Sponsored by:
Sponsored by: DashLynx
Window motor
Old 08-31-2014, 09:54 PM
Nickkkx24
Nickkkx24's Avatar
Default Window motor
I have a 2001 mustang I haven't had a problem with it but now my passenger side window won't go down I did some simple tests and I know my motor is bad, but my question is can I just replace the motor? With out having to pull the regulator out? And if any body could give me some guided steps, I would really appreciate it
Nickkkx24 is offline
Old 09-01-2014, 11:57 AM
yourmom6990
yourmom6990's Avatar
I believe there is a way to replace just the motor. I'm pretty sure you have to take the whole unit out as a whole. It's fairly simple though. I fixed a window issue on my brothers pontiac. I'm thinking its the same setup. Had to take the door panel off, Then roll the window down like half way and take out the two bolts that held the window to the regulator. Pull the window out (remember how it comes out and put it in the same way so you don't break it) Then the window/regulator is held in by like 6 bolts. Take them out and the whole unit should be able to slip out the door. Then take the motor off the regulator and replace if needed.
BTW, this is the wrong section. This section is for issues relating to the forum. It can get a bit confusing for the newcomers. Try posting in the general tech if you need more assistance. Good luck.
yourmom6990 is offline
Old 09-02-2014, 11:21 AM
AzPete
AzPete's Avatar
I have not done a Mustang, but on other Fords, I have never had to remove the window. Roll it up. Pull the door panel and locate the motor. Ford is good about leaving a dimple in the metal where a hole needs to be drilled so you can access the motor mount bolts. Drill, pull bolts, remove motor. Several motors may fit and the electrical plug may need to be changed on the new motor.
AzPete is offline
Old 09-02-2014, 11:25 AM
yourmom6990
Drill holes? Sounds like improper installation to bypass time. Should not have to drill holes to replace something.
Old 09-02-2014, 01:13 PM
AzPete
AzPete's Avatar
Well, so far, 93 Explorer, F 150s, full size Broncos....all need the hole drilled to access the bolts.This is according to all instructions I have ever seen. Right or wrong on the original plans (Ford left dimples as a guide for the holes), that is what it takes on the vehicles listed that I have replaced them on. Just not sure on the Mustang. Think what you want about improper but I have done the work.....according to the book.
Once the motor is out, the issue could be the gearing in the motor gear box. Sometimes, the three ***** inside the gear box break up. They can be replaced for a few dollars as opposed to maybe 50+ for a motor.
AzPete is offline
Old 09-27-2014, 10:39 PM
99GTvert
is my username.
99GTvert's Avatar
Moving to general tech..
99GTvert is offline
Old 09-28-2014, 02:52 PM
Special20
Special20's Avatar
Hi-- buy the regulator and motor from here and follow the video on how to do it. Easy as pie and done in 45 minutes-- Hope this helps http://www.1aauto.com/ford-mustang-p...or/mo-c/243-22
Special20 is offline
Old 09-28-2014, 09:00 PM
DRAGUL
DRAGUL's Avatar
I have done it before awhile ago. Here is what I remember. No you do not have to drill holes. The motor and gearbox come as a assembly. Remove door panel.I supported the window glass so it would not guillotine my hand when I removed the motor. There are 3 bolts that hold the motor/gearbox in place. I had to loosen the nuts that hold the window regulator gear assembly in place. I loosened and pushed the studs into the door giving clearance to remove motor. Remove the 3 bolts holding the motor in place. You have to reach in through the rear hole in the door to remove it. It is mounted at the front of the door. You can not see it you have to do this all on feel. Hope this helps.
DRAGUL is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
logan409
09-26-2015 07:43 PM
Quick Reply: Window motor
