- ignition key
- Cobra Brakes + skinnies
- CATBACK
- Help with cams!!
- '01 Crown Vic Head: Same?
- brakes/ power steering question
- question about milage and motor
- Replacing Wheel Studs
- Twin Turbo Q's?
- nitrous problem help asap
- coil on plug?
- ignition lock or something related
- 97 cobra exhaust lt or h catback
- slp lmII install
- what power gains do ported heads provide?
- 5.4 vs. 4.6 stock cam
- Would these fit??
- YOUR opinion...LCAs or Subframe connectors?
- rebuilt t45
- H and X pipe???
- MOVED: Met a guy...
- 98GT single or double overhead cam???
- just put on my mt dr on
- Diferencial Info Needed!!!!!!!
- MOVED: lost my mustang forever.
- What's a good clutch today?
- Need some advice - Oil on valve covers around bolts - Leaking Valves? Blowby?
- ticking noise *not timing chain tensioners*
- I think my clutch went
- cooling system problem
- instrument panel
- Check engine scan tool. (already did a forum search)
- drop spindles
- Cobra engine question
- Trouble code
- Clutch for 97 GT
- king cobra
- Vibration.. help
- i got code P0156
- What shocks/struts?
- Whistle noise below 32degrees
- Suspension still rattling after overhaul
- how hard is it?
- Screwed up Power Steering Pump Pulley
- Intake piping for 97 GT
- Uploaded the SCT tuner (Brenspeed)!!!!!!!
- mid pipe installation
- 2000 Roush and Emissions Test
- A/C Compressor circulates???
- Mysterious sound
- How to change my procharger oil!?!?!?
- RPM problems
- proper cam break in?
- IAC code
- MIL extendors?
- rev hang fix on 97?
- Piecing Brakes Together
- I'm confused about gear calculations now....
- TKO 600 Grinding 3rd (HIGH RPMS)
- Stalling Problems
- Brake upgrade & appearance recommendations
- i want go over 400 hp what do i need?
- New TB?
- Will 275/40/17 fit
- coilover kit question
- INTAKE MANIFOLD ?????
- Weird steering...
- PI cams or Headers?
- Replace the Throwout bearing or the whole clutch?
- MAXIMUM MOTORSPORTS: full-length subframe connectors
- forged shortblock question
- Bullitt Rims and Brakes.... FYI
- Underdrive pulleys
- MOVED: What do these weigh?
- grainy clutch..replace it?
- HP chip! Good idea Bad idea?
- engine swap
- please delete
- Functional shaker hood scoop on 98 gt?
- rear end 8.8 how do i rebuild it???
- Engine Code, any ideas?
- Frustrated!
- Automatic Tranny!
- MOVED: Some pics of my baby...
- Cracked Intake Manifold....Any ideas?
- best rear control arm combo
- spark plus + nitrous
- having some problems with side markers
- Help with Cylinder heads!!!GT
- New guy! 5.4 supercharged dimensions!
- MOVED: modular forums newest member =]
- Clutch problems
- When will i need caster/camber plates?
- which c/c plates should i get?
- 2V Engine codes
- Need info on front toe alignment
- Exhaust Leak??
- Cracked Intake Manifold :(
- MOVED: Any undercover Mustangs in your area
- 6spd conversion
- Lowering Springs
- Short Block help please
- injector sizes??
- Ticking Noise. need confirmation
- Removing Oil Pan
- HEADLIGHTS
- fuel upgrades for 100 shot???
- Rear control arm mounting bolts, what grade?
- removing valve covers
- just got my car back need help
- T56 in a 97 Gt?????????
- Edelbrock intake
- setting keyless entry key pad
- suspension question
- Steeda tri-ax users
- Engine check light on?
- supercharger
- What size tire will fit
- how car can i push my stock block with the vortech strim???
