View Full Version : 4.6 (Modular) Mustang
  1. What fuses to look for with battery light?
  2. 1998 Mustang Gt piston questions
  3. A/C Troubles...
  4. help please! fast!
  5. possible to re-use programmers?
  6. Looking for a full-featured programmer
  7. Battery Pull
  8. ridiculous gasket.
  9. Someone with a Bullitt Mustang please help!!
  10. Remote problem, can't start car PLZ HELP
  11. pi swap help
  12. what cams for kenne bell GT?
  13. pi swap with supercharger or bottle ?
  14. I Think I Cracked My Intake Manifold...now a batt light. WTF!
  15. more exhaust help pls
  16. intake plenum ?
  17. Long Tubes???
  18. car wont start
  19. Stock Intake Mod.. Good idea or no?
  20. Timing Help Now!
  21. smoke problem
  22. New Clutch, Question??
  23. Diablo Tune
  24. What mid pipe to go with Borla catback??
  25. Are pulleys worth it?
  26. clutch Question
  27. Shift Kit for an 04
  28. Emergency Brake!!!
  29. p2272?
  30. PI swap question/ Car dilemma- UPDATE
  31. sound clips?
  32. loss of power>????
  33. ACCUFAB TB AND PLENUM
  34. What are iso's?
  35. Help plan my exhaust!
  36. iac mod and AC
  37. How to loosen chain tensioners.
  38. Stock Intake... Boot or no boot?
  39. Power Train ("Pnnnn") DTC Search Tool
  40. Accufab TB and Plenum install
  41. is this true about intake manifolds
  42. Car is getting a little hot
  43. Radiator looks like its leaking. Is this a good idea?
  44. Speedcal for sale-Cheap and New
  45. What H pipe for my car
  46. Need help check engine light came on today!!
  47. Good price for gear package?? Opinions
  48. need advice on trouble code
  49. Motor Fried
  50. Hypertec Hyperpac...Can i use one that came out of a different Mustang?
  51. PIC REQUEST eibach drag launch kit
  52. No underdrive bolts...
  53. Rough Idle after new fuel pump and IAC cleaning
  54. Vacuum Leak
  55. how long are slicks good for?
  56. Bilstein shocks/struts ?
  57. tokico illumina/adjustment
  58. Guys...I need help! FIXED!!! JUST THE BELT!
  59. exhaust
  60. smoke and gas
  61. gears or midpipe?
  62. Another IAC mod Q sorry guys!!
  63. Type of gas?
  64. Grinding when i'm slowing down..
  65. Shift kit install gone bad.
  66. PI Intake Swap---How To
  67. Off Road H pipe problems on 98 Mustang GT
  68. Adjusting headlights
  69. MAC 4V LT header and X-Pipe package starting at only $650 Shipped!!
  70. aftermarket gauges
  71. Drag radials.
  72. PO452
  73. hard starting
  74. crate engines??
  75. Throttle sticking anyone?
  76. need some help
  77. How much HP?
  78. my firends car
  79. intake help, asap
  80. Any1 know where EGR Delete goes?
  81. Proper way to clean engine and bay area
  82. Transmission question on 96 GT
  83. Question about startup
  84. NEED HELP!?!?!?!
  85. Installation of Zex Kit.....Anyone have tips?
  86. Rear passenger clunking
  87. A fun WEEKEND
  88. Water dripping on exhaust manifold
  89. speedo recalibration ?
  90. Focus Fuel pump?
  91. Electric gauges
  92. installing a pushrod and away with the modular
  93. sound clips please
  94. Exhaust Ticking?
  95. GEM
  96. 4V Swap???
  97. Please Help!! Newb here!!
  98. Exhaust popping more than normal and check engine light on
  99. Check Engine Light, IAC MOD
  100. Which gears should i get?
  101. Voltage Regulator (HELP)
  102. emissions
  103. chatter felt through stick @ ~2800-3000rpms
  104. Cams And Emissions
  105. 03/04 cobra fuel tank and dual pump
  106. MORE POWER!!!
  107. Removing The Thermostat Crossover
  108. Exhaust sound
  109. Where to buy?
  110. FPSS
  111. what clutch do you run?i
  112. Tranny fluid change
  113. Do Chips Really Work?
  114. Tuner help.
  115. question about alignment or bent control arms
  116. I F*d my driveshaft today
  117. 98 Mustang Gt brake light Problem
  118. sound after x pipe installed
  119. Lowering the Stang
  120. What to gap my plugs at?
  121. IAC MOD INSTRUCTIONS PLEASE!
  122. 02 Roush, need tune up advice
  123. Bug guts issue
  124. running lean code p1157
  125. o/d light
  126. starter wont come out
  127. is there another tps wire i can use?
