does anyone...know...mach1 recalls?
i looked to see if this has already been posted and didn't find anything...but i was wondering if anyone knows of any recalls or are experiencing any problems with they're 03/04 mach 1...i'm going to be getting one here in a few weeks and would like to know what i'm in for...thanks
RE: does anyone...know...mach1 recalls?
ORIGINAL: rshstng
cool thanks for checking that out...if the dip stick is the only thing that i'm gonna have to worry about i think i'll be set...thanks for lettin me know
ALLDATA TSB's on the Mach 1's
TSB Number Issue Date TSB Title
03-15-1 AUG 03 Rear Window Defroster - Inoperative
03-14-8 JUL 03 A/T - Cooler Flushing Service Tips
03-14-4 JUL 03 Ignition System - Engine Misfire Diagnostic Tips
03-11-6 JUN 03 Electrical - Wiring Soldering/Crimping Tips
03-11-4 JUN 03 Engine - Left Hand Side Ticking Noise
03-9-8 MAY 03 Emissions - MIL ON/EVAP System DTC's Set
03-9-5 MAY 03 Suspension - Rear Suspension Clunk/Pop Noise
03-8-3 APR 03 Engine - Oil Level Indicator Markings
03-1-5 JAN 03 Interior - Passenger Seat Squeaking Sound
02-23-7 NOV 02 Cooling System - Premium Gold Coolant Service Info
02-23-3 NOV 02 Fuel System - Fuel Pressure Relief Valve Discontinued
02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set
02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check
02-20-8 OCT 02 A/C System - Diagnosis and Service Tips
02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling
link: http://www.alldata.com/TSB/19/031917E6.html
I believe Mach1Registry covers the early 2003 Mach 1 recall on welds that were not performed at Ford, most were found and repaired while at Roush Racing awaiting their suspension mods, although some slipped through.
i'll look into making sure all that stuff is done if i get an 03...hopefully i will be able to have enough to get the 04 though...even then i'll make sure that that stuff is done right incase it was one that sliped through...thanks
