Sponsored by:
Sponsored by: DashLynx
How to burn out an auto...?
Old 07-16-2003, 03:40 AM
Jugador1
I ♥ Acer
Jugador1's Avatar
Default How to burn out an auto...?
how bad is it on an auto tranny to put it in neutral rev and throw it in drive? also...would having it in drive and holding the brake, revving, and then dropping the brake work?
Jugador1 is offline
Old 07-16-2003, 11:07 AM
jeep45238
I ♥ Acer
jeep45238's Avatar
It's extremely bad for it.
The second idea is called powerbraking. Rev untill tha car wants to move forward, back off a LITTLE, then release the brake. It's like dumping a clutch.
To burn out in an auto: put in low. Stand on your REGULAR brake. Mash the gas.
jeep45238 is offline
Old 07-16-2003, 12:29 PM
99dropTop
99dropTop's Avatar
to burn out in an auto....</P>
hold down the regular brake as hard as you can</P>
hold down the gas as hard as you can.</P>
</P>
99dro&#112;Top is offline
Old 07-16-2003, 06:29 PM
Jugador1
I ♥ Acer
Jugador1's Avatar
</P>
Whats putting in low?</P><edited><editID>Jugador</editID><editDate>37818.6876851852</editDate></edited>
Jugador1 is offline
Old 07-16-2003, 07:14 PM
99dro&#112;Top
99dro&#112;Top's Avatar
he means put it in first gear.... you dont have to... i dont.
Old 07-16-2003, 07:15 PM
99dro&#112;Top
and, i wouldnt reccomend doing this often... unless your car is under warentee like mine<IMG src=smileys/smiley1.gif border="0"><IMG src=smileys/smiley1.gif border="0">
Old 07-16-2003, 07:27 PM
Jugador1
I ♥ Acer
Jugador1's Avatar
why put it in 1 if u wanna keep going after that</P>
Jugador1 is offline
Old 07-16-2003, 07:28 PM
Jugador1
I ♥ Acer
Jugador1's Avatar
also...is it bad to shift on the fly with autos, like go from 1 to 2 to 3 to D or OD
Jugador1 is offline
Old 07-16-2003, 11:30 PM
jeep45238
I ♥ Acer
jeep45238's Avatar
The reason I prefer to put it in low (or 1), is because usually that's a climbing gear, and has a short ratio. It lets the tires break free faster if the tranny doesn't start in that gear from a stop.
It's not bad to shift on the fly, you just don't get anything good outta it (and I hope your reverse block out is in effect).
Old 07-16-2003, 11:34 PM
vfast
I ♥ Acer
vfast's Avatar
your u-joints will love you for rev'in it up and dropping it in drive. I always drop in 1st while doing my burn out shift up to 2nd to roll out...hard on the drive train to have the wheel spinning and you let completly off the gas
go to the track to see it done
vfast is offline
Quick Reply: How to burn out an auto...?
