- Clutch Maintmence?
- COBRA BUMPER ON GT
- Hey everyone
- can someone explain coil bind?
- cobra side skirts on gt
- dallas emissions/shop
- Time for torque converter...clueless.
- new engine
- 38CC TFS heads - who is using them?
- 99 Gt Brake question
- Improving the sound of my '96 Cobra 4.6L
- 03 GT Burning oil. Where from?
- Adding horsepower tomorrow
- How to smoke fog lights...
- Will a DOHC fit in replace of a SOHC
- camshaft positioning sensor
- Buying an SVT cobra next summer
- can a hand held programmer help me?
- Rear End rebuild.....is it needed?
- Windshield wiper arms
- 12 second car
- Good Rear End shop in NJ?
- P0406 Exhaust gas recirculation sensor a circuit high
- What's the most I could get out of a N/A 96 GT?
- Need info on reverse lockout solenoid.
- Check Engine Light...no idea
- aluminum fly wheel
- 03 04 cobra front bumper?
- New struts
- Want to get an off-road H pipe, unsure which one 2 get
- Coolant Leak Help Please
- Sticky Clutch.
- HELP! Can't get Trans. loose from Engine
- P0720 Output Shaft Speed Sensor circuit
- Need help! Motor missing poss after wash
- LCA Question
- idling
- Removing Factory Bushings...
- Road Race Suspension at the 1/4 Track??
- Gear whine (HALP!)
- Tach Question
- My first mod
- explosion
- Tune trouble?
- npi cams vs pi cams
- Just installed JLT CAI, Accufab 75mm Throttle Body and Plenum
- how many 1/10ths might i increase??
- Gridning after you shift
- I hope this isn't serious
- Important Support Mods...?
- starving lifter?
- 4 cylinder fox springs on 99-04 GT
- Check Engine - P0340 Cam Sensor
- Clutch
- line lock/ roll control
- A/C doesn't work, CCRM?
- question on emissions
- GT Headers
- Mach 1000 Audio in my 97 Cobra>?
- few trans questions
- Drag Suspension Question????
- HELP!! underdash wiring diagram needed
- boost question for an educated answer
- Vortech Problem In Rain
- spark plug gap????
- Reverse lights not working
- dorman intake on 98 mustang gt
- 4v auto trans?
- Need help please, Missing
- Engine/Trans Question?
- 3v motor swap ish
- A/C-Heat Issue
- 99 Mustang Gt Driver window problems
- longevity of various super chargers
- PI motor Swap ?
- problem?
- Trans. removal help?
- 98 Cobra oil ?
- HUGE PROBLEM - 2003 GT, TECH/CPU
- Problems with Idle while operating A/C and Defrost
- Losing gear oil behind brake
- Squeaky driver's front?
- Intake Manifold Information
- PROPER SETTINGS PLEASE ! ! !
- Exhaust what did I do wrong.
- air conditioner problems
- XCAL 2 question??
- Annoying squeak from rear of car
- 04 cobra gage cluster does not iluminate
- intake manifold
- t-45 transmission install problem
- Need help identifying two wires on my 96 GT.
- do i need a new O2 sensor and tire question
- Fog Lights
- Transmission starting to piss me off
- 03-04 cobra motor in my 97 gt
- Intake Question
- Installing pypes o/r X and have a question...
- What jets do you guys run for a 125 shot?
- please help cracked block
- Front Plate
- 2003 cobra foglights
- Odometer help needed!!
- wanted more horsepower
- SVT Focus pump question
- 00 Mustang Gt coolant light is on and engine light is flashing
- 2000 Mustang GT Check engine light flashing
- Printable Clutch guide for 2v pls.
- Help Please. Clutch problem!
- Prepping for auto X - watts link & torque arm owners chime in!
- Blinking "theft" light... car won't start, but not a bat. issue
- Typhoon Intake
- Recalibrating Speedo
- Can someone explain what causes gearbox to slip out of 4th gear
- Lean condition at part throttle/decel
- removing sail panels?
- 18% overdrive?
- Aftermarket White Gauges
- Would the new 2010 mustang wheels fit my 96 mustang?
