View Full Version : 4.6 (Modular) Mustang
  1. New Head Gaskets
  2. New mods - will I need a tune?
  3. best springs?
  4. Best Clutch Kit for 99 Mustang GT (stock)
  5. offroad h pipe
  6. 2002 GT 1/4
  7. BBK VS SLP headers
  8. SLP??
  9. 40k mile service
  10. What size filter?
  11. Will it fit??
  12. so these cars come with posi?
  13. Which exhaust?
  14. torque the plugs to???
  15. gears....
  16. Cat-back magnapacks+Mac Prochamber=???
  17. power pipe
  18. eibach prokit install
  19. Trouble with posi install!
  20. SCT LIVEWIRE TUNER
  21. gauge installs
  22. coolant problem
  23. gears grind during a u-turn!?!
  24. Pirell 240????
  25. Procharger brackets...
  26. Spring settle. . ?
  27. Shifter install gone bad
  28. Tuner in central NJ
  29. Fogged up headlights
  30. where to find an intercooler
  31. how much top end loss?
  32. whining tranny or rear end??
  33. Too much gear?
  34. Fuel pump
  35. saleen 3rd break light help!
  36. Top End Engine Kit
  37. Tires?
  38. Changing T-45 fluid
  39. Getting roters cut... will it unwarp them?
  40. cog set up
  41. Nitrous setup??
  42. good all around shocks needed
  43. H&R Race Springs or Just Super Sport Springs
  44. Reverse gear grinds EVERY TIME!
  45. Changing Brakes: Whats needed?
  46. PSI STOCK BLOCK
  47. Removing cats
  48. MORE BOOST PLEASE!
  49. Brake Caliper
  50. Which way to go?
  51. Stock Block
  52. Engine weighs????
  53. wiring harness + computer
  54. reaend question
  55. My cams are in!
  56. Rear Axle Lubricant
  57. new springs install ?
  58. Catted or Offroad UPR X....??
  59. Grill Removal
  60. Turbo Gears
  61. Replacing passenger side mirror....
  62. what would cause a rough idle in park?
  63. Just put in the exhaust
  64. Flowmaster 10 Sound Clip
  65. cams and air flow sensor?
  66. decisions....
  67. Twin Turbo
  68. sputter???
  69. UPR products
  70. ABS Light
  71. Subframe connectors
  72. Widest tire for car and rim ( 10.5 )
  73. 3:73 Gear install
  74. Running HOTT!
  75. IAC trouble
  76. how to remove sidescoops?
  77. h pipe question
  78. 10 psi ?
  79. PI Swap Head Gasket
  80. Whats louder?
  81. shift kit?
  82. help with CEL please!!
  83. Front Strut Install Guide
  84. Oxygen Sensor Extenders???
  85. headers
  86. shocks and struts
  87. Jack points on a GT????
  88. Wing delete
  89. Carfax anyone
  90. Rich Condition: Cause?
  91. PI kit problems please help!!
  92. Why do people say not to go WOT into an AT's OD?
  93. Idle problem
  94. 2003-04 engine block specs?
  95. Under car ram air kits?
  96. car can't relearn idle
  97. anyone ever change out their coil packs??
  98. GOt 2 problems
  99. plug wires to coil pack diagram?
  100. Bad Idle HELP
  101. Can i do this?
  102. cleaning my MAF
  103. Exhaust leak repair?
  104. Blower belt shredding
  105. **midpipe install**
  106. mach 460 hood fuses
  107. Oil leak??
  108. Oil leak after tap
  109. 3" cowl hood Cervinis or Carbonware
  110. p1131??? cel
  111. motor swap
  112. Which 315 Tire?
  113. Supercharger/PI Swap
  114. blower noise
  115. Extra friction modifer for use with RP? Gear break in?
  116. broken piston =(
  117. Conv. Top?
  118. at what RPM do you normally shift?
  119. Tires
  120. hey!!! centi s/c's what is better-vortec or procharger??
  121. turbochargers
  122. Recalibrate Spedo...Help!!!
  123. nos wet or dry
  124. does your mustang
  125. Diablo Chip
  126. Ford Racing Springs
  127. H&R vs. Eibach
  128. Need help with x pipe
  129. superchargers!
