View Full Version : 4.6 (Modular) Mustang
  1. Buying Used Heads
  2. CEL Code P1409
  3. built 4.6
  4. What is a Mongoose kit???
  5. HELP NITROUS/JUICE
  6. anyone runnin' a 5.0 k member in a new edge?
  7. Mustang dies at highway speeds
  8. Tokico HP struts and springs?
  9. Start up problems after sitting
  10. fuel pump wiring!!!!!!!!!!!!!!!!!!!!
  11. QuickTime Bellhouse Question
  12. intake manifold??
  13. Why is my PCV hose collapsed?
  14. 4R70W transmission question
  15. ????sct tuner?????
  16. water pump for short serpentine belt?
  17. cat back ?
  18. Rear leaking?
  19. 98 GT Exhaust issues.
  20. Timing cover gasket??
  21. help me decide what to do with my car
  22. Lowering springs?
  23. transmission
  24. Rear ID tag
  25. parting out a 97 gt
  26. i need more speed lol
  27. Deep dish wheels?
  28. help with rear suspension setup
  29. IRS or NON IRS
  30. painting rear bumper
  31. tire size ?
  32. Help with Rear brakes
  33. What you guys think?
  34. TB spacer & CAI?
  35. gears
  36. Stroker Question
  37. ?????someone help?????
  38. cobra spoiler??
  39. Help Attching Saleen S281 Wing
  40. motive install/bearing kit
  41. need help
  42. 1998 Mustang GT. Exhaust Advice Please
  43. What do you guys recomend?
  44. DOHC
  45. where can i get this!
  46. Strut brace write up
  47. P&P Heads
  48. How much do you think cant get for my engine?
  49. Is my engine blown or what???? VID INSIDE
  50. Typhoon, Mach 1000, 24# injectors, Oh my!!
  51. 98 cobra Reverse Gear??What did i break??
  52. Need help with rear defrost
  53. 3.73 gearing
  54. Vibration and loss of power?!?!?
  55. typhoon intake or OEM?
  56. fuel filter
  57. Estimating HP increases
  58. I have 2 questions
  59. Speedo gear installation
  60. Fox Body shocks work on a SN95?
  61. Anyone have pics of where vacuum lines go on a 96 Gt ?
  62. Lowering Springs...
  63. spun a bearing
  64. Lowering my car (again), do I need anything?
  65. Rebuild Shops?
  66. Sorta stupid question
  67. VT Cams
  68. Line lock install - - brake line questions??
  69. AUTO SWAP TO 5 SPEED
  70. Steeda lowering springs. How hard
  71. shift light
  72. Replacing Clutch and Somethin
  73. Timing belt chain??
  74. anyone swapped ball joints on their stang?
  75. help engine noise!!!
  76. sequential tail lights
  77. Using a screwdriver to listen for ticks
  78. Spring Isolators
  79. Installing MGW shifter
  80. Lag in the pedal
  81. coolan overflow tank
  82. nitrous + diablo tuner
  83. PCV valve
  84. I need help!!!!!!!!!!!!!!!!!!!!!!!!
  85. Lights just went out
  86. Black coolant
  87. What Size Rubber will fit the front
  88. I'm an idiot. Need some help...
  89. NEED HELP BADLY!!!
  90. What should I do next?
  91. snow meth?
  92. NEED HELP BAD!
  93. upgrades to get
  94. Funny Sound
  95. 99-04 Manual Transmission Flush
  96. Fuel Filler Neck Removal???
  97. Tire experts.
  98. Where to place blow-thru meter????
  99. In desperate need of some throttle body help
  100. 4.6 (99 to 04) Swap questions
  101. Overheating and a leak??
  102. Programmer ??????
  103. Air Conditioner Pulley replacement?
  104. exhaust
  105. Where To Place Jack Stands
  106. King cobra clutch?
  107. 5.4 / 4.6 3v
  108. 99 mustang v6 - 302- 351
  109. steeda clutch adjuster
  110. My mustang is skipping badly
  111. clutch noise?
  112. trans
  113. Seat Heater Kit Sale!
  114. weird noise from my rear?
  115. what is a good cam to run
  116. Electric water pump.
  117. supercharger 03/04 cobra on 99 gt?????
  118. *HELP!* Front Seat Removal!