  128. RACK AND PINION!!! ANY SUGGESTIONS
  129. Will my JLT fit an accufab TB
  130. 2V Heads
  131. Auto meter gauge pods
  132. NEED HELP Mustang is making some strange abnormal engine noises
  133. 00 GT manual Trans fluid
  134. Help key wont turn in the ignition
  135. questions about ecu's and programmers for mustangs
  136. clutch quadrant
  137. Short Shifter???????? Thoughts
  138. what are my chances
  139. Installing upraded Brake Kits - Instructions w/ Photos???
  140. cam
  141. debadging
  142. underdrive pulleys and short shifter
  143. Misting Green Stuff
  144. Roush ThrottleBody
  145. Does anyone have a pdf file of a procharger install manual for 96-04 gts?
  146. ticking sound still there! HELP!
  147. Next...?
  148. Spacer or no????????????????????
  149. rebuilding alternator?
  150. VT cams
  151. metal particles in oil
  152. Area calculation of MAF screen...who's removed their screen?
  153. Engine Issues?
  154. Coil Pack Upgrades
  155. Clutch.....
  156. what helps top end?
  157. Gauge cluster swap ?-help
  158. PYPES X PIPE????
  159. Any dyno #'s on the new TrickFlow from members?
  160. Wheel pulls
  161. Did rear brakes, caliper cage hits rotor!?
  162. Best Place to get an front end alignment?
  163. TYPHOON INTAKE
  164. Gear Grind
  165. instrument panel
  166. 2V intake manifold options
  167. Wierd noise at idle.
  168. spark plugs, I know repetition....
  169. 2v to 4v
  170. Is my Cat. Busted? (Vid inside)
  171. anyone get the strauss fuel system cleaning?
  172. 4.6 Newbie
  173. Lighter fuse
  174. what mid pipe should i get?
  175. exhaust people
  176. how much was it for you to get your transmission rebuilt?
  177. Slow top speed... or is it just me?
  178. FoxLake 2V P51 Intake???
  179. Idle Drop while pressing brake hard on idle? normal?
  180. coolant leak
  181. spark plugs
  182. exhaust recommendation
  183. Springtech shocks/struts
  184. Whats Missing?????!!!!!!
  185. SCT Settings for Automatic?
  186. what parts needed for purge kit?
  187. REAR BRAKE NOT RELEASING
  188. Teksid Block
  189. Are these Steeda's right?
  190. p0171 bank 1 lean and p0174 bank 2 lean
  191. can't get fuel filter off
  192. Looking for paint, please help!
  193. HELP!!!!!!!!! please
  194. Electrical short
  195. New Stang..routine maintenance
  196. A different Vibation
  197. groaning noise from what i think is rear suspension.
  198. Tranny Questions
  199. Gear Question
  200. Door locks & Trunk button stopped working
  201. I need a wiring diagram for a nitrous relay
  202. dead battery?????
  203. Whats the fastest way to install headers?
  204. O2 sensor causing the problem??
  205. pinging?
  206. ECM Pinout, Where is the speed sensor wire
  207. How to differentiate between stock PI and stock NPI cams
  208. suspension noise?
  209. Clutch item installations
  210. Tire Blow Out Going 65 mph
  211. Steeda Pullys And Belt??
  212. Does anyone have a procharger installation manual?
  213. help question!!
  214. differentials
  215. 96 cobra - lca relocation bracket
  216. What is next???
  217. Factory alarm with emergency back-up key?
  218. Mods question
  219. Driver window regulator broke
  220. Burn out question
  221. Compression Test Results
  222. Quick SLP question
  223. Grill delete installation??
  224. which headers..
  225. Where to put jack stands
  226. CEL help
  227. Reverse Popping Out ?!?! HELP
  228. Wierd smell coming through air vents
  229. Putters when i step on the gas!!
  230. oil in the spark plug thread
  231. annoying rattling
  232. can i use a window switch to supply power, besides take away ground?
  233. Tips on Replacing Header Gaskets
  234. flowmaster
  235. Found a 98 gt 5spd.
  236. How do I adjust timing?
  237. how much hp gain?
  238. New in the Pony Class
  239. New in the Pony Class
  240. Best Maf to use with D1-SC s/c?
  241. confused
  242. throttle body spacer q's
  243. Computer adjusts timing?
  244. Car won't drive properly with new H-pipe
  245. metal shavings in oil
  246. Trick Flow intake manifolds
  247. What is a Terminator mustang?
  248. Muffler question
  249. Straight Axle to IRS Swap
  250. whats the best thermostat?
