- Procharged...gears? cams? Threshold?
- Which Cams should I get?
- MOVED: Winters Coming Quick
- ok, how in the hell
- MOVED: C&L 80MM MAF kit for sale!!!!!
- cobra engine swap
- Interior lighting??
- ne1 in Kansas have a tuner for a 1999 mustang GT
- New here and need help with mod options
- pi intake
- Forged Motor Questions.
- quarter time
- 4.10s
- should i buy a 95 GTS
- Is this a stock exhaust tip or not?? *Pic*
- Trouble Code p1443
- 04 gt idle air control sensor the same as 98gt?
- BBK Shorty Headers
- Symptoms of a bad IAC?
- Tailshaft bearing noise
- Dont understand??
- Mac LT + O/R prochamber NOT AS LOUD AS I THOUGH!!!!
- emergency brake
- PI?
- SVT fuel pump questions
- 5.4 intake
- 4R70W from a V6
- PI fun
- anyone have an aftermarket steering shaft?
- Keep the GT?
- SVT FOCUS FUEL PUMP
- TRICK flOW INTAKE MANIFOLD?
- Tranny fluid?
- running lean - fuel problem
- question about rpms
- where to get oil cap??
- NPI or PI heads?
- brakes
- Was looking at N20....
- HELP!! Rear Axle C locks!
- New JLT and Throttle/Plenum Install
- what 4.10s should i get?
- Squealing from the rear end under hard accel
- What is wrong with this disc?
- Why did I almost T bone someone?
- where can I get this?
- Rear End Set up
- need some measurements off the head or block 4.6/5.4 dohc/sohc
- drift anyone
- mid pipe pipe question
- Exhaust Help Please
- How to convert to Cobra brakes
- motor locked up
- Plugs and wires
- Question about the TKO
- Plenum spacer
- big dilemma!!!
- spark plugs again
- remove my AC
- good deal???
- Suspension questions
- 5.4 specs
- Trying to fix before the cold....
- Laptop Programs...
- Paranoid (I guess)
- 100,000 miles old today!!!
- I need a downpipe for a single turbo!!!
- 03/04 Cobra front bumper
- Hearing squeaking noise from right side of engine!!
- 5.4 4v do you have to modify the...
- Upgrading a 2003 GT to Cobra
- bad blower pulley?
- 2001 GT Parking Brake Bolt Broke
- Vibration Help
- Here's how you install a fuel filter (big pics)
- Which Fuel Pump for S/C built GT
- After market ignition coil packsd
- All Spec Clutches - 10 % off!
- no flywheel dowls = vibration
- start up problem
- question about midpipe
- Water in spark plugs
- Left over part???
- 5.4L info needed
- Price on Install for gears
- question on cam???
- 5.4 intake adapters
- knocking I think
- sputtering, misfiring? HELP PLEASE
- CHEAT 02 SENSORS CHEAP AND EASY
- air fuel ratio gauge
- DOHC swap into a GT
- so yea the x pipe is installed but
- Control Arms
- Dyno Results - HP Still Going up at Redline?
- heads warped
- Seat Heater Kit Sale!
- What kind of vacume should I have at idle?
- car squeeks on turns
- How to uninstall and reinstall timing chain?
- Check Fuel Cap Light On!!!
- preadetor
- SCT Tuner Issues with Auto
- this sound like a vaccume leak?
- Rear Blackout
- Heavy clutch, long throws..normal?
- Top End Swap
- Engine warranty
- o2 sensors grounding out?
- Driveline Clunking and chatter
- couldnt hear fuel pump
- Anyone change window motor?
- still running lean
- pro stars
- IT HAS TO GO!!!
- coolant smell
- Smoking issue??
- Grill
- Biggest Tire on a Stock Bullit Rim
- 2 Stock Mustang Bullits
- T45 on the edge of destruction?
- Fuel Cutoff Switch
- I am an idiot....
- wont start
- suspension fix questions
- Clutch adjuster
- Problem with alignment
- 03 04 cobra OR 01 Saleen.
- what engine/tranny is in my gt?
- New coil overs, write up + pics.. no 56k
- H-pipe Bolt???
- Caster camber plates
- Exhaust leak killing my fuel economy
- stall/transbrake
- CAI HELP.....
- Yet another problem
- Brake Pads
- A couple questions and a gripe
- Tuning after replacing cams
- 02 GT to 95 V6 suspension
- what to do at next service
- question about solid motor mounts
- GREAT night at the track!
- how do I know if my a/c clutch is bad?
- Nitto 315/35/17 DRs on 17x9 Rims
- steering clicking noiise!???
- Steeda Sport Lowering Springs
- Need alignment when...
- Strange Vibration
- MAC u/d pulley kit... missing some bolts...
- port and polish
- Dash bezel removal A/C decal install
- bbk pullys
- Was I out of gas or is the intake cracked?
- tuner and tire size
- TIRE SIZES????
- turbo boost
- a little help here please...
- catted h pipe question???
- Turning By Hand AFTER Draining Oil?
- tuned for 91 octane, 93 octane, etc?
- Quick question
- A/C High Pressure Cut out Switch
- EGR delete
- IAC mod, Base idle now 1100...
- Plenum Intake, Throttle Body, TB Spacer
- To H Pipe or to X pipe, that is the question.
- any place to get bullitt/mach gauges
- Need help with my 8.8
- egr valve
- Turndown
- flywheel or pressure plate vibration
- Whats needed for Tune Up?
- H pipe question
- I got the X pipe but got a question??
- 97 gt brakes on a '00 gt?
- Holy crap my GT's clutch sucks
- NEED TIRE HELP!!
- 70mm???
- Speedometer Problem
- what will it cost for a new quarter pannel?
- best size DR
- fog light hook ups
- Qa1 front struts
- steering and brake problem
- what tuner to buy
- rearend question?
- Fuel pressure regulator question
- Help engine won't start
- Good Tuners?
- 26" or 28" Slicks?
- Longtubes
- headers???
- gettin pissed...
- coolant leakk??
- Throttle Body Spacer Help
- tires
- What oil pressure (psi) runs the motor
- Installing new TB & Plenum, have a question
- 96-04 X-pipe / H-pipe
- GEAR CHANGE
- Supporting mods w. a kenne bell?
- Exhaust setup
- 95 heater core
- leak need help
- 96 cobra mass air... will it work on a 96 gt
- speedo cable question...help asap
- where to buy 8 rib pulleys?
- Need help with running rich problem?
- Thermostat
- Charging light on
- programmer ?
- Cobra 4v head swap
- so my mechanic said it could be tensioners but...
- o2 simulator??
- Need advice on buying a 99-04 GT...
- Uh oh.. P0190 Trouble code
- PCM?
- Car won't start!
- auto vs stick
- MAF question
- 03 Eaton Setup to 2001 Cobra
- sputtering when cold started then fine?
- clutch
- door lock keychain pads
- PI swap question
- Clutch replacement
- SCT not powering up
- Lightning MAF and 30# injectors= $200?
- cylinders 4 and 6 not firing?
- just installed turndowns, mufflers popping?
- Do I have stock gears??
- Any feedback on the claims in this kit? Thanks,
- installing UPR x pipe
- shorty headers and a X pipe??
- How would you fix a loose shifter?
- no cats/service engine soon light
- Bassani full exhaust.
- running lean. need help badly
- 04 GT Auto Tranny Problem
- Question for those who put the car away for winter
- Need some education: Fuel System
- expected performance ?
- got water in engine. :(
- seats?
- Dumb question about 4v valve covers.
- Safe racing RPMs
- EGR DELETE PEOPLE!!!
- Is it possible?