- Heater Core Question
- Closing Driver Door Issue
- Issue with my 97GT
- bumper supports questions
- Cam Sprocket Questions
- scraping/squealing noice from back right wheel
- Rear wing removal
- Plenum
- Crate Engine
- overheating
- Lower control arm bushings
- Brake Master Cylinder Q??
- ebay headers
- Can you mod. the 4.6L v8
- MORE TRANS HELP!!!!!!
- Which Trans?
- motor swap!!!!!
- cc plates
- mass air flow/fuel injector
- springs
- vortech question
- need help locating a great mechanic in MI.
- shortshift like rx7 or vette
- Re-tap or helicoil crankshaft?
- Headers
- intake/heads
- H?X? what about straight
- swaping in 4v motor
- Hard Clutch. Looking for a New one
- SVT cluster....
- a/f ratio gauge help
- 96 GT cam gears bolt-on/pressed on
- 2005 Mustang Superchips programmer.Max Microtuner Model 1755??
- 99-04 NX Plate Kit?
- 28 spline forged axles enough?
- Which Cam's to use?
- new rims butt
- Quick Lowering Spring Question!
- Belt keeps breaking????
- Help, Can't take off stock H-pipe
- question on TPS and IAC
- Rpms are surging ramdomly
- Exhaust!?
- brake upgrade
- Dash Cluster
- Steeda Ball Joints
- Thowout bearing noise
- Which supercharger?
- A-pillar
- Romeo valve covers
- removing silencer.
- walbaro or SVT
- One tire fire?
- Whats the proper lug nut torque?
- so maybe this head tick is something else
- Which bullets to buy?
- cleaning the MAF
- Headlight question - leaking
- X Pipe Install
- Problem with a foglight
- Plugs?
- what are some good axels for a 04 gt ?
- Will it ever whine???
- tapping into the fuel
- Good shock/strut/spring combo?
- air intake silencer.
- so i fixed my gas tank leak but...
- differences b/w cobra motor and mach
- Diablo--Shift Firmness?
- Struts/shocks recommendation for Daily Driver...
- Match a Camshaft to this setup.
- making the fog lights come on without the headlights
- 100 shot on 112k
- Valve Cover
- 94-98 cervinis ram air hood question.
- engine swap
- 01 v6 to v8?
- Where to find SLP LM II catback for best price
- How reliable is the cobra motor?
- Canister location on 98GT?
- 75mm t/b idle problems...
- Was I on crack or did I do it right?
- stage III pi heads ?
- who has zex nitrous wet kit
- Mods!
- Please help... car won't turn over!
- Traction "Off" Lightbulb Blew
- Timing Marks?
- internals
- Grey bullits on a black convertible
- Cylinder 1 miss fire ... any advice ?
- MOVED: Vortech... for sale
- HELP! SALEEN SUPERCHARGER 4.6 2v
- Spark Plugs
- PI cams
- RPM @ 70mph on 3.73s?
- Hesitation and Power Loss
- Lowering Springs!!!!
- Modular ??
- BIG ? FOR YA GUYS
- Any advantages or disadvantages to using Premium Gasoline in my Mustang GT?
- installing shocks struts springs...
- accufab 75mm combo?
- WTF,is my tranny gone
- '02 GT Owners, Come Inside
- BBK pulleys =fugged?
- t45 borg warner tranny for 96 cobra
- Summit Racing drop springs
- Fast Toys - Now Selling Lloyd Custom Floor Mats!
- Quick Question
- (help) Buying 98 Cobra with Tick
- She's Overheating
- auto tranny on last leg?
- Fuel Pump
- headers??
- Quick question on Snakebit Cobra
- Nitrous Pressure Question
- Do I need new clutch or flywheel?
- Need your advice on buying a 4.6l
- E-Brake Freezing?
- supercharger in the future
- 17 x 10.5 315/35 DR
- Help with Fuel Pump
- service engine soon light
- 5.4 4v
- 2000 gt
- Coolant light playing games with me
- keyless entry control problem
- BBK air intake question
- PLUGS AND COIL PACKS ????
