What gears should i get? im sick of getting whooped by other gt's :(
#31
RE: What gears should i get? im sick of getting whooped by other gt's :(
ORIGINAL: Sidewayz6.0
What? Where did you get that?
ORIGINAL: redass02gt
I believe the 4r70w (or whatever the correct jumble of letters is supposed to be) won't shift into o/d at WOT. burns out the weak o/d band or some crap like that.
#32
actually, many shift kits even advertise the fact that their shift kits will allow you to shift into OD at full throttle. If OD was just a normal gear and you could shift into it at WOT normally, why advertise that "feature?"
#33
Thats odd. I've personally never heard of it. However, I've never owned an automatic Mustang. Of the 3 Mustangs that I've owned/own, they were all sticks. Although every car I have owned that was an Automatic shifted into 4th at WOT.
#34
#35
ORIGINAL: samseed101
I figure there's no sense in arguing the point since people are hard set in their minds about what gears they like. Personally, my 95 does NOT shift into OD at WOT. Many people I know have cars that won't shift into OD at WOT. I also know that frequent shifting into and out of OD at WOT and at high RPMs is bad and can shred the band. You're not going to kill 3rd gear as easily from ****fing in and out of it at high RPMs are you? The difference beteen 3.73 and 4.10s near redline in 3rd = only about 10 or so MPH. But then again, every bit counts. i guess it depends on personal preference again.
It's not designed to be a gear that can be "beaten" and shifted in and out of all the time. But if that's what you prefer, tehn continue to dump in and out of it at WOT. It's your' tranny, not mine so have at it.
The second part about the 3.73s VS. 4.10s only being maybe a 10 mph difference is helpful information as well. That was the point I was trying to make is that there is next to no difference between the RPMs in the 2 gear sets. Now the author has all the information he needs to make an informed decision.
Thanks dude.
#36
ORIGINAL: MikeHawke
thanks for the info on the shifting into OD at WOT [sm=smiley20.gif] I didn't know Ford did that. That's gay LOL.
Thanks dude.
Thanks dude.
True 10 MPH may not make a huge difference. But when he starts getting a badass car with some major rwhp.. at the end of the 1/4 mile it's gonna suck to be stuck at 108 or so... either that or force it into OD and hope for the best. The upside... you get to 108 much quicker than you would in 3.73s. The downside... you're stuck at 108 as opposed to 118 or so.
If you come off the throttle a bit, it will shift into OD and then you can slowwwwly accelerate and get into the higher numbers.. And like you said, you will never reach that therotical number for the redline in that gear.. which is 202 MPH in 3.73 or 161 in 4.10s.
I wish Ford would do something about it and give one more "true" gear that you could treat just like 1 - 3... Well I guess they did do something... it's called "manual." But I was hoping for a better solution.
I know most people probably won't be pushing past 108 at WOT anyway.. but I was at 115 at WOT this past weekend... 3rd was damn near maxed out ;(
#37
hwat does your stang top out at being that you have 3.73's? and when your crusin at 65 does it have a good take off or is it **** poor
Yeah, it really is gay. I found out the hard way when I had my first mustang that was auto (an 88 5.0) It's hauling *** and gets to the redline, but doesnt shift. I finalyl did some research and found out that it is designed that way and it's a weak band. Also learned that frequent shifting into and out of it in any condition can weaken the band. That is why many people elect to shut it off using the button when driving around town.
ORIGINAL: MikeHawke
Thanks dude.
Thanks dude.
#38
With my 3.73s, if I am cruising at 65 MPH on the highway (meaning I am going to be in OD) then my RMPs are 2,126. If I all of a sudden floor it for acceleration, it's going to drop me into third at about 3,173 RPM. Depending on how hard I get onto it, it may even put me in second at dump me into second at 4,664 RPM before going back to third. So I stil have plenty of room to play and it will pull away nicely. If I stay at WOT, I can go all the way to 120 at which point, I am redlined in 3rd. Once I got off the throttle a bit, it would shift me back into OD and if I were still doing 120, I would be at 3,925 RPM. Of course, as you go higher the numbers become theoretical (gotta have enough power to get to that speed.) But you can easily be going 65 in OD and shift down to third or even second for some power.
Keep in mind you CAN do this with 4.10s. You just lose a little off your top speed and the RPMs will be a little higher.
#39
#40
Oh yea, I have 3.73 gears here, that i haven't installed yet, because i haven't found anyone to do them yet. Should I keep them, or get 4.10?
part 2 to my question earlier
