View Full Version : 4.6 (Modular) Mustang
  1. Flywheel!
  2. NGK Plugs!
  3. White Exhaust Smoke???
  4. Thrown Code?
  5. Royal Purple??
  6. Grille Question
  7. Muffler Questions
  8. Hooking up Tach
  9. what will make me deeper
  10. how to install a fuel pump?
  11. whats a timing adjuster
  12. Air box bracket???
  13. cobra blower
  14. SIMCO gauges
  15. Is something wrong with my Rear-End
  16. Plug Wires
  17. belt broke, help!
  18. 180* thermostat
  19. Quick Release Clutch Quadrant
  20. Why Does My Clutch Cable Squeak?
  21. Code P1443 WTF
  22. Need engine advice!
  23. Keisler Transmissions $$$ ?
  24. AC PROBLEM
  25. MGW Shifter Question
  26. mods for a 1994 4.6l
  27. PI Intake Manifold Cracked w/Pic (Anyone Else?)
  28. Where can I find some SLP Mufflers?
  29. Transgo shift kit installed
  30. PLEASE HELP! HIGH IDLE, NO THROTTLE
  31. thumping noise???
  32. Bassani X pipe with cats pass emission in Texas?
  33. something weird?
  34. MAGNAFLOW DECISION
  35. JLT CAI
  36. Air Silencer?
  37. obdii code help - P0455
  38. Installing new fuel rails.
  39. super dee duper clutch chatter!?
  40. Shift knobs?
  41. sn95 tonneau cover for sale!!!
  42. Fuse keeps blowing.
  43. transmission cooler install
  44. Coolant Leakage (Not just a cracked IM) *Now w/Happy ending!
  45. Best Shocks for the Dollar?
  46. GT hood stripes??
  47. Off road pipe
  48. Got my P-51 in today!!!!
  49. Throttle body/plenum Install troubles...
  50. trying to squeeze more power
  51. Auto window question?
  52. 4v heads 4 sale
  53. car making weried sound
  54. MAC CAI install...
  55. Have a question with pics on air injection for 4.6L DOHC guys
  56. buying a SN95 what to look out for(with pics now)
  57. whats my transmision
  58. Marauder 4V swap?
  59. loosing antifreeze
  60. mushy accelerator pedal
  61. compression test results
  62. Intake Manifold Spacers
  63. Tech info 96 GT
  64. Which Shifter!
  65. Car wont start help!
  66. Clutch Install??
  67. HELP!! rough idle and stalling
  68. what do yall think
  69. blowing an 01 gt
  70. Kenne Bell or Roush Stage 3 S/C???
  71. Flows getting quiter
  72. under drive pullie diffrences?!?!
  73. V6 mustang bumper on GT?
  74. Need help on upgrade!
  75. Calling all mustang TECHS
  76. bullit intake question.....
  77. coil packs
  78. Might get an 03/04 Ferrari
  79. throttle body.....
  80. Aluminum Driveshaft
  81. Springs
  82. Wiper Cowl
  83. DiabloSport Predator users.... I need some help
  84. Loud noise when turning right.
  85. '99 GT rear wing gasket?
  86. newbie question - about plugs
  87. hesitation after cold start
  88. is there a write up on a timing chain/tensioner replacment?
  89. Rear Window Lip...
  90. new T/O and still squeeks...
  91. Tranny Flush Questions ( 2001 AUTO GT )
  92. reving at idle
  93. steering for an 01 GT
  94. Using a lightning maf, which wires to use for IAT?
  95. question on paint
  96. b&m shifter
  97. 4v cobra engine on 98 mustang gt ?
  98. Vibration in steering wheel???
  99. new clutch. please help
  100. Pinging/Knocking
  101. I need some specs on the Sn95 Mustangs
  102. C&L 85mm maf 02-04 gt and inlet tube for sale (rpmoutlet.com are scams)
  103. T-45 swap
  104. Need Steps to Polish and Wax Paint
  105. pypes x pipe o2 extenders
  106. What would this sound like? Loud maybe?
  107. advice needed on 01 auto trans rebuild
  108. squeaking
  109. starter??
  110. WOW, get this!
  111. wanting to lower even more
  112. '98 GT check engine light on
  113. adjust timing?
  114. MGW adjustability
  115. well whats the best way to go about this? intake manifold.
  116. Tach
  117. Best stuff to clean injectors...
  118. Ideas for Spark Plugs ?
  119. CEL on 02 GT
  120. Window wont go up
  121. Finally decided on the parts
  122. S/c on a 99-04 GT?
  123. audio help
  124. Need help!
  125. SES, high idle
  126. 17" or 18"?
