View Full Version : 4.6 (Modular) Mustang
  1. Fuel pressure ?
  2. Need Help!!!
  3. Help with Pop's 04 vert? Startup sound
  4. shifting issues at the track
  5. My car lacks power..What could it be?
  6. License Plate Question need help
  7. exhaust cutout placement
  8. which tuner
  9. Really newbie question... sorry...
  10. Correct my if I am wrong please.
  11. header gasket install?
  12. Another 4.6l head question
  13. Longtube midpipe fitment issue
  14. I'm new and wondering how much hp.
  15. Tranny Temp Spike
  16. Inconsistent clutch pedal question?
  17. IRS to solid.Anyone Local? R.I
  18. should i attempt it?
  19. 2000 Mustang GT and the stiff clutch/shifting
  20. hoods
  21. Rear end shake
  22. 99 gt motor swap in 98 gt
  23. F/I Q'sss. . . ?
  24. NEW PARTS IN SOON!!!
  25. throw-out bearing
  26. Gear install in Indiana
  27. Long
  28. MM Torque Arm
  29. About exhaust Backpressure
  30. Do you have a 2002 GT Manual?? Please help
  31. 4.6 swap from a 3.8.. what bellhousing
  32. Nitrous + texas heat. Bad?
  33. rim and tire
  34. 3v or 4v swap?
  35. Removing Heads
  36. Centrifugal vs. Roots
  37. S/C on an 04 GT
  38. Head Swap From a 2v to 4v Anybody have any Ideas
  39. SCT Livewire
  40. where to buy a speed cal
  41. Transmission
  42. Non-pi block
  43. after clearing codes....
  44. Car wont start after instl. of K&N cold air
  45. 5.4 questions.
  46. looking at some mickey thompsons et drags
  47. good suspension info inside
  48. Radiator for a 1996 Mustang GT?
  49. New Clutch - New Problem
  50. Cobra Short block
  51. Wheel Bearing Gone Bad?
  52. '96 Mystic...needing Mod Advice
  53. Need help on Choosing Springs
  54. Stall/Tourque Converters
  55. cost of gear install
  56. Aftermarket GT automatic Shifters??
  57. Need Line Loc Pictures of Install..
  58. 4v problem
  59. Headers
  60. Programmer best bang for buck ??
  61. Squeaking Sound From My tires???
  62. steering box/tie rod problem?
  63. pistons
  64. procharger?
  65. Slight bucking
  66. cruise control
  67. How to change trans fluid on T-3650?
  68. PI Head tech
  69. newbie here
  70. 98 GT PART NAME?
  71. Long Tubes In Illinois???
  72. Mustang Featured Marque
  73. Oil Leak
  74. tune affect abs
  75. wicked idle
  76. Cobra vs GT Springs
  77. Drivers side window won't roll down
  78. Water + engine = bad (plz help)
  79. Crap ass Rack and Pinion
  80. Pistons and rods
  81. Ford Racing Springs
  82. Porting?
  83. Removing 3650 bell housing?
  84. temporary quiet exhaust?
  85. Mustang Auto Engine
  86. The Diablo Predator Tune
  87. turning over way too long
  88. Brakes and rotors question
  89. car clicking/sputtering sound
  90. Car acts like a it's carburated
  91. Fuel Problem...Please Help!
  92. O/D off?
  93. performance shop told me not to get a tuner?
  94. Idle rpm adjustment question
  95. a/c vent door sloooooow to move
  96. Heli-Coil : HEAD FCUKED UPDATE
  97. Change color of entire Interior??
  98. WTF was that sound
  99. Transmission bolts ??
  100. Transmissions and LT's
  101. How to Window Fix
  102. Tuner question
  103. torque converters?
  104. found out what was wrong with her!!!
  105. I HAVE A QUESTION!
  106. Chips and tuners?
  107. clutch travel
  108. 3.73 install
  109. tranny question
  110. 6 BOLT and 8 BOLT Cranks TECH Question
  111. Long tube header install pls help
  112. Tire balancing????
  113. clutch adj
  114. v-6 to v-8
  115. shrt shift adjustment
  116. Quick help please!!!
  117. Help! Pictures included, 56k warning
  118. Changing Spark Plugs HELP
  119. Windsor/ Romeo bolt pattern
  120. got a problem starting?
  121. How to install my oil pressure gauge?
  122. Dilemma with upgrading fuel system…
  123. rear end noise fixed!!
  124. $5 to whoever figures this crap out.