  119. Hardball'r intake
  120. Exhaust or not
  121. Clutch problems
  122. SUSPENSION ISOLATORS????
  123. starter
  124. 2003 Mustang GT Fuel pump Fuse #
  125. Underdrive Pulley Problems
  126. Noises after exhaust/springs install
  127. should be made a sticky/rearend build
  128. Will 96 Airbags Work in a 2002 GT?
  129. CD-6 Compatibility Question?
  130. Help with Misfiring
  131. Is it my timing?
  132. more hp
  133. GT auto trans
  134. 4.10 gears...weak?
  135. 03 exhaust on 01
  136. Window Switch
  137. please help bassani x pipe with mil eliminators
  138. LTs Legal?
  139. wierd! my gauges have started sweeping on startup!
  140. check engine light codes ?
  141. widdest tire
  142. HELP! DAILY DRIVER MAF INSTALL PROBLEM
  143. questions for the most knowledgeable
  144. exhaust
  145. problem shifting into 2nd
  146. Swap to V6?
  147. Pi intake
  148. Dyno Tuning in Vegas?
  149. the best drag radial other then nittos??
  150. What is the paint code for this color (also background)
  151. Clutch adjustment?
  152. MAF help
  153. May need new heads...
  154. flywheel help
  155. 04 headers?
  156. Replacing right rear quarter panel
  157. gas guage
  158. Roush Side Skirts Question
  159. TKO 500 Bellhousing?
  160. handling?
  161. After PI intake swap, 3 code ?
  162. Motor Swap HelP!!
  163. Pre-S/C
  164. Head swap question
  165. 500 rwhp?
  166. Putting together a Modular swap...
  167. HOW TO: rebuild an AODE?
  168. blower ?
  169. EGR help
  170. stingers or lm 1's?
  171. clutch questions
  172. race seats
  173. installing headers?
  174. Convertible top
  175. noise. from my car. help!
  176. 99 4.6
  177. fuel pump
  178. am i burning oil
  179. rear end fluid?
  180. TPS sensor adjustment question
  181. shift knob issues
  182. 1998 Cobra Ticking engine
  183. What is the bolt circle on my axles?
  184. SLP Loudmouth II's
  185. Rear axle
  186. Interchangeable Heads
  187. Chirping sound driving me crazy.
  188. Fuel injector question for supercharged car
  189. Top Speed Problem???
  190. NEED SOME THOUGHTS FOR UPGRADE
  191. P1401 HELP!
  192. ring gear
  193. what would sound better
  194. Plastic Intakes
  195. Bought a GT hood (with the scoop)
  196. Does this look right ? (Pics)
  197. Exhaust Question
  198. how to convert to a blow through setup???
  199. 4V anyone?
  200. rear end build up
  201. Auto ?
  202. Pinhole Oil Leak from Oil Cooler Housing
  203. How much for cobra engine?
  204. AUTO TRANS COOLER
  205. OVERDRIVE ON/OFF AUTOMATIC GT
  206. Tokico Adjustable Struts. Need Help!
  207. recalibrating after 4.10s
  208. New clutch for the 8 bolt opinions needed
  209. MAF cleaning?
  210. shaker question
  211. AODE to Manual
  212. Badging?
  213. so i think i f'ed up my clutch last night
  214. authentic wheels?
  215. crank pulley bolt?
  216. what short throw shifter to get?
  217. got borla exhaust installed and....
  218. Lowering spring questions?
  219. What brand of axles/diff are you running
  220. question about mustang differentials
  221. intake manifold gaskets
  222. ARP studs
  223. 575hp Slp Performance Pac
  224. Heads upgrade, Foxlake or DSS?
  225. Maximum Motorsports Max Grip Box Install into a '03 GT
  226. What would you guys pay?
  227. which 75mm and plenum to get?
  228. 2"lowering
  229. missfire again
  230. diablosport programmer ?
  231. Can someone run Carfax on a Vin #.
  232. Is this the future?
  233. Am I running Lean
  234. How much should I pay?
  235. My car is wicked bad in the rain
  236. Agent 47: Double A-Arm
  237. 2004 gt needs transmission seal- can't find 1
  238. Problem with install!!!
  239. Oil change today...question
  240. Traction Control
  241. Interior lighting Question--anybody???
  242. Clutch Question
  243. Odometer not working?
  244. 2001 Mustang GT Vert - ABS Light / ASR
  245. CC plates needed if aligned?
  246. loud exhaust
  247. A/C PULLEY PROBLEM
  248. exhaust leak???
  249. Transmission Shop Woes
  250. 1998 GT Fuel System. what is the difference????
