CD Error on Mach 460 cd-changer - Page 3 - MustangForums.com
Sponsored by:
Sponsored by:
Old 07-03-2007, 04:02 PM   #21
Spoutz
Default RE: CD Error on Mach 460 cd-changer
i fixed mine after i replaced it. i can sell it to you for a fraction of a new or refurb. a cd was jammed so i replaced it then cleared it out. i can help you. e mail me
Spoutz is offline   Reply With Quote
Old 07-03-2007, 04:37 PM   #22
shadowfoxx
Quote:
ORIGINAL: Augy
Well, I decided to take it out again and REALLY take it apart this time. I messed with all sorts of stuff I shouldn't have and pulled a few things out that seemed a bit foreign. Lo and behold, when I put it back in it WORKED. I'm tempering my enthusiasm a bit because I don't know how long it will last but it's the first time I've heard the sound system really shine (radio sucks). Sounds pretty darn good for factory. So, to those reading this thread with similar issues...don't give up.
yeah.. the cd error on our cars are VERY common.. they are a piece of junk.. speaking from experience: for some reason pulling the negative cable off the battery alone does not always fix the issue.. if this happens to you again disconnect both battery cables for about 10 seconds then put them back on .. that has always fixed the issue with me.... at least until it starts to flake out again..
or
just replace the factory unit with something better.
shadowfoxx is offline   Reply With Quote
Old 04-08-2014, 06:05 PM   #23
c5zee
Default wooohoo thanks MustangMike2001
Quote:
Originally Posted by MustangMike2001 View Post
Radio fuses are#27 (25A) and #32 (15A).
Thanks MustangMike2001 , bought the car and cd's jammed inside, pulled the fuses and was able to get out the cd's! I didn't have a manual so that really helped... my #27 fuse ended up being a 20amp but it was the right fuse none-the-less. Signed up here just to post this... good luck with the cd changers.
c5zee is offline   Reply With Quote
Old 04-08-2014, 06:56 PM   #24
GTgeezer
GTgeezer's Avatar
Mine did it and it was a cd stuck in opening just behind door which I was able to dislodge with another cd. this happened while unloading cd's and I found I had better luck if you hold the load button (long press) which is auto load and no problems.
GTgeezer is offline   Reply With Quote
Old 07-07-2016, 09:28 PM   #25
zachbiery
Default Simple Solution
This isa real common problem. I used to be able to get mine going again after a "cd error" by pulling the fuse to reset it but eventually nothing would get it working again. The in dash changers are junk. It will have to be replaced.
3 easy steps. Press CD, press scan, press 1. This is the official Ford reset process.
zachbiery is offline   Reply With Quote
Old 07-13-2016, 09:35 AM   #26
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
Quote:
*perk*?
I'm writing this down in my shop manual. Thanks for the information.
fastbackford351 is offline   Reply With Quote
TNT, New PB TCStangerv6 Street/Strip 12 10-11-2015 06:57 PM
Rear Package Shelf jrrhd73must Classic Mustang General Discussion 2 10-02-2015 10:17 PM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 02:27 PM
Please help! 10 Check engine codes mrtrodonet V6 (1994-2004) Mustangs 1 09-29-2015 12:13 PM
Patience is a virtue! 2007CalSpec Off Topic 14 09-26-2015 01:08 AM
460, cd, changer, error, errors, fix, ford, jams, mach, machcd, sound, stereo, stuck, system, taking
