Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-10-2004, 04:45 AM   #1
Acer2428
Armed Moderator
Acer2428's Avatar
Vehicle: F-250 7.3L Powerstroke
Default Drag Radials...
I can get some 295/35/18 BFG drag radials for the same price as the 285/35/18 Nitto 555's and about $50 less than the Nitto DR's.
How much faster will the drag radials make my ET's? What about streetability? I know their tread life is short, but how short?
Also, I'd love to have matching tires, but I couldn't afford BFG's on the front... Is it really worth it for a car that's going to the strip MAYBE twice a year and just racing ricers and other kids from my HS?
EDIT: Crap, I have more questions... What's the widest i can go on a 18x9" wheel? 275, 285, 295? What's the biggest that can fit under the car? I don't want to rub or replace any suspension items yet (can't afford it)
Thanks all!
__________________
Quote:
If god wanted you to hit your target on the first try, he wouldn't have invented the semi-automatic.
Acer2428 is offline   Reply With Quote
Old 08-10-2004, 04:53 AM   #2
nomocobra
Default RE: Drag Radials...
honestly, bfg are MUCCHH stickier than the 555r's, but if your only going to the strip twice a year, i say go with the nittos because they will last much longer.
nomocobra is offline   Reply With Quote
Old 08-10-2004, 11:12 PM   #3
jdaniel
I ♥ Acer
Said it before and I will say it again... Im gettin some Nitto's!!!
jdaniel is offline   Reply With Quote
Old 08-10-2004, 11:24 PM   #4
vfast
I ♥ Acer
max..traction...e.t. streets
vfast is offline   Reply With Quote
Old 08-11-2004, 01:21 AM   #5
Acer2428
Armed Moderator
Acer2428's Avatar
Can somebody answer my size question????
__________________
Old 08-11-2004, 01:43 AM   #6
Obsol3te
Send a message via ICQ to Obsol3te
Not completely sure, but.
I think my friend is running 275's ok and couldve gone wider
In his 98GT
__________________
R331 Stroker @ 8.5:1
313RWHP 339RWTQ (N/A)
423RWHP 518RWTQ (N20)
Obsol3te is offline   Reply With Quote
Old 08-11-2004, 06:17 AM   #7
beezy
Send a message via AIM to beezy
I have 285 on my 18x9, not sure if I can go bigger or not
__________________
2003 GT
Steeda tri-ax
Magnaflow Magnapacks & x w/ Cats
18x9 Steeda Ultra lites w/ Nitto 555s
C&L 85MAF w/ inlet pipe 75mm Accufab TB C&L Plenum
FRPP 4.10s Tokico D-spec S&S, Steeda Sport Springs, U&L control arms
beezy is offline   Reply With Quote
Old 08-11-2004, 11:55 AM   #8
Acer2428
Armed Moderator
Acer2428's Avatar
As long as the 285's will fit, I'm happy. I think I'll stick to the nittos, thanks guys.
My setup will be:
245/40/18
285/35/18 Nitto 555R's... On 18x9" chrome bullitts
__________________
Old 08-17-2004, 02:12 PM   #9
StangMang
Send a message via AIM to StangMang
Anyone know what the largest size tires you can put on a 88 gt??
__________________
StangMang is offline   Reply With Quote
Old 08-17-2004, 08:12 PM   #10
roundman
that's a very hard question to answer as it all depends on the wheel diameter, wheel width, wheel offset, wheel backspacing, and suspension mods if any were made to lower the car. whether or not you keep the outboard shocks on the rear also affect the the max size combo you can run on the rear too. generally, you can get by with wider combos in the rears since you don't have to worry about steering clearances like you do on the front end. best advice I have is to go talk to the guys at the nearest and best high performance tire shop, they will be able to give you some ideas of what will and won't fit.
__________________
retired and drag racing all I can now that I have the time!
13.533 @ 96.24 mph w/1.780 60', ALL THROTTLE, NO BOTTLE! 13.557 @ 98.24 mph most recentl
roundman is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
