Wanting to Build an Engine....
Ive wanted to build an engine for the longest time. The only real reason is just to see if I can do it. I want to build a 4.6 from a bare block with stock stuff i guess, and see if it works without blowing up.
What would be my best bet to do this? Like go to a junkyard or Ask around to see if anyone has a block or something? How hard would this be to build that is?
RE: Wanting to Build an Engine....
I guess so, Ive always wanted to build an engine from nothing. It just looks fun. I dont want to get a perfectly good engine and take it apart, that would be dumb. But no real experience, no formal training. Ive been in shops/garages alot.
How much money do you want to invest in this experiment.... dont forget to calculate tools.... [sm=chairshot.gif]
ORIGINAL: 97BlackStang
Well Im going to suggest starting small. Keep your eye out for a briggs and stratton lawnmower engine. Im not kidding. These make for an EXCELLENT start... youll learn about basic engine operation and fundementals and its alot easier than a car engine. I do power equipment maintnance/repair as a side buisness so Ive worked on countless small engines like this.
Keep in mind, you will need quite a few tools, beyond basic hand tools, to "build" and engine...
at least 2 different range torque wrenches (maybe even 3)
ring compressor
ring expander
feeler guages
cylidner hone
bore guage (set)
Micrometer/caliper
cam degree wheel
dialindicator/base
gasket scrapers
a General purpose Puller (harmonic balance/steering wheel type)
Maybe even a cam bearing installer depending on how involved you get
valve spring compressor
serpentine belt tool
Theres alot of measuring and "adjusting" that goes into building an engine, its not like taking it apart and putting it back together. You need to be able to recognize possible problems that can occur, not to mention the COUNTLESS measurements that you need to take. Get somebody who has done it before and KNOWS WHAT THEY ARE DOING to guide you through it. You need to know your limits, Im only on my 3rd "REAL" engine (that I have serviced internally to be reinstalled into a car) and it takes a bit of "practice" if you will.
Jim
ring compressor
ring expander
feeler guages
cylidner hone
bore guage (set)
Micrometer/caliper
cam degree wheel
dialindicator/base
gasket scrapers
Jim
ORIGINAL: kartracer55
ring compressor
ring expander
feeler guages
cylidner hone
bore guage (set)
Micrometer/caliper
cam degree wheel
dialindicator/base
gasket scrapers
Jim
ring compressor
ring expander
feeler guages
cylidner hone
bore guage (set)
Micrometer/caliper
cam degree wheel
dialindicator/base
gasket scrapers
Jim
Well I know how to "build" and engine. I know all the things that make them work, how they work etc etc, ive dont the briggs thing a few times before, very succesful actually. I know you need to take alot of measurements. As far as tools go i have everything on your list aside from the ring compressers, which may be somewere i just dont know it, the ring expander and the dial guage and base. Oh and the cylinder hone, but the Girlfreinds dad is a race car driver/mechanic by profession. He MAY let me barrow some stuff.