  130. Help! rubbing sounds
  131. how long to let calipers dry?
  132. concerned
  133. UPR / Pypes products (X-pipe desired)
  134. next mod...
  135. price????
  136. Clutch Adjustment
  137. Caster Camber Plates...
  138. last thing i need
  139. big question injectors
  140. How much torque.
  141. Huge Problem
  142. stock gears.
  143. longtube vs shortube
  144. catalytic converter
  145. Will this exhaust FIT?
  146. Quick Cam question
  147. need a upgrde 03 gt
  148. Brake Kits
  149. need a good web site
  150. NEED FUSE BOX HELP???
  151. Electronic Cutout?-
  152. Open house money what to do to my car!!
  153. Car squeaks when turning?
  154. Cats H pipe!!
  155. i want more power
  156. what temperature?
  157. Nitrous Help
  158. *Requested* how to paint your wheels
  159. CLUTCH
  160. OKAY guys..EVERYONE READ
  161. Struts removal help
  162. Cut H-pipe to fit long tubes?
  163. RPM's sticking at 1300 while cruising
  164. WTF
  165. MIL Eliminators help
  166. help removing valve springs
  167. What would be best?? For me?
  168. Ford "C" springs or "B" springs?
  169. Exhaust question...
  170. HELP!!! Procharger intercooler install ?
  171. Installed Pro Kit Didn't seem to settle (Updated pictures!) IS this the right hieght?
  172. theft reset
  173. speedometer help
  174. Which is stronger? More Pinion Teeth, or More Ring Teeth?
  175. messed up paint
  176. What is this?
  177. i need help
  178. Tremec 3650 Tranny Fluid question
  179. Professional Products
  180. brake guide
  181. help??
  182. Underdrive Pullies with Supecharger
  183. Piston dish and Compression ratio
  184. Thermostat help.......
  185. is it worth spending the money/time
  186. cutting my springs.
  187. Fire out of tailpipes WtF?
  188. Swaybars
  189. Throttle problems?
  190. Quick question
  191. under drive pulleys
  192. Suspension Help
  193. 4V heads (98 cobra) conversion?
  194. Opinions what should i do next?
  195. So many options!!!!
  196. Is this worth getting?
  197. rear gear ratio in 02 gt stickshift?
  198. car running like sh!!!!T ?
  199. Brake upgrade
  200. exhuast
  201. best catted h pipe?
  202. wheel sizes
  203. check out this video!!!
  204. help out please!!
  205. Getting Warm!!!!!!
  206. Catbacks vs Mufflers?
  207. how many cams does a 04 gt have
  208. pacesetter X pipe
  209. should i get a cai with a shaker hood
  210. Engine will not sustain an idle
  211. check engine light ...??
  212. Injector Size?
  213. Smoke headlights?
  214. what engine will fit
  215. Preadator owners ??
  216. Control Arm question
  217. changing alternator
  218. check engine ligth flashing?
  219. coil packs?
  220. AC eliminator?
  221. eibach pro system plus install nightmare
  222. Mac long tubes for $200!! Question
  223. More 5.4 Questions . . .
  224. Will this work?? What will it support?
  225. INSTALLED 70MM ACCUFAB TB/PLENUM COMBO
  226. ****IF YOUR A BLOWN GT**** read this
  227. Max speed in third with 4.10's?
  228. SCT Tuner.
  229. Baddd Shakes!!!!
  230. rear end leak
  231. gt to a mach 1
  232. need help with lowering springs
  233. What do you guys think of the 99-04 GT STOCK exhaust sound?
  234. Are my stock 03 gt mufflers made by flowmaster?
  235. Radiator fan motor locking the fan?
  236. H pipe
  237. size - rear
  238. Leak behind rear passenger wheel...
  239. Removing spoiler?
  240. installing LTs right now, use the EGR delete or no?
  241. magnapacks+ ????????????????HELP
  242. 2 questions
  243. replace flowmasters with ?
  244. PI Cam on NPI Heads?
  245. Should my auto at WOT be shifting into 4th gear @ 5200?
  246. Mach 1 chin spoiler clearance issues?
  247. steeda timming tool
  248. Mongoose kit
  249. Long time reader, 1st time poster with questions
  250. weird s/c noise
