View Full Version : 4.6 (Modular) Mustang
  1. o2 sensor HELP ME PLEASE
  2. GOOD SPRINGS?
  3. cobra calipers?
  4. tail lights question
  5. what to do next?
  6. whats the deal?
  7. Bank 1 lean
  8. A/C vent rattle
  9. BAD SITUATION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  10. speedo question
  11. Plug-In or Slice-In Eliminators??
  12. In a bit of crunch
  13. Need somebody who know's the 4.6 pretty good
  14. Spark Plug Blew Out The HEAD !HELP
  15. 2000 Stang Making A popping Noise
  16. oe wheels
  17. stock mid pipe.. 10 series or super 44 series flows?
  18. Stripped Strut...
  19. removing nut on top of strut
  20. clutch adjustment
  21. Need a little assistance with a couple questions.
  22. 2002 gt mustang a/c compressor replaced and still not working
  23. Question on rim/tire size
  24. CDC Shaker
  25. PCM fuse blown twice, questions..
  26. Chandler AZ area shop needed
  27. Need rear gear recomendation for my 98 GT
  28. 1998 GT Mustang Coil Springs on a 2003 GT Mustang?
  29. SNIPER tuning for a supercharger (AFR)
  30. 01 gt got better milage than my wifes 07 kia
  31. Crooked Lowering Job
  32. AOD Aluminum Drive Shaft ???
  33. PI question
  34. Advanced IAC question
  35. Overheating
  36. so I need some new brakes...
  37. where to get billet idle pulley
  38. clutch replacement with full length headers
  39. Mongoose kit but what supercharger?
  40. New to the forum, need help with power seat!
  41. I broke it....
  42. Where to get this??
  43. Will this transmission oil be ok?
  44. COBRA ENGINE REMOVAL
  45. problem with tb plenum install
  46. WOW engine blew on me...
  47. 99 Mustang Spark Plugs
  48. noise when clutch pedal not depressed
  49. Different size water pump
  50. Blinking theft light wires????
  51. diablosport predator tuner
  52. Aftermarket clutch noob question
  53. A/C has mildew smell!
  54. The worse TO bearing noise I've ever heard.
  55. Theft Light ON and car wont start
  56. Need power for seat lumbar.
  57. sct sf3
  58. caliper bolt spacing
  59. New Alternator, which one?
  60. Transmission problems?
  61. Yes another 5.4 swap thread
  62. Turning off airbag?
  63. I snapped a bolt off in the head HELP!
  64. Squeaking in/around engine
  65. 1998 GT Exhaust Hanger Question
  66. AC questions
  67. Transmission shop may have not installed the gears they said they did..one year later
  68. Got a clunk....
  69. 2003 GT Mustang White Face Cluster Panel Problem
  70. wierd problem
  71. Help with pypes off road x pipe
  72. brake rotor red hot
  73. EGR line question
  74. ding ding ding noise
  75. Fuel Line Problem
  76. Supercharge or Cobra????
  77. TCI Streetfighter ratchet shifter YES or NO!
  78. Front Sway Bar Removal
  79. braking/steering problem..
  80. 5.4 swap
  81. mail order tunes
  82. need help with noise
  83. My Mustang build plans...
  84. Well just a ramdom question....
  85. Tuner not licensed to be used on this vehicle?
  86. Dang Drvier Side Window
  87. shocks/struts
  88. Exhaust leak after o/r pipe install... ideas?
  89. WTF! Rear end was completely dry!
  90. removing my wing
  91. name that noise
  92. Cobra brake upgrade issues?
  93. E3 Plugs
  94. 99 COBRA ENGINE REMOVAL TOP OR BOTTOM?
  95. Black Coolant
  96. smoking lights
  97. Generic Electronic Module (GEM)
  98. Question about flywheel
  99. Weird Noise 98 Cobra
  100. Batter relocation?
  101. 99 Mustang K Member
  102. 02 4.6 GT Won't start- Service Engine Soon w/ no codes
  103. A/C for Dummies!
  104. Droning noise = bad bearings?
  105. 3.73s
  106. A/C HELP PLEASE
  107. Battery Cables + radiator hose.
  108. Options for built bottom end?
  109. Bolt on suggestions.
  110. T5 to T3650 Swap
  111. Torque Converter Write Ups?
  112. 99 Mustang Rear End
  113. Fox struts/shocks on new edge
  114. need some help 4.6 2v crank
  115. Best shifter for banging gears?
  116. can someone help?AC issues
  117. Saleen Intercooler
  118. Is this ricey?
  119. What the heck are all of these wires?
  120. new motor and tune; now vortech is acting up?
