View Full Version : 5.0L General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. CAM
  2. 347 TEMP
  3. Tire Pressure
  4. 5.0 turbo
  5. Question about Retrofitted AC
  6. GT40Ps!!!!!!
  7. TEST DRIVING A NOTCH(LMAO)
  8. what happened to the posts?
  9. How to? - Remove Airconditioning in 89GT
  10. Project supercharged 408w build (update 6/14/08 w/questions) 56k
  11. found on road dead
  12. problem idling. . . .
  13. Walbro fuel pumps
  14. deleted
  15. picked up 2 motors a 89 and 86 wheres the block numbers??
  16. Need a t5!!
  17. lil 347 we did up for a friend
  18. ah the good old days police 5.0
  19. impact sockets
  20. throttle cable
  21. Put a Windshield in a 7 sec Fox Today at Work
  22. Wreck at richmond StreetNight pics
  23. Restoring or painting molding on car....
  24. trouble codes
  25. way to test injectors
  26. went to track pics
  27. long time since i posted but here i am
  28. which valve covers do you have?
  29. how to modify explorer tb?
  30. going to fi from carb
  31. I swear this car is an addiction...
  32. Is this normal ground clearance for a Bassani X?
  33. idle trouble
  34. Help anyone...?
  35. PowerGlide in a Fox ???
  36. Advice/input on look....
  37. pic of mounting spot for clutch cable bracket?
  38. SSP fox
  39. MOVED: raced a civic hatch with a gsr 1.8l couldnt beat him:(
  40. Venom VCN 2000 Nitrous kit (Sweet)
  41. Ordered exhaust....finally and did some resto
  42. What Pushrods??
  43. best time at the track was 18.11...
  44. Which Tuner?
  45. side exit exhaust on a fox
  46. i cant find
  47. just came from da track 2 day
  48. Just Got Her Painted (Finished Product Pics)
  49. Problem With Car
  50. cobra r rims
  51. Mustang steering wheel HELP
  52. AOD to T5 swap?
  53. Welded my sump today (pics added 56k warning)
  54. how big a slick...
  55. Finally got to the dyno
  56. Dupped by the Dealer
  57. aod shift cable
  58. new here...
  59. Ebay Alternator, Opinions Needed
  60. Tire size?
  61. power steering and elec. fan
  62. Might buy a 4 EYES, Is this worth it?
  63. Mallory or MSD
  64. next mod? help!
  65. 1600 HP Mustang Destroys the Driveshaft on the Dyno
  66. headlight switch ?
  67. what have you ****ers been up to?
  68. ford racing 3.73's
  69. Suggestions on good Car to swap seats from?
  70. Estimate on times?
  71. some more of the rear bar tire (pics)
  72. Line loc install Pics!
  73. sits higher drag spring PIC!!!
  74. Power steering pump removal/installation?
  75. opinion needed
  76. fouling plugs
  77. Look what I picked up today
  78. timing prob's
  79. progress on the suspension swap
  80. Strong Gas Smell
  81. quick lx gt tailights swap question....
  82. 94-95 cobra
  83. pics of 5 inch tach + shift light in sn95
  84. 5.0L Mustang/Capri
  85. best place for 555r's?
  86. Couple vids/pics from this past weekend
  87. Custom Chip Suppliers
  88. checking fluid level on TKO 600?
  89. Perfect street build on a 10k budjet.
  90. Headlights...OEM vs Reproductions
  91. getting rid of smog pump
  92. a/c delete kit for fox body
  93. coolant light on
  94. why do people say 306 like its something better than a 302?
  95. MSD Ignition Install *PICS*
  96. 89 lh convert
  97. Which vendors take Paypal?
  98. what kind of tires you all running for skinnies
  99. Where did that thread go????
  100. Disty Help
  101. The racers edge performance
  102. Transmission
  103. egr delete
  104. NEED HELP WITH MY 5.0!
  105. My new car
  106. might be getting another mustang
  107. quick question
  108. 5.0 section projects
  109. Got some cash!
  110. Fuel pressure help
  111. 87 Fox Idles High After Highway
  112. So i Finally Got My Bottle.... ; )
  113. surprised to say this.....
  114. What is this part called?
  115. 7.5 Rear end carnage (pics)
  116. ??'s about overheating
  117. $2,000 to spend for my ride
  118. Finally found another
  119. toasted my t5
  120. Myrtle Beach area.
  121. What motor oil are you running this summer?
  122. old gunky oil in motor
  123. 302 Rebuild
  124. Transmission Question
  125. check this out!