- ticking
- need power window help asap
- vortech guys come on in..
- diy nitrous tune....is it worth it?
- Engine Swap
- trouble code's
- rear end is gone!
- HID VVME Defective
- will these work?
- OEM or aftermarket Throw out bearing?
- street/strip suspension order
- Battery light turns on when I open it up?
- Problem with rear power window
- Belt Squeal starting @ 2K rpms
- sct sfc for 2003 gt
- radio bezel help
- 3.73 swap / now i get vibrations?
- Power surge @4800rpm +/-...any ideas?
- Anyone who's taken gauges out know how to remove the air bag light?
- Power window help please
- Blown head??????
- Fuel filter location? 1996 GT
- slp proflow
- 2000 4.6l gt2v intake, plenum/trottle questions
- need some quick questions answered
- ticking noise
- crazy high idle issue
- tranny work
- vvme ballast location
- Engine Coolant Gauge INOP
- Tail light Problem
- Spark Plugs and Rear End Oil
- What type of Summit starter?
- kirkey racing seats
- 5.0 in a 1997 GT
- Spark Plug problem
- plugs
- Adding clutch plates in 31 spline T-Lok
- Power Window Switch Problem
- AC NOT WORKING
- Drivetrain Issues (possibly clutch related) help!
- Passenger Mirror and Mach 1000 stereo system
- t56 tranny
- Exhaust HELP????
- SCT 4 bank tuner
- Please Help. Coolant leak from firewall on 1998 Mustang GT
- new here!!!
- What TB/Plenum size?
- Trickflow pulley install (piggyback)- Bad? Need advice
- Miss/Stumble at idle and while driving
- X-Pipe
- ICM?
- 5 sp help!
- Stock rear rotor size?
- transmission problems
- 96 Mustang GT DOHC?
- what is the stock piping diameter?
- Need some help...
- Got my car back from the shop today... exhaust leak?
- Transmission lines
- paint ? for those who have changed bumpers or hoods.
- Porting NPI heads
- ticking noise at idle
- Changing anti-freeze
- Vinyl graphics question
- Ok Running out of Ideas!! help!
- pi swap power loss???
- SCT error, what do i do
- My heads = doorstop or usable you decide
- Timing chain going slack. Need help.
- Front Suspension
- car is falling flat on its face at like 3500-4k.
- Vibrations..braking...turning!
- Brake pads and caliper
- Need Starter..
- quick help...
- EXHAUST questions 01' GT
- shift knobs interchangeable?
- procharging my bullitt
- IAT Sensor Problems
- wet sanding tail lights after tint and clear?
- Motor help?
- clutch issue
- Cam install difficulty?
- need help
- Look what the ups man brought me today
- has my car been repainted!?
- next mod
- Cloged Fuel Injectors???
- Where can I find the cheapest slp cat back?
- Tuning Questons...
- Will this fit?
- changing light color in gauge cluster
- A few tuner questions
- What's cheaper?
- BEST LONGTUBE HEADER GASKETS
- Few questions
- Weird Noise Coming From The Motor
- Maintenance guide?
- Trick flow underdrive pulliy question
- off road x pipe
- Control arms
- Lincoln Teksid Motor Question
- Are the DOHC 4.6 blocks the same?
- Muffler Q's
- I need a how to on changing brake rotors
- how to do SCT datalogging?
- HID going bad?
- What is the torque spec for this part?
- Another spring question
- Race Strips close to Fresno Ca.
- What am I missing here? (NX Plate Kit)
- creaking in rear
- Bullitt intake
- Grinding in second and third
- Oil pressure sending unit
- tranny swap
- spoiler and fuel door
- I'm lowing my mustang
- Camber caster alignment settings
- third and fourth gear issues....
- MAC vs BBK long tubes
- Any thoughts on Solid Lash Adjusters?
- HID HELP
- Overheating
- Please help if you can!
- Squeaky clutch petal
- Fuel pump/regulator...Do you think I need one???
- 03 GT problem - first ever 60k miles
- Input shaft
- not enough fuel???
