View Full Version : 4.6 (Modular) Mustang
  1. MIL eliminators?
  2. 2v L/T's Which ones?
  3. Should i get a tune...?
  4. 02 GT with "older" style water pump?
  5. Difference...
  6. Which cobra bumper? 99/01 or 03/04??
  7. H pipe keeps leaking on driver side.
  8. What the heck???
  9. do i need bigger injectors?
  10. Having problems idling with cams!
  11. Applications for supercharger?
  12. what 2 do next?
  13. Removing factory Emblems and Spoiler Help!
  14. Installing Sending Unit
  15. shakey?
  16. Lazy Question: Intake Removal
  17. Intake Manifold:
  18. suspension
  19. 01 gt diablo tuner monitoring
  20. ALRIGHT THIS IS AN ALL HANDS EVENT!!!!!
  21. A/C HOSE?
  22. PCM question
  23. Steeda Clutch Kit..
  24. exhaust
  25. Getting the suspension now how do I make some power?
  26. Stick or Auto, Advice please!
  27. Dome lights will not work!!! help
  28. Used Superchargers!
  29. H pipe "bolt kit"?
  30. Idle control valve
  31. 4v & S/C with a S/C 2v tune...
  32. Patriot Stage 2 heads Comp Cam, worth it?
  33. changing t-45 fluid
  34. Thinking about getting a mod 2v....
  35. QA 1 K member
  36. Anyone have a predator log file?
  37. O/R in Houston
  38. Need Help Painting Interior Pieces
  39. SOHC swap
  40. Where can I find a good rebuilt T45?
  41. Jack Points
  42. Getting T45 out of reverse
  43. 2v off road x pipe
  44. headers or udp
  45. Hood Decal
  46. Grille Options????
  47. If it can F8CK me, it will.
  48. 2001 PI intake on sn95
  49. Can I fit 275 nitto 555r's on my 17x8 rims?
  50. brakes
  51. clutch curiosity
  52. Fuel pressure question
  53. HELP! Check Engine Light Code Diag
  54. Clutch Help
  55. TPS setting???
  56. Car having trouble idling...and sometimes stalls
  57. Belt Tensioner Question?
  58. Redfire With anthracite deep dishes!
  59. will it fit?
  60. how many miles to allow for break-in
  61. Dies on warm start?
  62. Termie Swap Runs! BIG Props to wolverine!
  63. CEL Question
  64. Electric Cutouts
  65. Installing performance chip
  66. Replacing front calipers
  67. Auto trans fitment
  68. Steam coming out of ac vents? What can it be?
  69. to supercharge or not
  70. parting out 97 gt coupe!!!!!!
  71. Did I mess up my tranny?
  72. whats next?
  73. Floor mats
  74. Misfiring problem
  75. Clutch
  76. traction control
  77. need help on fuel guage hookup.
  78. tps
  79. TR-3650 trouble
  80. popping sound??
  81. a/c prob
  82. mil's
  83. Sniper Recon fuel trim fix...
  84. Which Nitrous kit to get?
  85. new to here
  86. best thermostat to run
  87. Slick Sizing
  88. POS 3650. replacing 2nd gear syncro
  89. head swap from a police interceptor(crown vic)
  90. 8 or 6 bolt flywheel?
  91. Quick lifter question please
  92. Coils Helped to a Point
  93. Cobra brakes on GT, whats needed?
  94. Cooling Fan temp question
  95. need a quality racing engine w/ warranty
  96. What size wheel are these???
  97. tsp
  98. Problem Expert Help:
  99. New 3.73's and rebuilt Facotry LS Unit
  100. SLP Exhaust Pipes
  101. NITROUS TUNNING
  102. HOW-To: Baer 13inch rear brake upgrade.
  103. Gauges-ADDT Question
  104. crank pulley
  105. Clutch Problems.....
  106. borg-warner vs tremec
  107. do i need new fuel injectors
  108. Sumis?
  109. exhaust help
  110. car started a ping from engine
  111. Clutch squeak... stops when i apply slight pressure to clutch.
  112. Torque Converter
  113. Rear Noise - help me determine what it is
  114. Rear Bumper Removal
  115. Trans flush at 30k?????
  116. speedometer sticking after gauge install
  117. alarm/lock issues
  118. running lean??
  119. safe to supercharge??
