View Full Version : 4.6 (Modular) Mustang
  1. Exhaust?
  2. squeeling tranny, not fixed...
  3. Thermistat temp
  4. Do i have 4.10's?
  5. 13" front brake conversion behind bullitts?
  6. To anyone who throws a spark plug....
  7. What lowering kit and shocks should I go with?
  8. Replace Front Lower CA bushings w/o alignment?
  9. SLP POWER FLO'S anybody have them?
  10. P.I. swap with plastic intake, will it work?
  11. ALL PLASTIC PI INTAKE??
  12. silencer
  13. SCT X3 93 Octane Tune???
  14. Is this worth the money?
  15. Those with LT headers and wintery weather driving
  16. EGR or IAC
  17. low boost turbo/blown setup for a '00 2v?
  18. tire sizes for 18's
  19. rear spring ???
  20. ebay throttle body question
  21. 99 cobra will not idle
  22. Running untuned
  23. Labor costs for Plug n Play?
  24. 2003 GT Question
  25. got a little problem i think.....
  26. Damn PCV Valve
  27. Brand New TR3650 Installed, Rattling sound coming from it?
  28. Tire sizes and wheel offset question
  29. anyone with cobra bumper.....
  30. exhaust noise?
  31. DTC help
  32. upgrades while waiting for supercharger
  33. forged, or 4v swap..
  34. Whooshing noise under hood
  35. Cam Question
  36. V6 getting bad gas mileage
  37. How do you remove the timing chains safely/correctly???
  38. cooling system pressure check
  39. Exhaust problem maybe?
  40. 1998 GT engine swap
  41. detect a vacum leak?
  42. MRT Catted H Midpipe owners
  43. P.I. Swapped guys....
  44. Bullitt Intake Help
  45. car throwin codes..
  46. will the 03/04 eaton bolt onto an 01 4v cobra?
  47. Am i going to blow my stock 4.6
  48. my proposed suspension
  49. next mod most exspensive!
  50. 2002 mustang gt: How Much Oil Does It Hold?
  51. To Everyone Running On Spray!!
  52. Aluminum Drive Shaft
  53. Why is this happening to me
  54. Car whines when starting
  55. Problems with changing gauge cluster lighting!
  56. 97' Cobra, what do I have to do to add Mach1 Heads?
  57. Swap or conversion?
  58. What gears do i have?
  59. lowering springs Eibach vs H&R
  60. Funny Accelerator
  61. Gear selection
  62. Do i need a new valve body?
  63. Exhaust Fumes!
  64. what is going on??
  65. Upper Control Arm Bushing
  66. 98 Cobra aftermarket performance brakes
  67. Hesitation
  68. Power Brake Booster
  69. Comp 278's
  70. Subframe connectors
  71. Should I degree?
  72. Gauges for nitrous setup
  73. hanging rmps?
  74. Need some advice....
  75. Transmission Temp Gauge
  76. Exhaust.. best place to purchase??
  77. exhaust question
  78. Studdering, Hesitation Need Help?
  79. heres a stupid question
  80. Installing further mods
  81. Dyno tune
  82. convertible back glass
  83. steeda shifter and transmission problem
  84. best bang for the buck
  85. ADjust E-brake?
  86. tire quetion
  87. oil pressure
  88. custom midpipe
  89. 4.6l aftermarket intakes
  90. Whirling Sound
  91. o/d flashing
  92. Mystery Engine Problem...
  93. LTs and midpipe question
  94. what kind of clutch should i get for my s/c 2003 gt
  95. Forged Block
  96. WTF!!!!!!!!!!!!!
  97. Which Mod Would Be best?
  98. longtube headers installation
  99. Which 2V Intake is worth the money??
  100. Which one is it?
  101. Battery....make your recommendation
  102. 03 Cobra Fog lights?
  103. Wide Tires Question
  104. Question about Whipple SC
  105. MAF and Injector question
  106. header compatibility
  107. Damplifer?
  108. new parts will these work without a tune
  109. 10.5 clutch in a 3650 trans
  110. hibernating
  111. HELP PLEASE STARTING PROBLEM
  112. Heads needed for super?
  113. speedo/rpms
  114. When changing the tune
  115. Nitrous With kenne bell
  116. Do gears need to be broken in?
  117. take a look
  118. UNBOLTING THE EXHAUST?
  119. Bypass Belt = HP?
  120. Intercooler Ideas and Sites appreciated
  121. Engine swap?
  122. power gain estimates?
  123. Please HELP!!
  124. 85MM MAF
  125. Drilled VS Slotted Rotors
  126. no idle after trick flow intake install..
