Sponsored by:
Sponsored by: DashLynx
difference between a big block and small block
Old 03-11-2006, 11:21 PM
ikeybmg
ikeybmg's Avatar
Default RE: difference between a big block and small block
the biggest diff. i see there is length.
ikeybmg is offline
Old 03-12-2006, 11:44 AM
Chopper
Chopper's Avatar
ORIGINAL: JD1969
What Redass said plus. Most of the auto makers would use two (somtimes more) seperate block castings. For example, GM's small block 327 and 350 look the same from the outside but the bore and stroke are different, they also share external accessories and most times heads and intakes. At some point the block is only going to accomidate a certain amount of cubes, so a new larger casting was needed, hence the big block.
This is the best simple definition there is.
Chopper is offline
mtgldr
02-03-2024 09:00 PM
Luke9222
10-22-2015 11:55 PM
rdog69t
SVT Forums
09-13-2015 06:16 PM
09-08-2015 05:21 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: difference between a big block and small block