  120. girdle
  121. Stupid Mid-Pipe Question
  122. What size fuel injectors?
  123. Raising redline?
  124. Cruise Control OUT
  125. obx cam gears
  126. Spun Bearing...
  127. Radar Detector
  128. A/c works but...
  129. Cam install yesterday! UPDATE!
  130. Need new tips
  131. True Blue Color?
  132. Noise from CC plates? Top of struts?
  133. svt pump
  134. Are the coils supposed to do this?
  135. Hooked on tuning. Tuners a PIA. What to do.
  136. short tubes or long tube headers
  137. MOVED: a little off topic...
  138. I need advice with valvetrain noise.
  139. Timing Cover Queston
  140. MAC H-Pipe...any good?
  141. MOVED: rpmoutlet.com
  142. remote mounted turbo ?
  143. Possible electric problems? newbie needs help
  144. Suspension Questions
  145. clutch
  146. Starting Problems
  147. anyone have a supercharger on daily driver
  148. Mid pipes!
  149. Spray-on Smoked Color Lens Paint
  150. Anyone have link to installation instructions for accufab plenum?
  151. Anyone with the Drag pack from RPMoutlet?
  152. best sounding exhaust?
  153. Catted X or Catted H???
  154. Pi swap and gears
  155. code P1151
  156. throwout bearing help please
  157. how to tell if your running to rich
  158. new pilot bearing with clutch question???
  159. Clanking Noise
  160. need a how-to or link to oil catch on pcv
  161. mustang is running too hot
  162. delete
  163. heads...
  164. Cheapest place for Borla Stingers?
  165. More Tranny Probs!
  166. What is wrong with these PICTURES????
  167. low rpm knocking sound..
  168. I wanna go faster!
  169. LOUD yet legal!
  170. cost of 3.73 install!!!!
  171. RPM's hang between shifts
  172. adjusting the voltage on the tps
  173. Throtle Body question
  174. Dumb IAT question?
  175. PI Head Swap
  176. vortech v-2 SQ
  177. Threw codes P1152 & P1131
  178. lower control arm ball joint, need answer QUICK!
  179. Phantom noise found need help
  180. How much timing do you guys normally run?
  181. How much do rear seat delete kits weigh?
  182. Borla vs. MM Panhard Bar
  183. Is my clutch going to be okay?
  184. Full Exhaust
  185. 7s 1/8th mile?
  186. best performance bolt ons
  187. Why isnt m Borla loud?
  188. choosing the right springs/retainers
  189. need some advise on paint guns and tires
  190. What's this worth?
  191. transmission flush price?
  192. hp gain?
  193. would those tires fit on my car
  194. upr
  195. my car the mystery mobile
  196. Summer Mac Madness Sale!
  197. Traction Control - 2000 GT
  198. ****ing exhaust
  199. NEW Oil Separator Catch Can
  200. One tire spinning!!!! IDK why
  201. stock clutch and transmission limits???
  202. PI SWAP
  203. Tire Diameter
  204. Repair Manual
  205. Radiator Flush: Please Read and Reply
  206. quick TB and plenum ?
  207. lincoln MarkVIII 4.6 32v 00 gt 2v swap
  208. About to purchace a 4.6
  209. egr vavle block off
  210. is this true
  211. Engine Oil Coolers? Worth It??
  212. diablosport locked to dead pcm
  213. leaking headers
  214. stores that mix auto paint
  215. Meth injection?
  216. what are the HP ratings of Fuel pumps?
  217. porting stock heads
  218. Fuel Injector Cleaner?
  219. A few Question
  220. subframe connectors install cost
  221. Shifting gear w/o the clutch
  222. Knock in engine 4.6L 1996 to 1998 engine swap problem advice needed.
  223. In the middle of a cam swap need help timing...
  224. Plenum Spacer?
  225. painting rims
  226. turbo vs superchargers
  227. Idle Air Control Valve
  228. Starter
  229. tune up question?
  230. Fuel Rail Problems.... fuel everywhere
  231. right side wheel spin
  232. Centerline Telstar driveability
  233. lightweight driveshaft for an automatic
  234. all about tuners
  235. IAC mod: How to?
  236. catback with longtubes
  237. Chirping noise coming from tranny ?
  238. deals on cams....
  239. Knocking post SCT X3 Custom Tune
  240. problem...
  241. Bought a V2 SQ have bunch'o ?'s
  242. subframe weld ins
  243. Interior Question: PLEASE HELP
  244. painting stock rims
  245. LT headers fitting with in Auto
  246. Just had clutch installed... HELP
  247. t-45 from 99 cobra bolt up to my 96 gt?
  248. Intake manifold gasket
  249. Best Tranny Cooler
  250. tire question??