  127. Loudest GT Exhaust Brand
  128. Anti-seize compound on tri-ax?
  129. Brake Question
  130. 2002 4.6L V8 manual - 5th gear question
  131. How hard is to replace...
  132. Foggy Headlights
  133. Cutting hole in K member?
  134. PI head swap problem! need help
  135. engine misfire/sputter
  136. Same thing?
  137. Buying used injectors
  138. Need Help...
  139. Vehicle lettering mod
  140. swaping pcms will i have a problem?00to a 02gt
  141. what size nos pills=100
  142. 97 electrical problems (radio and clock) PLEASE HELP!!
  143. TECH HELP PLEZZZ I changed my o2's and still have bad o2 codes ANY IDEAS.....BAD PCM? list of codes
  144. Reputable KC Shops for Gear Install
  145. Should I upgrade my injectors?
  146. whats wrong with my e-brake??
  147. Leak help??
  148. Heads and Cam (Need Advice)!!!
  149. Does this sound right?
  150. is this a good brand??
  151. 01 4v vs 03-04 4v Heads
  152. suspension question
  153. Broken Exhaust pipes
  154. UD Pullies: Free HP or Time Bomb
  155. Turbo Mach 1
  156. Throttle cable with BBK 75mm T/B
  157. Need help i have a check engine light on
  158. Clutch going?
  159. i datalogged my stang, need help reading results
  160. JLT or C&L
  161. 4.6l v8 ???
  162. 99-04 Mustang Mileage Prob?
  163. How do I set the clock on 01-04 stock radios?
  164. Oil gage...
  165. anyone who has slp lm2
  166. Push Button Starter
  167. Power windows - fixed!
  168. What is going on here?
  169. ? about preperation for cams
  170. How To: make mach or bullit gauges work in a GT
  171. DIY turbo single turbo systems
  172. Please help i have a check engine light
  173. Cobra Gauge Cluster
  174. Engine Swap
  175. 95 break calipers work on a 98?
  176. crack in instrument bezel 99-04
  177. PI Swap-Worth it or not?
  178. 275/40 17's on stock rims with 1" spacers?
  179. Installing fog lights?
  180. power/dash shut off while driving?
  181. many miles
  182. Spark Advance
  183. circuit board swap
  184. Startup problem
  185. Idle issue
  186. 4.6 swaps?!?!?!?!
  187. Problem getting into all gears
  188. blower belt shedding
  189. Rear Upper and Lower Control Arms
  190. Nitrous Jet chart! NOS 07006
  191. does the t45 normaly clunk around?
  192. Powder coated vs chrome
  193. Noise from steering column
  194. Stock 2003 Cobra Mass Air Sensor on a slightly modded 02 gt?
  195. anybody ever had problems with door lock actuators
  196. At home head cleaning
  197. SLP catback guys come in here
  198. BBK LT, BBK O/R H-pipe on 97 GT (live in MD)
  199. limit on stock rods
  200. Fuel Level Circuit Problems
  201. cold air intake with nitrous question
  202. 98 Cobra Mods
  203. Auto Tranny and Tune
  204. Need some helping picking long tubes
  205. 75mm on K&N FIPK2?
  206. gears
  207. 96 GT supercharged!!... but no intercooler???
  208. Leather seat cover's for 96 Gt
  209. Ok this is really lame
  210. I successfully removed the power window motor.
  211. How do you remove the radio?
  212. disabling the past sytem. wont start
  213. help asap
  214. SVT fuel pump
  215. Tuning!
  216. Intake manifold question.
  217. Removing Fog lights on 96 GT
  218. Wheel Spacers
  219. Power gains? & Sound level?
  220. 01-04 GT hood fit an 01 Cobra?
  221. what all do i need to install 00 tranny into 96
  222. PI swap, sound good???
  223. good deal?
  224. gear install problem
  225. 00 GT motor and trans in 97 GT
  226. new 2008 gt
  227. 97 Cobra Rod Knocking
  228. 2V Twin - Intake manifold suggestion - turbo lag - dyno curves inside.
  229. WOT Switch mount??
  230. Mac Pro Chamber Install
  231. Porting npi heads or get pi heads
  232. Stage Ones or Twos
  233. Crazy Idle
  234. Need a new intake manifold
  235. help me with clutch issue.
  236. two motor swapping questions
  237. Where exactly is the power window motor located?
  238. Uh oh I broke the fastener on the doorpanel..
  239. jerking in 5th gear!!!!
  240. Tranny break-in period and steeda tri-ax
  241. loudest bypass valve?
  242. IAT Sensor
  243. plenum=whistle?
  244. Long Tube Sound VS Short Tube Sound
  245. How do I remove the wiper blades?
  246. Front turn signal covers
  247. What is the exact name of this color?
  248. Help an idiot fix his mustang
  249. Ticking at WOT maybe?
  250. car sitting for four years