  127. backed into a pole
  128. Another 1/4 mile est.
  129. blower problem at 5 grand
  130. Speedcal causing it CEL ????
  131. 99 GT with saprk plug problem
  132. viper spec t56
  133. carbon fiber or fiberglass?
  134. clutch problems
  135. mod x
  136. drivetrain
  137. automatic tranny
  138. Rims
  139. exhaust wrap
  140. Clutch noise...
  141. Tapping Noise?
  142. SN-95 + vortech questions
  143. changing front brakes please help!!!!
  144. Getting a S/C Qestions....
  145. Shifting bezels different??
  146. Long/Short headers/midpipe
  147. BBk header install problems
  148. 5.4 boost
  149. Finding a transmission?
  150. short headers to Long headers, worth it?
  151. I made my first upgrade
  152. Air temp relocation
  153. Pics of your cars with Drag Radials
  154. Noisy Pulley?
  155. real quick: fuel filter question, bout to change it
  156. some problems with tranny swap
  157. wheel bearing, help please
  158. 96 gt tranny problem
  159. gears
  160. rollcage
  161. throwing a code
  162. Hey guys, Anyone have this problem?
  163. Midpipe gaskets
  164. Running super lean????
  165. midpipe BOLT
  166. synthetic oil
  167. How bad can it get...
  168. need some answers
  169. Prior to installing tb/plenum....unhook battery?
  170. Help me decide on these
  171. Thinking Of gettin headers wat do u guys recommend?
  172. Does anyone sell gauge needles?
  173. which one is better?
  174. Help!! shifter/tranny problems
  175. 98gt belt size for ac/bypass ac (pump is knocking)
  176. diablo predator
  177. question about spark plugs
  178. Drag Radials
  179. Just a quick exhaust hanger Q
  180. Adjusting Firewall adjuster
  181. Anybody close to Defiance Ohio ?
  182. exhaust?
  183. Interior Light Comes on with Headlights??
  184. Quality Suspension set up for $500?
  185. Is this Auburn worth it?
  186. 4.6 Heater Core Hose / Intake Issue...
  187. Drag Radials - GT reco width?
  188. spark plug black
  189. ??? with my driveshaft.. HELP ASAP!!!!!
  190. paxton to procharger?
  191. Short Shifter Question PICS INSIDE UPDATED
  192. WTF is this weird THUMP when starting???
  193. i'm looking for aftermarket hoods. ideas???
  194. Exhaust/x-pipe
  195. did all 99+ gt come with trac control??
  196. Problems with 3rd gear
  197. What can I use with Accufab Plenum
  198. Steering and Handling
  199. 5,000rpm + problem. Please help
  200. ABS
  201. Forged Internals.
  202. 2002-2003 Mustang Question...
  203. i need some input
  204. 02 sen
  205. Cold Air Intake, ideas please
  206. do MILs completely throw c/e light?
  207. Road Race build
  208. 2TONE PAINT,WHAT LOOKS GOOD??
  209. full bolt-on 04 gt
  210. PI SWAP!
  211. cobra gauge cluster fitment on GT
  212. Supercharging 16v
  213. 96 GTS, to wing or not to wing?
  214. All right...still having starting issues
  215. gotuner questions please
  216. White Exhaust Smoke????
  217. THR's promotion code?
  218. MAF Swap
  219. Nitrous Problems
  220. Hp. vs. Weight
  221. Mach 1000 problems...help
  222. Cluthc and Flywheel
  223. Transmission question. t-3650
  224. Ok i have a question about exaust.
  225. Cobra conversions?
  226. fuel system, 500RWHP
  227. What size injector!!
  228. Priming Oil Pump
  229. Bbk lt's
  230. opinion question
  231. Shorty headers, turbo and K member
  232. brake warning light coming on
  233. Magnaflow Catback to Magnaflow Magnapack
  234. A/C Control panel
  235. Floor mats from American Muscle
  236. Location of IAT and BOV
  237. Grill delete
  238. Could use help with Vortech
  239. Nitrous Installed
  240. FLOWMASTER SUPER 44 SERIES
  241. headlight help?
  242. swapping auto for 5 speed a good idea?
  243. Is 110k miles too much to put a cam in?
  244. Hp Question
  245. i need helpp please
  246. Superchips tuner
  247. Head Port and Polish Question
  248. 03 heads, and tranny
  249. ATF Leaking everywhere
  250. turn signal
