View Full Version : 4.6 (Modular) Mustang
  1. Is 110k miles too much to put a cam in?
  2. Hp Question
  3. i need helpp please
  4. Superchips tuner
  5. Head Port and Polish Question
  6. 03 heads, and tranny
  7. ATF Leaking everywhere
  8. turn signal
  9. Another LT header questtion.
  10. Help locating problem, sound only
  11. plastic manifold cracked. Need help asap!!!!!
  12. somebody has to know...
  13. Coolant Fluctuation
  14. Found another 98 gt
  15. Engine Parts
  16. low oil light starting to come on.
  17. Nice little suprises :)
  18. exhaust questions
  19. longtube headers 4v
  20. Build up questions
  21. Boost
  22. should I??????????
  23. off road midpipes
  24. steeda underdrive pulleys
  25. What is this???!!! Should I worry?
  26. Need 00' GT Cruse Control Trouble shooting help
  27. Engine builders, please Help!
  28. Mileage
  29. 04 5.4 heads on 96 4.6 block
  30. Stall/Torque Converter
  31. SCT livewire
  32. Intake
  33. coolant hose
  34. Blue smoke, Rough Idle/Misfire (40k miles!)
  35. so for those that care
  36. 50k Service....what to do?
  37. comp cams in a 4v
  38. Idle Air Control Valve? HEELLPPPPP!
  39. swappin parts
  40. 1998 Saleen Supercharger questions
  41. DRI WASH 'n GUARD(R) Special for Forum Members
  42. question about exaust
  43. 4.6 max compression
  44. how much wrhp do I have?
  45. SVT Focus pump enough??
  46. a "What now?" Question on Installing a Intake
  47. Iridium Plugs?
  48. Looking for 18's
  49. Tein Springs
  50. 04 gt 5 spd h.p. max average.
  51. Clutch Q's/woes
  52. Canuck Motorsport Springs for 99-04 V8 coupe ?
  53. Finally got my gears!!!!
  54. T-3650
  55. X-pipe
  56. Anyone here LOVE Vortech?
  57. How is it going to sound
  58. FLUIDYNE WITH ELECTRIC FAN
  59. New Motor Setup some thoughts and help needed
  60. What power gain should I expect???
  61. 4.6 engine problem?
  62. piece together your own supercharger. where did it go?
  63. PI intake question
  64. very worried...
  65. FRPP King Cobra
  66. Getting just a CAI tube??
  67. 10.5" Rims
  68. Info on key transponder?
  69. need help please racing clutch???
  70. Sparkplug torque?
  71. Infamous accufab idle hang
  72. igniton?????
  73. Hood pins on '99's and up?
  74. help with caliper bolt size??
  75. long tubes on a vert
  76. Anyone Rebuild a T-45 for HP
  77. Which Vortech S/C Mounting bracket ?
  78. exhaust noise louder with LTs or headers??
  79. I just rebuilt my T-45
  80. questions on oil reloc. kits and keeping it cool
  81. I GIVE UP..
  82. help w/ heads n headers
  83. do i have a leak?
  84. AUTOMETER TACH AND TACH ADAPTER INSTALL ON 99 GT PLEASE HELP!
  85. throw out bearing
  86. 180 thermostat question
  87. Hood Clips
  88. t-56 tranny???
  89. cam install
  90. Painting calipers
  91. Setup (my) Stock GT to Put Down 350hp
  92. Mach I shaker fit SOHC?
  93. I'm changing my own clutch, cause I'm out of money.
  94. Need some help (picture request)
  95. a/c compressor
  96. Upgrade suggestions for a '97 GT
  97. changing brake rotor ??
  98. what will my 1/4 time be?
  99. Studders When I Hit Gas (HELPPP)
  100. Please some one.... need help with fuel pump?
  101. LOW RPM SHAKE AND BAD STARTS
  102. suspension clearance issues
  103. suspesino clearance issues
  104. 75mm TB to BIG?
  105. how do i quiet down injector noise?
  106. gasket help
  107. I'd like some new seats please...
  108. suspension help needed ASAP (drop springs in progress)
  109. New 4.6 engine
  110. just installed the eibach sportline kit
  111. armrest / console removal
  112. Ready to get a another engine
  113. how much horsepower????????
  114. Torque setting on plenum bolts
  115. clutch pedal vibrations after new install
  116. rear end gear install
  117. Help with window
  118. Brake install question..
  119. Rattle under car when I go over bumps...
  120. bizarre noises
  121. 1997 4.6 2V swap to a 2001 cobra 4.6 4v
  122. How Much???
  123. Holy grail of TB/Plenum combos
  124. VT stage 3 sc cams
  125. Condensation at the ass end...
  126. loud rattle when in high rpms help plz
  127. 2000 GT - Time for a suspension overhaul
  128. How much hp??
  129. Need some help!
  130. Three questions.
  131. car sputtering this morning an ideas???
