- roaring sound
- 03 Cobra engine in 96 gt...?
- Car keeps overheating
- Mac Products End Of Summer Blow Out Sale!
- Huge Tru Fiber Hood Sale!
- Blew coil pack. HELP!!
- Radiator Fan Problems
- Loud Whining Sound HELP
- Bent axle or caliper wont fully release
- help with gauges
- SC Experts look here
- Car stuck in reverse!!!!
- Install New Driveshaft
- Lean bank 1 & 2 HELP
- battle boxes
- long vs short headers
- Nitrous Help!
- Need Help from you Supercharged 4.6 guys
- convertible top soaked inside help please quick
- Very weird Check Engine Q
- Header install
- MOVED: 3000GT
- Which exhaust to buy?
- yes another 2v to 4v Q
- Which replacement pedals?
- 2V parts for 4V
- Transmission Problems?
- how much oil will drain out if filter is removed?
- manually shifting my auto
- Who has a Centerforce dual friction clutch?
- Front Brake Upgrade
- Smoked lights?
- Clutch install writeup?
- removing A/C compressor...how?
- Battery power drops on idle
- bought 4.10s
- 15/16G Turbo
- Midpipe
- Chasis & Body Question
- tranny oil change in a 5-speed gt
- cut-outs
- Just Wondering
- Bullitt Wheels -
- NOS vs NX jet sizes
- Third Brake Light Housing - Replace?
- REAR MOUNT TURBO?
- 90 mm lighting maf
- new pics. of my car from auto-x 8-19-07
- will a TB/Plenum from 2000 GT fit on 96-98 GT??
- FRPP pedal install Q?
- Are these project headlights a good product?
- Engine gushing oil!!!!
- x pipe
- Brake change problem
- Mach 1 bumper chin spoiler question
- quick question
- Cold air ?
- A/C
- What should I get?
- Lights Won't Turn Off...
- 2nd Gear Whine..??
- HELP cylinder 6 is misfireing
- long tubes for both romea and windsor?
- Realistic Power?
- Spare Tire
- SLP Loudmouth 1 or Loudmouth 2????
- coil packs and plug wire routing?
- ? on a new thrown code??
- Shocks that dont suck...
- Camshafts explained
- ram air hood gt questions
- Ford C Springs
- installing an A/C bypass pulley...how?
- brake job
- vortech
- vt 2 cam guys come in!!
- Engine turning off?
- transmission whine
- Hood Scoop Question
- emergency brake problem
- Need suggestions from resourcefulness masters
- PI heads
- calling all tko swapers
- Cobra brakes...
- New NX kit installed need help with pills
- this is weird
- 6 disk not working, does yalls do this?
- brake pedal sqeak, help
- 99' Cobra vs. Mach 1 Poll
- tranny oil change
- odometer stopped!!
- Dyno tunes in MIchigan
- P1270 - Speed limiter Reached, Help?
- rear end....hopefully FIXED!!!!
- No More 4X4 (Pics)
- Pistons???
- Strut help ASAP
- Gapping plugs for nitrous
- Steeda Race Wing??
- 60# injectors needed?
- 5spd to auto
- Critical Desicion
- a/c question
- What type of Flywheel should I get for a Cobra motor?
- bassani mid pipe
- Convertible Top Cleaner
- bypassing A/C?
- Octane troubles
- Track
- What do I need to cut/hack for procharger install
- woohoo
- Built 98 cobra..how much nitrous?
- Safely dropping weight off a vert
- blower cams..
- Running rich?
- Got the stang tuned!!!! Track times!
- cold air problem
- Spring Isolators
- Can you guys check my wire diagram for my nitrous setup
- Too much fuel for a NA setup??
- heads
- P# for SVT FOCUS PUMP?? Hurry Please
- which pill for wet shot
- what kind of number would I lay down?
- Spring Difference??
- rear suspension set up need info?
- Typhoon Intake???
- Clutch release bearing help!!!
- Ways to tell gears apart!?
- calling tko swappers
- Will a 99-2004 cat back fit on a 96 gt
- NOS for my 06 gt
- o/r h is in.... just few questions, big pics, beware
- procharger
- TKO500 LUBE
- After PI Swap, tune?
- Need Rubber Seal
- Baer Brakes
- P&P TB and plenium
- track
- Really bad noise - help!
- cobra heads 2v block?
- Funny noise...
- how to sump my gas tank?
- t/b plenum cleaning
- AODE to 5 speed
- Accufab 75mm TB & Plenum
- New BBK MIL ELIMINATORS CHEAP !!!
- GREEN MUSTANGS
- removing fuel rail NEED HELP
- Signs of bad engine trans mount
- Need new front bumper...Where can I get one?
- K&N vs. BBK
- 4.6GT Block question
- pi intake
- Whats better?
- Squeaking pulley. Not sure which one?
- rear end dead ??
- guys with widebands
- Chattering noise ...
- rear wheel ABS sensor
- LOCK ME!
- Bought SCT XCAL2!
- clutch freeplay question
- Bumpsteer Kit?
- need help quick?
- Rim spinning on tire
- EFI or SFI
- where did u get 97 fan
- check engine light after pi cam/ intake swap
- Do you have 4.30s, if so GET IN HERE!
- Exhaust Loose? Weird Noise ....
- Catback Exhaust
- cam replacement
- Pinion Leak please help
- Gears
- New Mustang
- New Stang and some ?'s
- 3.73/4.10 top speed
- Pinging
- Nitrous...
- would...
- rings blown need some help and advice on rebuild
- Installing NX Kit, Need help with predator
- Rear gear questions-Again!
- 4.6 help please
- overlay sticking needles
- Hey, whats your Auto gt 1/4 mile times
- 2005+ rims on a 94-04
- What transmission is this?
- intake manifold
- Nitrous/Fuel nozzle....
- about my pulleys
- headers and x pipe setup
- T3650 PARTS & FLUD LEVEL INFO
- transmission help
- 2003 COBRA ENGINE
- tranny/rear diff fluid for 200 mustang gt
- knocking on cold start
- clutch noise
- what size swaybar comes stock
- NOS window switch
- Diablosport Predator
- IMPORTANT INTAKE QUESTION
- MGW getting "knotchier"?
- inconsistant gear engagement
- 3650 limits?
- where is a switched 12v souce i can use for my solinoids/window switch?
- 3650 fluid change...
- Pulley question....
- Need advice on Intake Kit
- caster camber plates
- clutch/quadrant re adjust
- 02+ mustangs with nitrous using fpss
- LOUD CLUNK
- i need to hear an opinion
- baaaaad feeling
- is open headers safe on motor?
- Will 500rwhp be obtainable?
- 1998 Mark VIII 32V
- what size belt
- NEED HELP!!! Throw out Bearing??
- its official
- Does my car hate me?????
- Spoiler delete
- High RPM At Idle
- weird sound
- help!!! question!!
- Wheres the best place to get gears??
- Clutch Install Writeup???
- rim pics
- Need info about EGR
- hey guys, SCT question!!
- Nitrous with a stock motor
- best guages to get?
- Machine Gun
- Do 96-98 cobra's have a 6 or 8 bolt crank??
- 2v to 4v
- need help ASAP
- Mustang Dying! Please help!
- Weight diff. between 2v and 4v motors???
- How to replace wheel studs?
- grinding 2nd sometimes
- Saving for big mod what should I do ?
- Pinion Seal Leaking
- catback exhaust?
- octane
- 4v swap Fuel pump) questions on 96-98 models
- Power Steering Pump Disassembly!!!!
- cost of nitros
