cant get the trim off
Im trying to get the trim off the a/c & radio panel so I can fix the a/c vents but I can't get it off. I already took off the two small screws and got the shifter bezel off no prob with a screwdriver but the trim that I need to get off wont budge, what can I do???
Ok the screws you removed were below the heater controls Correct? If so then pull/pry stright outward it will come out trust me I work for ford. I at times use a small pocket screwdriver and pry at the top of the a/c vent area the dash will dent slightly but it will pop back into place.
09-16-2015 07:53 PM
