RE: Drag Radials...
I should have told you this the first time you asked StangMang, on the stock 15x7 turbine wheels on my '88, I was able to run a 26x9 Hooiser slick but in a turn off the track the inside of one tire would just barely rub on the outboard shock just enough so I could hear it squeak when I turn off the track. I removed the shocks since I didn't need them anymore as I did some rear suspension mods and have a pinion snubber too, so hope that helps you out some. 9"=229 mm
__________________
retired and drag racing all I can now that I have the time!
13.533 @ 96.24 mph w/1.780 60', ALL THROTTLE, NO BOTTLE! 13.557 @ 98.24 mph most recentl
