Go Back   MustangForums.com > General Mustang Forums > Forum Issues and Feedback
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-29-2009, 04:48 PM   #1
erikka.paige
1999 Ford F-Super Duty
My Garage
erikka.paige's Avatar
Vehicle: 1999 Ford Mustang GT
Send a message via AIM to erikka.paige Send a message via MSN to erikka.paige Send a message via Yahoo to erikka.paige
Talking Throttle Position Questions
Hi boys!! My name is Erikka, I'm 21 years old and I am new to the forum. This is my first thread... lol. I have had my car for a little over a year. I love it. I have had a few fun things done to it, but from the exterior of the car you would never know.
I have a quick question. Any insight would be greatly appreciated. The other day my check engine light came on. So I grabbed my scanner and checked it. I can't remember the exact code, but it was something about the throttle position. My car will randomly idle high. And it doesn't have a set RPM that it will idle at either. Sometimes it idles at 900, and others it's1500, or even 2200... wtf?? I can rev it up and it doesn't stop. I can shut the car off and it won't stop... nothing really works. It just fixes itself. The scanner said my car was at 16% throttle at an idle.
So I guess my question is... what should I do? Any reason it could be doing this? Thanks guys! I appreciate any and all help!!
erikka.paige is offline   Reply With Quote
Old 08-29-2009, 05:35 PM   #2
BlueBloodedPony
Forum Sn!tch
2000 Ford Mustang
BlueBloodedPony's Avatar
Vehicle: 00 Stang shooting a full clip
You probably won't get an answer here lol. This is for forum problems and technical difficulties within MF. You will want to post that question in this forum:
4.6L Tech
Also, that code would really help. Someone a little more mechanically inclined than myself should be able to answer this though.
__________________
2000 Ford Mustang GT; Accufab 75mm TB&P; JLT cai; SLP lm2'S; Summit O/R H; Sniper tuned; 4:10's. SFC's, Tokico HP Series Shocks & Struts, H&R Super Sport Springs, MM Caster Camber Plates, UCA's & LCA's all are here; To be installed shortly
Quote:
Originally Posted by Rdot9 View Post
...mmmm nice and thick ftw...
BlueBloodedPony is offline   Reply With Quote
Old 08-29-2009, 06:08 PM   #3
erikka.paige
My Garage
BEFORE replacing the TPS the scan tool said the code is P1120PP Sensor out of range low. I erased the code.
__________________
CAI W/80mm MAF, Custom H-Pipe W/Flowmasters, Eibach Springs from Germany [not lowered much] Air Springs Rear Kit, Adjustable Rear Shocks, Spec Stage 2 Clutch Kit, Billet Aluminum Clutch Quadrant, Drilled And Slotted Rotors, Offset Rack Bushings, Underdrive Pulleys, Pro 5.0 Short Throw, 3.73 Gears, 31-spline Traction-LOK, Lakewood Lower Control Traction Lift Bars, Trick flow diff cover, Axle brace, 275/55/17 rear and 255/50/17 front, Caster/Camber Plates, Ported Intake Plume, Aftermarket Fan
Old 08-30-2009, 11:32 AM   #4
BlueBloodedPony
Forum Sn!tch
2000 Ford Mustang
I have to ask, are you topless in your avatar? Regardless, welcome to the forums, if I didn't welcome you already. I also see the other 4.6 boys are helping you out, so I will leave it at that.
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