  125. D-1sc with Stock motor
  126. short shifter
  127. hit the brakes hard, now it feels notchy
  128. A/C motor?
  129. Required Reading - Lots of Tech Info
  130. Oxygen sensors Pass side removal
  131. Start-Ignition Wires
  132. STEEDA QuickRelease quadrant and firewall adjuster combo
  133. automatic trans
  134. Blown axle seals
  135. Belt For Steeda UDP's??
  136. swap my 5.0 for a 4.6 or cobra motor
  137. A pop sound when under hard acceleration
  138. HELP!! HELP!!! Isthe shop F*ing me?
  139. mils
  140. service engine soon light is on
  141. Help with squeak
  142. Method for Cleaning MAF
  143. 1996 Oil Capacity
  144. BUILT MOTOR
  145. Guage lights went out!
  146. 98 GT tranny fluid?
  147. coolant leak where from ?
  148. Can anyone help me find..
  149. cams and emissions
  150. new k member and spring rates?
  151. dynotune nitrous
  152. Loud Squealing!!!!!Help!!!!!
  153. X-pipe, exhaust size...
  154. DOHC Swap?
  155. SN95 Tire Fit?
  156. Nitrous Help Needed
  157. adjustable clutch cable
  158. How to remove pinion????
  159. What to expect...performance wise???
  160. Can't figure out the vibration in my car?
  161. Forged Bottom
  162. Headers & X pipe Q's
  163. CHANGING fog lights
  164. Falken 512's????
  165. Head Fcuked?
  166. ONLY RIGHT REAR SPINNING????
  167. Forged Rotating Assembly
  168. i have a leak...
  169. Bucking in first and second gear
  170. turbo questions
  171. I am reading alot about oil changes my Q
  172. Cold Startup Sputter/Leak sound? 2004 GT 5 speed.
  173. pi swap hp ?
  174. P-51
  175. spring install help asap!
  176. Speedometer Problem...
  177. Where do i tap a 12v line for nitrous install?
  178. 98 gt exhaust
  179. HELP with cobra
  180. 275 tires on stock GT pony rims?
  181. UDP's
  182. Best Rear End
  183. A/C on making the floor very wet!
  184. In the middle of a header install need help NOW PLZ
  185. Questions for performance valve body
  186. cams on high milage motor
  187. Exhaust Leaking
  188. Car trouble again...
  189. It IS a Technical Question!!
  190. Noone came seem to HELP me out
  191. coil springs from 02 to an 88? possible?
  192. Emission testing
  193. CAR WON"T START!
  194. stiff clutch! why?
  195. stock block
  196. tick in engine
  197. those with short shifters
  198. IAC Issues
  199. Need some HELP, hit the curb!!
  200. Changing brake pads, quick help please
  201. what is the top gear ratio in a t-45?
  202. screwed valve?
  203. noise when turn steering...
  204. 4V SWAP HELP PLEASE!
  205. Oil Change
  206. Veteran Stangbangers: Help a n00b out! Suspension noise!
  207. 275's on bullit rims????
  208. Question on 5.0 pro shifter
  209. 2004 GT Vert - Subframe Connections Question
  210. Epoxy putty
  211. noticed some smoke at high rpms
  212. 98 blower on an 03?
  213. Need help with my H pipe
  214. Will these trans fit and whitch one is better?
  215. Transmission question
  216. Normal Leak??
  217. 5.4?
  218. Anyone here have the Jet Programmer?
  219. Bad battery fried alternator??
  220. Anyone Running 05+ Rims?
  221. rough idle
  222. Spring Problem.
  223. Kevlar clutch and lightweight flywheel
  224. Short shift kit?
  225. Changing heads, installing LT headers?
  226. Timing chain service+tensioner
  227. 96-98 cobra owners....JLT CAI question
  228. Installing CC Plates
  229. TRACTION CONTROL
  230. two questions in one: gears and tranny
  231. Brake pistons
  232. new clutch and problem shifting
  233. crate engine problem
  234. Nitrous Pressure Gauge
  235. Ticking noise from Midpipe?
  236. quick tire help?!?!
  237. ticking noise please help!!!!!
  238. is my ac compressor shot?
  239. Installing my RAI
  240. broke FR strut from hitting curb! Walk thorugh?
  241. Steering wheel going ugly
  242. Steering Response...
  243. TPS Switch A Circuit Low Input
  244. Any trick to get wires through firewall or into trunk with a convert?
  245. Exhaust question just brought to my attention
  246. rear Shock mount???
  247. Ticking, rattling noise from behind dash
  248. Do i need high temp wires? & How do you install them?
  249. a few things taht i was wondering about
  250. Needs Help Please
