- sct LIVE WIRE vs. Diablo tuner
- Raising the Accelerator pedal
- engine swap
- Lowering Question
- Diablo Predator
- mustang tuner
- What is catback?
- UDP's?
- PI swap done....clicking noise tho...help...*vid*
- 1/4 Quarter Mile Est. Time
- gt harness
- engine noise
- abs, traction control Help
- how much boost
- Transmission shops in San Diego
- Throttle body spacer
- Need an opinion on 98 mustang
- will procharger fit?
- Quick questions about my brakes
- polyurothine bushings
- 4.6l compression ratio
- Blower guys.. what is a safe Air Fuel Ratio?
- exhaust tip question
- 3.73 effecting speedo
- Faulty squirter
- I need some help
- How to clean an EGR Valve?
- cutch install with bbk long tubes
- PI swap
- Noisy Pulley System
- lowering stang info
- How easy is it to damage...
- Clutch kestion
- no oil pressure
- 99-04 convertible Frame
- Steeda or Maximum Motorsports
- which trans. fluid?
- PI intake sensor
- Coolant leak into cylinder through head gasket
- abs disconnect
- Spark Plug Question
- HID question
- MOVED: 03/04 Cobra or 05/06 GT
- car stalling ocassionly
- odd missfire
- Cobra exhaust on a GT! will it work?
- factory seat bracket?
- Eaton M90 Supercharger?
- Clutch Install
- clutch replacement and LT headers
- Gear swap/speedometer adjustment
- safe or not
- 2000 GT 8 bolt crank
- Horsepower numbers
- Intake, Throttlebody issue
- motor swap mounts?
- Grinding Into Third???
- Oil
- t-45
- Mach 1 vs. Cobra Motor
- hood help
- ALL MUSTANGS, FRONT END SUSPENSION
- T-3650
- Quality Cost Efficient Clutch
- What the heck is this red tubing called??
- car died...
- Rear brake question
- block rating for hp
- stall converter with gears
- ABS / TCS PROBLEMS
- ? on engine build
- This ever happen to anybody?
- TICKING
- Loud sound in rear...please some answers
- Anybody ever use a Granatelli Tuner?
- New 96 Cobra. Anybody know these codes?
- CEL + Failing home made MIL
- Pypes:
- How to check Manual Transmission fluid
- Stupid spark plugs...
- off road exhaust and engine lights
- Problems: MPH Gauge and Suspension?
- What could be making this noise?
- HELP!!!! CAR WONT STAY ON
- track times
- Anybody good with transmissions??
- tranny/clutch?
- what kind of stang
- piston to valve
- Cams and Timing...
- Can anyone?
- Control arms or pan hard bar, whats recomended?
- where to put air fuel gauge
- Series of Problems after tune-up/Please Help
- pinging from the exhaust
- aftermarket driveshafts?
- autometer tach
- autometer tach
- Rotors
- clutch & TO bearing
- stall
- 97gt and radiators
- 03 GT Head Swap...Best Bang For My Buck? Mach 1, Police Interceptor, Or Port And Polish?
- what type of pistons
- gut out cats?
- Advice for HID
- do i need any maintenance yet or something??
- Idle low and poppy, and replaced all I can think of!!! NEED HELP!!!
- Fried Cats
- help with heads, cams, etc
- cluch install with lt
- to those with a s/c and boost/vac gauge
- Shifting an Auto
- Pro Motion T45?
- SOOOO SQUEEKY
- Fog Lights
- S/C and California smog
- H&R sport springs or Pro Kit?????
- lt header install
- SCT vs. DiabloSport
- tre
- Long start-up, about 4 seconds or so...
- important question
- 4th gear slippage??
- New Cams, valve springs, and heads
- help!!!
- 400HP
- Service Engine Soon Light (ROUND 2)
- Anyone ever notice better MPG after....
- About to go to my tuner to get a tune
- Whats all needed for a Healthy Gear Swap??/
- Best Oil for Higher Milege mustangs!!!
- can i leave my bottle filled over winter?
- cleaning intake
- Ticking noise under acceleration
- Help with CEL
- 5% OFF ALL WHEEL AND TIRE PACKAGES!!! ENDS 12/12
- Help with having no ABS
- Exhaust
- Exhaust Question
- eibach pro kit.
- smoking coming out of 1 exhaust pipe???
- Heads, Intake.... super charger?
- will it matter at the end of the day?
- Harsh ride after lowering, help
- "Service Engine Soon" light came on
- am i getting screwed?
- not normal for 2001
- Water Pump install?
- stall after 4k???
- Mac 8.8 Rear End Support Cover Sale
- Black Bullet Replica Wheel Blowout Sale ---> FANTASTIC pricing
- Would a Mach 1 Chin Spoiler fit a 99 Cobra bumper?
- Grill Delete Question.. HELP
- How would I hook up my fan?
- Backpressure Compensation
- slow starts!
- wierd noise, anyone know what it might be?
- Car Keys
- Gas Milege?
- valve spring compressor
- Clutch vibration, chatter
- Engine/Installation $3000
- Gas gauge went crazy...help!
- Clutch Problems ???
- Exhaust
- need information
- MOVED: Guess what I saw tonight!!! LOOK HERE NOW!!!
- Pi Swap
- sameole
- which x pipe for stock headers
- Dyno Tune with Sniper--good deal?
- Best tool combo to tighten header bolts??
- Audio guys help me out!!!
- Question
- Tranny fluid leak
- service engine soon light!! wtf
- patriot head problems?!
- anyone have a problem with patriot heads!?!?!?
- pi swap cont.......water pump nipple *pic*
- IAC
- 01 mustang GT-need help
- boost gauge install
- bumb steer kit
- Serious problem, Need help!!
- CHECK OUT THIS WHEEL AND TIRE PACKAGE SALE!!! ENDS 12/12
- Need Opinions on set of springs.
- AIR FLOW QUESTION?
- HELP ???
- fiberglass bodies, need help
- EGR valve
- Buy a catback or have a shop make me one?
- mustang shifter sticking?
- Brake Pads
- Speed problem
- question on destinction
- good setup?
- pi swap and cams
- quad shock?????
- One wheel peel
- grinding and popping noise coming from rear end?
- Pros and Cons of O/R H!
- Watch out for Ford
- Paint
- bassani mid lengths?
- OBDII port not there (Dealer issue) Help
- Whining Noise.
- ABS Problems
- Head Lights
- predator tuner
- Three Cams -- Pick One -- and Why?
- In the middle of PI swap..few questions
- SPEC Stage 3 Throwout Bearing???
- easy fan toggle switch?
- what should i go with for gears
- help.
- Lash Adjusters / Stem Seals
- Throttle body vacuum line
- need some info on block......
- Gotta pass Smog!!!
- whats the difference
- 2004 Mach 1.. New Heads??
- Patriot Stage 3 Heads on a 97
- SLP Loudmouth
- tranny problem
- patriot performance cams question
- HALO HEADLIGHTS HELP ASAP!!!!!!!!!
- Front End Clicking ?
- which transmission do i have?
- Rim/tire question
- Best engine site
- shifter
- crankshaft posistion sensor
- KNOB PROBLEMS
- Touble Codes
- front seat extension's
- Should i do this?
- Strange "shudder"?
- Springs
- will check engine light go off?
- MAC prochamber
- supercharger fuel pump issue
- intake manifolds
- Cobra brake fron upgrade
- HID's giving me crap
- Part number?
- HID lighting
- ECM
- Brake Debate
- looking for an answer