  132. PLATE
  133. Anyone try the plasma booster ignition yet?
  134. im buring so much oil.
  135. Lightening flywheel on the cheap?
  136. Which Fluid for T-45
  137. Turn Key Engine
  138. T-45R/RS opinions?
  139. Crazy project idea...
  140. MPH Vortech Kit
  141. Intake Manifold Swap Help
  142. Carfax help...
  143. Install NGK Tr7's= More gargly exhaust??
  144. Gas mileage after boosting..
  145. best bottle warmer???
  146. Nitrous And Supercharger??
  147. No More Popping?
  148. Best Brake Upgrades?
  149. Spark Plug Problems!!!
  150. clutches....
  151. SCT help
  152. Clutch ?'s
  153. Synthetic Oil...
  154. 1996 4.6 WONT START THEFT LIGHT FLASHING
  155. hey guys straight pipe question
  156. BULLIT PEDAL INSTALL MADE EASY : HOW TO
  157. help please!!
  158. X & H Pipe's
  159. ADJUSTING HEADLIGHTS
  160. Electric cutout
  161. Warning light
  162. Electrical vs Mechanical Gauges
  163. ??? about dumps
  164. Am i missing something???
  165. Clutch cable snapped? Clutch Quadrant?
  166. tire size question
  167. slp x-pipe question
  168. HELP!!! Ignition Coil C Primary circuit fault?
  169. What size injectors?
  170. weld on heat shields to OR X
  171. IAT sensor replacement?
  172. Leaking coolant... damn.
  173. garret turbos
  174. Horn sounds like crap
  175. tranny noise
  176. P0156, P2273 and P2273 code
  177. New Member with ?'s
  178. accufab tb/plenum combo arrived
  179. how much boost?
  180. Curb Weights
  181. Irregular starting issues...frustrating!
  182. I need a new motor!
  183. Bypass/Blowoff Valve ?'s
  184. What diff. gears should I go with?
  185. Touched my coils, got shocked!!!!!
  186. Bad Alternator? Battery Light, Car dying while driving, losing power
  187. bad coils?
  188. a/c help
  189. rear pad removal and install
  190. exhuast x pipe opinon
  191. Nitrous question.
  192. Side exhaust. . .
  193. EXPERTS HELP! I'm ONE freeze plug away from fixing my car!
  194. whats the best midpipe?
  195. NEW QUESTION... Brakes
  196. ummm...coolant dissapearing!??!
  197. underdrive pullies with juice?!?
  198. Moded My Intake (Pic's)
  199. exhaust/emissions Question
  200. confused???
  201. Removing head rest. How?
  202. Clutch Problem?
  203. blown 2003 gt with a idel miss
  204. just blew a connecting in a v6
  205. intake manifold
  206. Squeek in steering
  207. Proof you can get 400+ hp out of a 4.6 2v NA
  208. Transmission Cooler fitment with Intercooler?
  209. What gauges needed when F/I?
  210. air idle control
  211. How much to pay for leak down test?
  212. official 35th anniversery symbols for my 1999 gt
  213. From a pony to a gocart
  214. Another suspension question!
  215. weird feeling when i turn my wheel
  216. T-56 viper geared tranny
  217. Alarm issue on a 98 GT
  218. FLAMES
  219. Heads or Headers ? Which first ?
  220. Question on HP
  221. watch this
  222. Ideas on these two noises??
  223. got a knockin noise
  224. black 03' cobra rims in 17x8's?
  225. need 03 mustang drive belt diagram please!!
  226. PI Swap with VT Stage 2's
  227. shift light.
  228. wiring harness
  229. MagnaFlow Vs. SLP
  230. Intercooler questions!!
  231. Quick pully question
  232. Throw out bearing help
  233. 302 Stroker Kit
  234. 4th Gear!!!!
  235. Dyno Tune???
  236. Weird noise coming from speakers, HELP!
  237. heads/cams
  238. GT exhaust?
  239. ?Fuel Pump?
  240. how much power before boom!
  241. size of front windows and back glass 98 gt
  242. 4:10 3:73 gears
  243. LT HEADERS INSTALL
  244. Is this worth it?
  245. Whats Next?
  246. NEW MAF? What does this do?
  247. Water Pump 01 Difference
  248. With these mods...
  249. is anybody putting down 400ish hp???
  250. New clutch advise