  126. went to the junk yard today
  127. alt help
  128. AOD to TkO swap? pilot bearing?
  129. pics from the car show
  130. explorer intake
  131. Spout connector
  132. ??????
  133. ??????
  134. went to the track!! video's!! and busted
  135. ANY IDEAS???
  136. I need some trans. help fella's
  137. Quick Question on Master Cylinder
  138. Curious?
  139. need rims quick
  140. 90 Mustang GT convertible whats it worth?
  141. black sticky stuff under weatherstripping
  142. rear end gears
  143. Detailed the Phantim this morning
  144. Bought another catback...
  145. need some help please!
  146. Cobra MAF question?
  147. Easiest Way to add tilt?
  148. Leather Interior Paint?
  149. surging problem
  150. Sunroof Leakage
  151. dropping and pulling out steering column?
  152. Maryland Car Show this Sunday!
  153. Anybody with SN-95 seats in their fox?
  154. NEW GUY
  155. cowl hood pics
  156. Normal To Keep Up With a Modded 06? + Video
  157. Possible New Mustang
  158. Painting a Mustang
  159. 93 cobra front bumper
  160. Interior Paint
  161. hp estimate with my mods
  162. fuel pump question
  163. Thinking of Buying...
  164. HP with build?
  165. Exhaust systems???????
  166. Anyone know what size wires are used for MSD box...
  167. Astro Transmissions
  168. 86 stuff
  169. LOOK what happened to my local track last night
  170. 94 GT Problems
  171. jacking up car???
  172. line drawing of fox body gt
  173. What is a good 302 setup?
  174. Help me pick out my headers
  175. can i fit 17x10
  176. Best looking hood for an sn95
  177. CRYSTAL BALL ET ANYONE???
  178. taking a big step
  179. Pedestal Mount Bolt Size
  180. b&m replacement stick
  181. SLP loudmouth(how loud will it be)
  182. P-51 Theme for my fox.
  183. Converting a sn95 tb to fox body style
  184. slight vibration ??? help
  185. Help can't figure it out!
  186. Longtube Headers--->Midpipe?
  187. What is Leaking?
  188. Rotting floors? HELP!
  189. fully custom guages
  190. Mustang Trunk
  191. problem with intake
  192. SHOULD I RUN SYNTHETIC
  193. GT tailights to LX...straight swap?
  194. CALLING ALL 5.0 PICTURE WHORES
  195. What to do about leaky sunroof? {UPDATED w/ PICS}
  196. I hate stupid people...
  197. Deal for Convertible Owners
  198. didnt know what i bought - GOT PICS UP NOW.
  199. Turbines- Center caps- Quick
  200. Me and A Lightning
  201. installed headers
  202. upper intake manifold gasket
  203. Wooooooot
  204. Painting HELP!
  205. bought a 5.0
  206. Gas Gauge HELP!
  207. Slipping and Engine light
  208. Exhaust video!
  209. Installed my Steeda tensioner pulley
  210. coolant drip wtf!!
  211. I just bought . . .
  212. my new ride
  213. I need help w/my Mass Air 5.0
  214. Need help with shift light
  215. Gauge spot filler idea?
  216. Runnin rough
  217. vote!! go with stalker bumber or stock
  218. MOVED: Cobra Tattoo
  219. Flashlight Drags
  220. Wolverine
  221. Quick question ladies
  222. gauge
  223. probability of a new 5.0
  224. compression tester
  225. wheel widening
  226. my new setup
  227. octane booster
  228. Who has the GT with the LX style exhaust poking through the GT bumper?
  229. sheet metal door panels
  230. "Shopping List" for a decent engine swap
  231. Problem with my cowl induction hood.
  232. '94 SN95 V6 to 302
  233. MOVED: NORTH CAROLINA
  234. Ordered more swap parts from Summit.(update w/ pics! 56k beware)
  235. Nice highway run
  236. More money!!!
  237. Mustang is no longer....
  238. pics/vid of my 85 from TAD 03/10/2008
  239. Will Mototr swap work?
  240. cam questions
  241. Pictures of door jamb
  242. Its not a 5.0 but
  243. smog pump delete
  244. R302 vs. Dart, World..............
  245. Countdown to DynoTune!!
  246. Bought a
  247. What kind of wheels are these? Help!!!
  248. Valve Cover Recommendations???
  249. Best looking sn95 hood
  250. Fuel pressure
