o/r x for long tubes
  64. 03/04 Cobra Hotchkis CC plates in an 02 GT Vert?
  65. Misfire or Clutch-Slip??
  66. Stage 2 SPEC clutch feel
  67. Sniper Locked Up?
  68. ball joint lower
  69. Location of Anti-Theft Control Module?
  70. Off Road H help
  71. car seems slower?
  72. Stupid O/R H, i want it louder
  73. Intake manifold bolt is stripped
  74. First real car
  75. BROKE THE TIMING CHAIN COVER, **** IT
  76. Heads and cam install
  77. Stalling and burbing I need help
  78. Headlights?
  79. difference between prochager p1sc and stage 2 p1sc
  80. Alternative Auto....?
  81. Bad Belt Tensioner?
  82. electric water pump with underdrive pulleys
  83. N/A
  84. 1996 Transmission question HELP!!!!
  85. CLUSTER SWAP/NEED HELP
  86. Gears and recalibration of speedo?
  87. brakes
  88. Upgraded Brakes?
  89. no power to the fuel pump
  90. pi heads
  91. No power going to solenoid??
  92. Lost my suction line valve cap!
  93. rebuild
  94. Thinking about removing mufflers, leaving stock H
  95. mustang vs 335
  96. Fog Lights
  97. Steering (Ackerman Angle)?
  98. Prochamber/Flowmaster exhaust clips
  99. SSA & SSB shift solenoid
  100. What is my compression ratio?
  101. Painting Spoiler Flat Black?
  102. NEW BBK 78mm Throttle Intake
  103. I want to see: NITTO 305 35 18
  104. f1
  105. New question. Power
  106. PowerDyne SC for 1998 4.6L 5 speed?
  107. HELP ASAP - MAJOR GAS LEAK AT TANK!
  108. Cushman Cams???
  109. sumitomo
  110. 2000GT Auto to manual Swap!!! HELPPP
  111. Mac Prochamber midpipe install question
  112. PI swap
  113. aluminum sheetmetal radio delete 99-04 mustang
  114. aluminum sheet metal door panels for 99-04 mustang
  115. Quick Q's about 3.73 gears, clutch slipage, and licnese plate lights
  116. Is this a good price on a pypes xpipe?
  117. Redesigned Intake Questions:
  118. Tint Question for VA stangers
  119. how much can it take?
  120. throttlebody differences
  121. MAKING MY 99 FASTER W/OUT NOS OR SUPERCHARGING IT
  122. Headers!???
  123. brake line / brake bleeding
  124. Romeo max?
  125. E85
  126. 02 gt idling problems, please help
  127. Crower Cams?
  128. Forged Internals + Supercharger
  129. I think i found my problem...
  130. Pictures Pleaseee!
  131. pi swap 98 VS 99@up gts
  132. 2000 Mustang GT needs new Clutch, suggestions?
  133. O/R H-Pipe
  134. SCT X3, IS IT WORTH IT?
  135. Hard time selecting drag tires or slicks
  136. CMS Stage 1 N/A Cams
  137. Throttle Cable Slack...
  138. HID headlights
  139. SCT Livewire said it only has 1 unlock left....???
  140. where to get..
  141. Intake Manifold Gasket Replacement
  142. quietest aftermarket catback?
  143. Fumes in car
  144. strange smell
  145. SCT X3 Installation
  146. New thread...quick question
  147. Sniper Tuning Question
  148. LSD Question
  149. Repainting Questions?
  150. Battery Light:
  151. Teksid Questions
  152. throttle body PROBlems
  153. List of parts for a full rebuild on the rear end ??
  154. whats everyones...
  155. X-Pipe without cats. Can I pass emissions?
  156. Longtube Headers?
  157. complete pi engine swap?
  158. altenator upgrade
  159. Stainless Steel System's catback
  160. P0340 cam position sensor
  161. Coolant leak?
  162. M/T skinneys
  163. wheel spacer 7/16" for skinneys
  164. 1st gear problem
  165. NEED TECHNICAL ASSISTANCE
  166. how fast 98 cobra
  167. I'm confused about shortblock info?
  168. Manifold Gasket Cause Coolant Leak?
  169. Best place to buy procharger kit
  170. supercharger ?
  171. Will CDC shaker kit fit aftermarket plenum?
  172. Cheapest place for borla stingers?
  173. Horizontal Damper/Kicker Shocks
  174. Looking at a GT...best fuel economy and winter driving??
  175. Annoying Problem!? Please help
  176. gears?
  177. Anyone running livernios stroker kit?
  178. Boy was i Took!!
  179. Interior lights wont work!!!!
  180. 00 GT FUEL PROBLEMS
  181. need help with DTC P0201
  182. Eibach Springs? Pro-Kit?
  183. Royal Purple + Vortech
  184. best clutch/tob
  185. My Idle Is All Jacked Up!
  186. MSD Ignition
  187. just got gears and really loud
  188. Got some questions??
  189. Dents and Dings?
  190. Finally i got a video of the cams!
  191. best plugs for mild bolt ons
  192. Update: Intake NOT Cracked..Why Leaking???
  193. pcv
  194. Future Plans.
  195. 1998 to 2004 cd player swap?
  196. Steering noise w/video
  197. Coil-Overs
  198. MACH 1 RODS?
  199. Twin turbo kit for an '02?
  200. SVT Focus Pump Question
  201. s/c pistion question
  202. Need advice on powersteering
  203. need advice with a d1sc headunit
  204. someone kicked my taillight
  205. My story
  206. BEST TUNER?
  207. Vortech V2.... SQ??
  208. Quick Question about brake fluid
  209. SLP Exhaust Question:
  210. door alignment
  211. SICK Cobra Mod
  212. SNIPER TUNER SOFTWARE @ PI SWAP
  213. Harmonic balancer ?
  214. spec or ram clutch?
  215. Injectors??
  216. Bad wrist pin = new pistions
  217. will 99-04 center console fit on 96 mustang?
  218. idle problem after pi intake swap
  219. when to stop...
  220. Wind noise, how to adjust door?
  221. GT to Cobra Upgrade!!!!
  222. UPR Coil-Overs
  223. What tire pressure should I be running my nittos at tomorrow?
  224. need help pi swap
  225. Terminator Cobra?
  226. Powerpipes and S/C'ers
  227. BIG PROBLEM! need help plz
  228. Wing Delete: Just bought a 95 GT
  229. BBK clutch cable quadrant need help
  230. Starter Removal
  231. Check engine light!?
  232. Dual-Stage Rev Limiter
  233. engine swap
  234. suspension clunk
  235. Diablo Tuner
  236. What kind of blower is on this stang? (vid)
  237. need help with boost guage
  238. 03gt exhaust
  239. X-Pipe/H-pipe
  240. Small problem after IAC mod
  241. MIL eliminators?
  242. 2v L/T's Which ones?
  243. Should i get a tune...?
  244. 02 GT with "older" style water pump?
  245. Difference...
  246. Which cobra bumper? 99/01 or 03/04??
  247. H pipe keeps leaking on driver side.
  248. What the heck???
  249. do i need bigger injectors?
  250. Having problems idling with cams!