  121. workin on the 4r70w
  122. Jackscrew?
  123. Been A While - Intro(Help)
  124. gimme some numbers
  125. 4r70w information
  126. Tuning?
  127. 2003 GT Fuse Box Diagram
  128. What do you think good deal?
  129. Strange rattling under car
  130. Can't stand it!!!!!
  131. Rear sway bar
  132. Three pondering questions on 4.6 DOHC and IRS swaps
  133. Took may car to the shop and they found a very strange issue...
  134. Rear Lower control arms? Uppers too?
  135. camshft q
  136. Best UCA's/LCA's besides Maximum Motorsports?
  137. HVAC LED swap question
  138. Off-road x-pipe questions
  139. 18x10 275/40/18 too big?
  140. Anyone use a 90mm Lightning Mass Air with a Vortech SC.
  141. General Oil Questions
  142. What if I change my tranny fluid?
  143. Exhaust Question
  144. Vortech losing fuel with 400who at around 6000rpm?
  145. 3.90 or 4.10 gears? and aluminum drive shaft.
  146. ? on egr delete
  147. has anyone put another motor other than a ford in a sn-95?
  148. HIGH BEAMS
  149. code p0320??
  150. Water & Anti-Freeze in Oil!!!!
  151. Nitto NT555Rs up front?!
  152. WTF????
  153. NOS guys help
  154. Which gears?
  155. What is this noise?!
  156. Tranny cooler help needed now!!
  157. HELP...lost wheel lock
  158. Seats?
  159. Sounds like mudder tires wawawawaw...
  160. A/C won't blow out of dash vents.
  161. '03 Cobra 18x10.5??
  162. MAF sensor Error... Any ideas
  163. time to replace my convertible
  164. Back wheel grinding/rubbing sound...what is it?
  165. TEKSID TIMING CHAIN GUIDE ISSUES USING ROMEO PARTS
  166. Body Mods
  167. Need help asap
  168. Squeaky alternator?
  169. MM Full Length Fubframs.. Powdercoated or steel??
  170. Threw a rod..Maybe. Help!
  171. Aviator swap help, 96 GT
  172. Cam help for Pi Swap
  173. New here and have a ?
  174. Throttle body question
  175. Is Aftercooling a Vortech Si V3 on a 99 Gt worth it?
  176. Mysterious Squeeking, Front Suspension help
  177. Where does this go?
  178. Will I need MIL eliminators?
  179. Strange 10 ways w/ coilovers?
  180. Moates or Megasquirt?
  181. COP Information
  182. Need help with A/C - getting hot in Phoenix!
  183. How do I keep my 4R70W cool?
  184. Control Arm Install: Cannot re-install sway bar
  185. Car Shut off Doing 80ish
  186. Boost - valvesprings question.
  187. GMS Tubular A-Arms
  188. supercharger advice?
  189. need suggestions
  190. Rocker Arms
  191. front suspension
  192. drivetrain going bad?
  193. Ive got a problem,a crazy one too
  194. 98 GT J-Mod Question
  195. 96 GT charging system problem
  196. 1996 GT running rough. please help!!!
  197. plugs, oil, drive shaft?
  198. Coolant leak
  199. clicking sound from passenger side fender
  200. Bad Stuts
  201. PI head model # questions.
  202. no fire
  203. ECM on 2000 mustang
  204. S/C 2000 GT help
  205. Pro-Kit or Sportlines??
  206. 4 cyl springs for drag springs
  207. Why did my car stall?
  208. Running wierd
  209. 10# procharger pulley size?
  210. Lifters/lash adjusters$$$
  211. Licence plate names?
  212. Sniper Tuning Results.
  213. Car overheats
  214. How To Resolve B 1353 Code
  215. Strut Tower.....
  216. Catted H on stock mufflers?
  217. Front sway bar removal
  218. Low Fuel Tank Pressure?
  219. Diablo Chip
  220. Plugs
  221. RIIIIMMMMSSS
  222. 99 mid pipe question
  223. Confused over Flowmaster customer service
  224. Converting to Manual Transmission
  225. Gear break in period
  226. Question on Cams
  227. Cobra Supercharger
  228. Hoist
  229. intermittent miss usually under load COP?
  230. My Motor Is Lagging!!!!PLEEEAAASE HELP!!
  231. Strange things going on... HELP PLEASE!!
  232. Back behind the wheel of a mustang and have some questions
  233. weird new problem
  234. carbureted engine
  235. What's a good replacement clutch for a DD
  236. Tensioner pull stop:
  237. catlitic converter question.
  238. FUEL PRESSURE for Cobra (Supercharged) what is it?
  239. spark plugs
  240. SCT Chip Switch Cars?
  241. EVAP & Fuel Pressure Problem
  242. PLEASE HELP!!!!
  243. Shifting RPM
  244. Power Control Module
  245. burnout question?
  246. Squeaking noise when rolling
  247. question about sct tuner
  248. Replaced a head gaskets
  249. Traction control freaks out
  250. Clutch Maintmence?
